Old 05-05-2015, 08:16 PM   #26
CrimsonTide
Re: Radiator Support Install ???
Anyone??
CrimsonTide is offline   Reply With Quote
Old 06-19-2016, 10:22 PM   #27
projectking
projectking's Avatar
Originally Posted by CarterD2015 View Post
This pic is from the '68 chassis service manual. I'm not sure if it shows what you need as I haven't replaced a radiator support before. Hopefully it helps.
In carters manual pic I find it unclear as to which are rubber/steel pretty sure I have it right but just want to make sure.
Jon
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 06-20-2016, 12:09 AM   #28
stsalvage
Scrapper 1
stsalvage's Avatar
make sure you double Nut the bolt.But a nylon nut in there ot makes taking them off for any reason easier
stsalvage is offline   Reply With Quote
Old 06-20-2016, 05:55 AM   #29
Mjminino
Hopefully this helps you. This is what i went of and had no issues!
Mjminino is offline   Reply With Quote
Old 06-20-2016, 05:57 AM   #30
Mjminino
oops... wrong years, my bad,
Old 06-20-2016, 07:42 AM   #31
projectking
No, your good it's up to '68.
Thanks,
Jon
67 Chevy C10 LWB
90 Mustang Gt
Old 10-11-2017, 04:14 PM   #32
70"guero"c10
Responding to this old post but is there any way to go around having to remove the radiator and everything else that is getting in the way of me inserting the bolt from the top of the core support? I have a 1970 c10. Thank you all for the support.
70"guero"c10 is offline   Reply With Quote
Old 10-11-2017, 05:16 PM   #33
pappy 2
Now I have an issue. I just went and checked the 67 parts truck I have for my 71 restoration. In checking the radiator mounts, they are "both" flush with the top of the frame. No, the vin tag no. and the frame numbers are not the same and there is the number 7--5--7 stamped into the pass. side frame below the frame ser. number. I am thinking I have a 71 cab on a 67 frame??
pappy 2 is offline   Reply With Quote
Old 10-11-2017, 05:48 PM   #34
weq92f
weq92f's Avatar
I just went through this recently with my '67.
I just went to Lowes to their fastener section and got all the parts necessary to duplicate the LMC page's front 67-68 core mounts ( including the thick rubber washers and everything else ).
I just slid the radiator to one side while I mounted the other side and then vice versa. Didn't have to do anything special and didn't need OEM parts.
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 10-11-2017, 06:59 PM   #35
In The Ten Ring
I got my set from a forum vendor, Classic Heartbeat. The owner answered all my questions each time I called. Fit has been excellent.
I am not quite finished with installing mine...as I had to loosen those to get the front end back on.
In The Ten Ring is offline   Reply With Quote
Old 12-01-2017, 03:11 AM   #36
crakarjax
crakarjax's Avatar
Hth,
-klb
I think those washers aren't going to last long, the factory rubber is fiber-impregnated. If you did find the right material though what was it called? All my hardware is fine, I just need new rubber.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
