Old 09-07-2009, 04:58 PM   #26
Chips-resto
Re: 1982 Chevy Crew Cab Build! Need Help
It's a 14 bolt
Chips-resto is offline   Reply With Quote
Old 09-07-2009, 05:07 PM   #27
nekkidhillbilly
both are 14 bolts cause both where offered
duallys usually had danas which where 73"s where as 14 bolts where 72
and cab and chassis where 70"
nekkidhillbilly is offline   Reply With Quote
Old 09-07-2009, 05:21 PM   #28
Chips-resto
Look at his opening pic, the main hub where your rim mounts is almost flush with the bedside. On my swd its in about two inches in which is about right with what you're saying. It makes alot of deference in how it looks. In the pic of crew cabs,there a silver daully that has only a small spash instead of the full dually fenders. That's what this swd axle looks like with dually rims. If I would have been at the shop today I could have given exact differance. Thanks for confirming what I found the hard way wen someone said they're the same.
Old 09-07-2009, 05:23 PM   #29
nekkidhillbilly
either though would work that little difference is small
Old 09-07-2009, 05:59 PM   #30
Chips-resto
from hub to hub,where the rim mounts, is about 66" on this 3500 8lug 14 bolt rear end. It's the factory rearend never change. Just went out and put the tape to it. Before I started looking for a dually rear I put 2" spacers on to get it closer in width. It's not the first item on this truck that doesn't make sence but Dad couldn't find the build sheet before he passed so I get to figure it out. Would love to hear from some others with a 87 3+3 4x4 8lug 3500 on the width of there rearend.
Old 09-07-2009, 07:53 PM   #31
74 C-30
Dually Pride
74 C-30's Avatar
the dual rear and single rear axles are 67" wms to wms, and the cab and chassis was 62" wms to wms. (wms is 'wheel mounting surface')
Chips-resto, If its a cab and chassis axle you have, you would DEFINITELY know by looking at it
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 09-07-2009, 09:16 PM   #32
paps69
First off I don't know any exact measurements but a dually pickup rearend IS DEFINITELY WIDER than a one ton SRW rearend. If you put a dished dually wheel on a SRW truck the wheel is going to hit the inner fender. A dually rearend has to be wider to get 4 ft between the wheel wells. I am currently changing a 77 K30 dually crew cab into a single wheel. If I put flat 8 lug wheels on the rear it tracks about 7 inches wider than the 78 3/4 ton 14 bolt I am putting in it.
IF A FELLA DOESN'T USE HIS HEAD.......
HE MIGHT AS WELL HAVE TWO BUTTS
1969 C10 LWB "Granpaps Truck" (Project)
2000 K3500 Crew Cab LWB (Farm Truck)
2007 Chevy 1500 Crew Cab 5.3 (Daily Driver)
paps69 is offline   Reply With Quote
Old 09-08-2009, 06:56 PM   #33
Chips-resto
Thank you! The 14ff in the truck is 67" wide. A dually is74'
Old 09-08-2009, 10:55 PM   #34
nekkidhillbilly
sorry i was wrong i was always told they where the same
Old 09-09-2009, 03:43 PM   #35
Daniellane
yeah. well the rear is dana 60 im pretty sure. i got srw running gear.. what all is the difference in the front besides spindles? anything else
Daniellane is offline   Reply With Quote
Old 09-09-2009, 06:01 PM   #36
aggie91
I'm just glad to be here!
aggie91's Avatar
A quick little search turned this up. To convert the front to a non-dually truck 1 ton, all you need to change is the ROTOR. Use RAYBESTOS Part # 5016R. This is the correct front rotor for a single rear wheel 1 ton truck. The spindle/caliper is the same between single and dual rear wheels.
The front is easier then doing a brake job...unless you decide to replace the pads in the calipers, then it would be the same amount of work to do a brake job if you remove the rotors so that they can be turned. To make short work of it, get the new rotors, new bearings and seals, pack the bearings and install the inner bearing and seal for both sides before even putting the truck up on jack stands. You could do the front in less then an hour if you plan ahead.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 09-09-2009, 06:24 PM   #37
pig rig
pig rig's Avatar
the rear end in the swr trucks are different then that of the drw trucks
the differance is the drums and axeles and the axel tube leanth I cant remember the massure ments off the top of my head but a c&c rear end will put the out side dual almost in line with the front wheel kind of in the same place as a srw rear end would set as where the pick up rear end will put the inside dual almost in line with the front wheel
on the front end the differance is the rotors
here's a little wright up I did on here and dually scene about the inter change of front end parts
http://duallyscene.com/forums/viewtopic.php?f=27&t=4359
its not the gosple but its what I've found out
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 09-09-2009, 06:34 PM   #38
Daniellane
yeah. well thanks alot.. ill get those and switch em. what about the back.
Old 03-29-2011, 08:32 PM   #39
haywirecanuck
I realize this thread is old, however the 14 bolt rear IS the same between srw and drw EXCEPT cab and chassis. the difference is the wheel mounting surface. do a search on pretty much any 4x4 forum, its somewhat easy to flip the hub around to run srw or vice versa.
source, experience
haywirecanuck is offline   Reply With Quote
Old 03-30-2011, 12:20 AM   #40
pig rig
pig rig's Avatar
the cab a chassy dual rear end is the same housing as that of a srw 14 bolt rear end the pickup dually has a wider rearend the differance between the swr and the c&c drw rear is the drums and I got that info from pirate4x4
