#26 |
Junior Member
Re: Buy a Wood Bed Kit or Make one
I think it is Walnut. He is on the board in the 67-72 trucks as Dads71
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! ![]() Last edited by ol Curt; 09-15-2009 at 03:11 PM. |
#27 |
Registerd User
I got Mar-k bed wood and hardware. No problems and it looks great. I'm at work so I can't post pics.
#28 |
[QUOTE=Dan in Pasadena;3518492]Thanks TR. From your pictures I would never have guessed "black deck stain". I love the depth of a thick clear coat, but I wonder if such would really last in the sun? Too many times I've seen it look cloudy and chipped around the edges.
MBGMike - Automotive clear OVER urethane? Can I ask why? Was this intentional or did you change your mind? Was the urethane applied with a spray gun? QUOTE] We spray all bed wood on customer trucks. We use a brush to do the edges. The finish was intentional. Actually we just read the Mar-K wood test and followed their instructions to apply. |
#29 |
Registerd User
Heres my Mar-k bed stuff.
#30 |
Rottenwood Garage Member
I will look at the can of stain..but it was some typw of boat deck black stain....about 4 coats with 4 coats of clear on top
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
#31 |
does someone have the specifications on the board widths and placement. I am going to make my own from Honduran Mahogany and purchase the stainless strips?
#32 | |
http://www.gmcpauls.com/47-72_BedWood_Info.htm and here: http://www.mar-k.com |
#33 |
I did my own bed wood on my 73 Stepside 30+ years ago. Only tools I used were a circular saw and a drill for the outer edges. It looked great.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#34 |
Does the Mar K wood kits come with hardware?
#35 |
Moderator
![]() Join Date: Dec 2012
#36 |
I chose to make mine and ues as many of the old parts as possible. All said and done I was able to make a bed for around $150.00. I did spend ablout 3 weekends and I owned a table saw and Dado blade, but all other parts are from big box hardware store. here is a before pic and after pic. The metal was all rattle canned finished after a clean up with wire wheel
Restoring America, one Chevy at a Time ![]() |
#37 |
Here are the supplies I used
#38 |
Here are some of the bed wood planks under construction
#39 |
A finished look for a daily driver.
#40 | |
Posted via Mobile Device |
#41 |
Hey just wanted to say the specs for the grooves on gmc Paul's website and classic heartbeat are not correct imo. The specs on mar-k's site matches the factory cut exactly and looks much better. I'm redoing half my bed wood I had done because they look like crap, this includes planeing down from 2" stock, fun.
Mar-k specs ![]() Gmcpauls or classicheartbeat specs ![]() Last edited by Baddflash; 06-01-2015 at 09:48 PM. Reason: Add images |
#42 |
![]() Join Date: Jun 2007
How about bed metal??? Should last the lifetime of the truck as long as it does not rust I guess. plan is to paint it tan and make it appear to be wood at first glance.
1966 427 biscayne with a 5 spd tremec on old school torque thrusts. 1972 Cheyenne Short Bed 1958 Apache short fleet 1980 Chevy short bed http://67-72chevytrucks.com/vboard/s...d.php?t=761005 1959 "Henry" http://67-72chevytrucks.com/vboard/s...d.php?t=670461 1966 Biscayne http://67-72chevytrucks.com/vboard/s...d.php?t=444419 1972 Suburban http://67-72chevytrucks.com/vboard/s...d.php?t=478828 |
#43 |
![]() Join Date: Jun 2006
CMAC, see if you can find an old timer who does woodgraining. They can make anything look like wood,
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
#44 |
I'm a fan of cutting your own bed wood, so you can step out of the box and be different.
Maple with purple hart and walnut inlay. |
#45 | |
![]() Join Date: Sep 2006
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#46 |
Moderator
#47 |
Sorry man but the specs are so different they both are not right, being that the specs from mar-k match the original 46year old wood that came out of my bed I would say they are the correct ones. How did you get bolts between the wood if there's no gap? Milled like that there's no room for expansion. The pieces when milled correctly will let the bolt fit between the boards without drilling or modifying and won't look like crap. Luckily you didn't use wood so it probably won't matter.
The specs from gmcpauls and classicheartbeat do not match the factory specs. Period. |
#48 |
Moderator
The bolts fit because the wood is moved apart when installed. I just dropped that trim piece on for the pic. Your pic clearly shows that the flange dimension that would be under the trim is way too wide. Double check your measurements. The pic doesn't lie. Period
![]() ![]() As you can see, GMCPauls dimensions work perfectly. I had zero fit issues. ![]() |
#49 |
Except for the huge gaps around the bed strips it looks good. I never said it wouldn't work or fit I simply said they were not correct.
No pretty sure these are to spec maybe varries a couple thousand or hundredths ![]() Changed pic because a digital caliper could be zeroed anywhere. Last edited by Baddflash; 06-02-2015 at 07:21 PM. Reason: Changed pic |
#50 |
The pic of the old bedwood has me wondering if anyone on here around the KC area has some aged bedwood they are removing. I am keeping all the original panina I can on my project which is a short bed step side but there was no original wood left when I got the truck. So I could probably make wood from any bed configuration fit mine.
