#26 |
67cheby
![]() Join Date: Sep 2008
Re: will cupping the upper bag mounts allow lca to lay flat against the crossmember
my front fenders arent on the truck right now , my tire is 29.1, i am still 1.5 off the ground
#27 |
...I cant believe I just welded my upper plates on my crossmember yesterday And NOW I read this...Wow..Sucks for me.
#28 |
low n' slo
![]() Join Date: Mar 2009
lol, seems like that always happens. is it the truck in your sig? its looks super low already...
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#29 | |
Redefining LowBudget
as it sits right now... are your LCA against the X member??? Mine are?? and that is as low as I can go with out working the fenders heater box and exhaust.....things you shoud think about.... maybe I'm missing something here???
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#30 |
67cheby
i have drop spindles and upper and lower strong arms and bolt on bag plates on the top ,but i am not on the ground, i am reworking the inner fenders, i do plan on running the factory ac box , i will probably just not be able to drive with it really low, i am taking my stock inner fenders welding wheel tubs into the top of them so they will still bolt in i am sure my wheel tubs will almost touch the heater box
#31 |
if you pm me your phone # I will snap a pic of what I have with just the cupped lowers on 235/75/15's ( 29.5" tall) then you will have an Idea of how much you can drop it (I have an AC truck) before you have problems or at least you'll know what to look forward to....I just looked and took some measurements it looks like a 2" drop spindle would put me into the AC box as well as the heater fan
PS: I have camera batties on the grocery list so maybe I can shoot some this evening for yea and post them |
#32 |
67cheby
i would love to see some pics thanks mike
http://67-72chevytrucks.com/vboard/s...d.php?t=554172 Last edited by 67cheby; 09-17-2009 at 11:34 AM. |
#33 |
pics sent call me if you want to discuss them ...hope you can post them
#34 |
67cheby
Thanks for all of the info and pics, that was exactly what i was looking for, i sell cars and had a customer come in , that is why i had to go Sorry, hopefuly you can post those pics later for others to see what i was looking for once again thank you
#35 |
67cheby
here is where i set now compared to inside of fender, wanting to go about another 1.5 inches, i am not worried about hood hinges i am in line to get a set of the ones PB is building so more cutting is in order, in the picture of the crossmember it looks like it is setting on the ground but it is not just a bad picture
http://67-72chevytrucks.com/vboard/s...d.php?t=554172 Last edited by 67cheby; 09-17-2009 at 12:40 PM. |
#36 |
but can you turn"??? I would rather run 1.5" off and be able to drive it??
#37 |
on a side note I wish spindle builders would set there tie rod end so they mounted from the bottom then the steering geometry would be better??
#38 |
67cheby
i am not as concerned about driving at full dump, i will be happy just to use it as a show stance
#39 |
Happy to be here
![]() Join Date: Mar 2000
Ok, PLEASE tell me what I am missing here.Is this not a picture of your LCA's laying on the ground? Is not the ground, the ground any more?
I am racking my brain trying to understand how you plan to go lower by cupping the arms. Unless you get the bottom of those arms raised up, you aren't going anywhere.
#40 |
67cheby
in the post before the pictures i stated that this is a bad picture it looks like it is on the ground but it is abou 1.5 inches off the ground, it does like it is on the ground but its just a bad picture
#41 |
Happy to be here
Sorry, I guess I missed that. It really looks like they are laying flat.
