Old 09-24-2009, 03:15 PM   #26
ol Curt
Junior Member
ol Curt's Avatar
Re: 70's style alternator in my 65
Jason,
Do you have power steering on there?
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 09-24-2009, 04:15 PM   #27
jason65
Registerd User
jason65's Avatar
No, but I lift weights. The other truck does but it's not pretty. You need pics?
jason65 is offline   Reply With Quote
Old 09-25-2009, 08:25 AM   #28
Shorty Cox
Here you go,
It is so easy. I did it to my '64, and i would think it would be just as easy on yours.
1.Take the regulator off and throw it as far as you can.
2. It should have had 4 wires connected to it.
3. Using a test light, locate the wire that is hot (12 volts)when the ignition switch is in the "run" position.
4. now, locate the wire that runs from the regulator position to the gen/alt position.
5. splice the wire located in number 3 above to the one located in number 4.
6. now you have a wire at the gen/alt location that is hot (12volts)with the key in the "run" position.
7. forget the other two wires at the regulator position.
8. Now remove the gen/alt and throw it as far as you can(probably can't throw it as far as you did the regulator!!)
9. Should be three wires going to the it. two small wires and one large wire. The large wire is connected to the battery and is hot (12 volts) all the time. (On some vehicles, it may connect to the battery via the horn relay)
10. Go to the parts house and purchase an alternator with an internal regulator and a new "pig tail" (the little thing that plugs onto the two terminals on the side and near the back of the alternator) they are numbered 1 & 2. the pig tail will have a small white wire and a large red wire. The new alternator will also have a large terminal(electrical connection) on the back. It will look like a screw sticking out with a nut on it.
11. Do what it takes to bolt the new alternator into the place of the gen/alt you removed and threw in step 8.
12. Once installed, plug the pig tail onto the terminals mentioned in step 10. attach the large wire from the battery (mentioned in step 9) and the red wire on the pig tail (mentioned in step 10) to the large terminal on the back of the alternator, tighten the nut.
13. Now attach the white wire on the pigtail to the wire identified in steps 4, 5, & 6.
14. Secure all left over wires.
15. Crank her up and you are good to go.
Amp meter should work also. If you have a idot light, i'm not sure.
Shorty
Shorty Cox is offline   Reply With Quote
Old 09-25-2009, 08:28 AM   #29
jason65
Registerd User
jason65's Avatar
The original light will work. Thats what mine is hooked to.
Old 09-25-2009, 09:16 AM   #30
ol Curt
Junior Member
ol Curt's Avatar
Originally Posted by Shorty Cox View Post
Here you go,
Shorty
I think item number 8 will be costly, as the core charge would have to be eaten!
Old 09-25-2009, 06:47 PM   #31
jason65
Registerd User
jason65's Avatar
It's worth the upgrade.
Old 09-29-2009, 11:37 AM   #32
1964C10
1964C10's Avatar
I am not sure but I think if you have a gauge then you need to add a resistor inline with the gauge other wise your alternator will either not work or you will fry it. It needs to see a resistance value, a light bulb is enough but not a gauge. That is if I read the above instructions correctly
1964 Fleetside LWB
1995 Yellow Mustang convertible
1996 Camaro Z28
My build thread
Looking for help on completing the Disc Brake Upgrade Reference Thread
If you didn't build it, you don't really own it
1964C10 is offline   Reply With Quote
Old 09-29-2009, 10:50 PM   #33
TR65
TR65's Avatar
Guys,
My gauge worked fine with no modifications after the alternator swap. The only change was that it didn't go negative at idle with the light on any more.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 09-30-2009, 12:05 AM   #34
1964C10
1964C10's Avatar
TR can you share some more info? I tried wiring up with my gauge and it did not work which is what I expected. I just connected it to the "Overdrive" light which was unused and it works fine now. I am only rehashing what I read when I did my swap but the way I understand it is that the energize wire comes from the lamp and goes to ground if the alternator is not running (or is broke) causing the idiot light to illuminate. Once the alternator starts to work it essentially puts 12+ volts on the energize wire making the light go out since there is no longer a ground. So I have no idea how I would hook that up to get the gauge to work. I am no electrician so details would be great!
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 09-30-2009, 11:24 PM   #35
TR65
TR65's Avatar
Hey 64C10,
The gauge is a voltmeter and measures the voltage at the horn relay. There should be a black/white wire that goes to the hot terminal on the horn relay. The other gauge wire goes to ground. So I didn't bother that with the alternator swap so it measures voltage just as before except the voltage is higher at idle, which was the objective. Hope that helps.
TR
1965 C10 SWB Fleet
Two owner
Old 09-30-2009, 11:58 PM   #36
fixit-p
fixit-p's Avatar
The 12SI bolts right in where the 10DN mounts the adjustment bolt is metric IIRC 8x1.5 mm and all you need is to add jumpers at the alt plug. Doing it this way puts the voltage sense wire at the main splice giving you more power where you need it. Madelectrical.com has listings for 12SI alts they can be had up to 94 amps.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 10-01-2009, 12:36 AM   #37
1964C10
1964C10's Avatar
Thanks guys!! My wiring harness was completely shot so I had to make my own meaning I cut alot of that stuff includind the horn relay since it and the horn button on the column no longer worked anyways. But I think I can figure it out from here.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
