#26 |
"Trucks with Class"
![]() Join Date: Jul 2000
Re: Aluminum Master Cyl Set with adjustable prop valve-cool!
Take a look at post #23 above---that package includes the matching alum prop valve, SS lines and SS/Chr bracket...and I know it all fits and works together...$160 +20 S/H. And that's a great price!
#27 |
That's what I'm looking for. I'm going to have to save a little more longer though. Thanks
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
#28 |
![]() Join Date: Jun 2010
Frank, do you still have the 1/2 ton setups? What are the prices?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
#29 | |
"Trucks with Class"
Thanks, Frank |
#30 |
nice. might need one in the future.
Doug Looking for a 67-72 short bed driver..... |
#31 |
VA72C10
![]() Join Date: Mar 2008
How much for a booster and aluminum master setup with the bracket/boot, and rod, but no lines or prop valve?
Booster needs to fit a 72 1/2ton BB or for just the booster, master, and boot (no bracket, prop, or lines.)
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#32 |
"Trucks with Class"
??? So you would make you own custom lines and use your own prop valve??? These are nice tested & coordinated packages...everything fits! and it is discounted in a package price. You won't save anything buying just part of the components and trying to fit it to your parts. Sorry, that just sounds like trouble when it doesn't work. I want you to be happy with the system and everything to work. Thanks for asking...Frank
#33 | |
VA72C10
I wanted an upgrade on the master and booster's performance but still appearing stock so I wanted to use the stock prop valve not that blocky one...
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 04-01-2011 at 11:27 PM. |
#34 |
do you have any of these master cylinders in operation without a booster? Wanting to use manual brakes with a aluminum master.
#35 |
"Trucks with Class"
They will work as a manual brake system without the power brake booster. You can buy either the adjustable set or all aluminum.
#36 |
If you are running the stock disc/drum brakes does the adjustable valve necessary? Or should I say make an improvement? Thanks, Nate
#37 |
"Trucks with Class"
The adjustable just gives you a little more to work with. If you have different front & rear pads, rotors, or other reasons that it may not brake evenly---the adjustable helps get it just like you want it. Normally the pre-set prop valve works great, but...IF...
#38 |
Still got a 11in 1/2 ton booster with the aluminum mc???
#39 |
"Trucks with Class"
Yes, still available and same prices. The only change is brackets are now powdercoated black.
#40 |
#41 |
#42 |
![]() Join Date: Oct 2014
I'll take the setup minus the brake booster
Ralph L. Jasper 69 4x4 Suburban PTO winch(NAVY) 13 GMC Ext cab 12 Ford Fusion SE(wife) ![]() MAI Interior shop |
#43 |
"Trucks with Class"
Yes, I do still have all of these brake packages available. I have had to go to a new manufacturer, to get these 9" DD boosters made for me. The new boosters are finished a little nicer, but take longer to get & cost a little more...not much, but a little.
I'll recheck current costs & upgrade this info. thanks, frank |
#44 |
![]() Join Date: Jun 2012
Has anyone used this set-up with the 9" booster and running a BB with tall valve covers. My cab is not on right now and it didn,t come with power brakes. Im using tall covers from Brodix. Thanks
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
#45 |
Still same price Frank?
#46 |
Still selling the alum mc and adjustable proportional valve setup and $$?
#47 |
"Trucks with Class"
I'll try to review the new components & prices in the near future. They keep changing and getting discontinued. thanks, frank
#48 |
Frank,
Will your master/ booster set work on 1970 3/4 ton with disc/ drum brakes? Thanks |
#49 |
Frank do you still have any of these components available.
Specifically the Aluminum MC and std prop valve. No booster required. Thx, Jeff.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
#50 |
"Trucks with Class"
I have three MC/Prop Sets available:
1. Alum MC with Alum Prop Valve Set: $160 + $20 S/H/INS. 2. Alum MC with Chrome Alum Prop Valve Set: $175 + $20 S/H/INS. 3. Alum MC with Chrome "Adjustable" Prop Valve Set: $200 + $20 S/H/INS. Last edited by PICKMUP; 08-18-2016 at 10:27 PM. Reason: new lower price |
