Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-01-2009, 04:39 PM   #26
team39763
Re: elec. fuel pump suggestions needed
Originally Posted by fryco View Post
and don't forget....
Wire it right, use relays, proper gauge wire, and fuses. Soldering and heat shrink are a good thing!!! do not hot wire to a 20amp toggle switch
(although, some people like fires)
i have a magnafuel 500, couldn't tell ya how it works or sounds, i never put fuel into yet... (this winter some time)
Where exactly should the fuse go for a fuel pump? I have a relay on mine and a 20amp toggle switch. Should the fuse be between the relay and the toggle switch?
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 10-01-2009, 04:52 PM   #27
djracer
djracer's Avatar
no. between battery power and the relay
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
