Old 12-24-2009, 08:15 PM   #26
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: dana 60
Originally Posted by b454rat View Post
The Stupid Duty's aren't as desirable as the older ones. They have unit bearings and balljoints that aren't as strong as kingpins. More expensive to go crossover. The centers are pretty much the same, still high pinion, but that's aboot it.
Ok, but I'm talking about the even bigger D60 that is used in the F450's and F550's. The axle tubes are bigger as well as the axles, and supposedly the ring and pinion are also bigger. I'm trying to locate one for a specific class in a pulling truck. It has to be 8 bolt pattern to be allowed in the class and this axle I think could be the strongest for what we want to do.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-24-2009, 09:11 PM   #27
2tons of fun
Re: dana 60
the shaft arent any bigger and they are over all just a blown up pooperduty axle. after dealing with the ford/dodge axles lately i can honestly say that they are giant turds with $$$$ parts. if you get an 8 lug its going to be a big 8.75" pattern not a small truck 170mm.
the unit bearings are now skirting 500 each and the vacume/auto hubs has got to be the stupidest thing i have ever seen put into production.
now they have a third bearing in them similar to a spindle bearing, but unlike a spindle bearing they turn when the truck is in 2wd!!!!! and at $75 if you now how to find them, ford wont sell them as a single, only with the 500 unit bearing.
the amount of stupid desinging that goes into the balljoint axles has made me a kingping man for life.
2tons of fun is offline   Reply With Quote
Old 12-24-2009, 09:27 PM   #28
mudmizer
mudmizer's Avatar
Re: dana 60
Hey guys the best place to find D60s in the military ton and a quarter is at www.gsaauctions.gov also lots of 2 1/2 ton trucks for axles.
I bought mine for $1065.00, drove it home (bootleg style) pulled the axles,tranny &t-case (T400-208) entire driveline. I used the 60 front, kept all the other parts for future projects and then sold the remainder of the truck with the diesel motor for $800 bucks. Extra work, but got my front 60 for a lot less than swap meet prices.
68 4x4, 454, 4 speed, disk brakes both ends,
Sold my 69 SS396 Elcamino when young & stupid
mudmizer is offline   Reply With Quote
Old 12-24-2009, 10:15 PM   #29
b454rat
Re: dana 60
I had a center out of a Superduty, Dana expert said F450/550, was a standard HP60 with 4.88 gears. Still was balljoint, might have had lockouts, dunno cause all I got was just the center and tubes, nothing else.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 12-25-2009, 05:33 PM   #30
BurnoutNova
BurnoutNova's Avatar
Re: dana 60
If I remember correctly when I used to work for a Ford dealer (about 3 years ago) The new at the time 450's and 550's did have lockouts. I know some of them had 19.5" rims also, so they might have had more than 8 lugs I can't remeber. Also, most Fords that are 8 lug don't have the same 8 lug pattern as chevy's and dodge. They are the metric 8 lug patter. Would that matter for your class?
BurnoutNova is offline   Reply With Quote
Old 12-30-2009, 06:01 PM   #31
Wildstreak
"something witty here"
Wildstreak's Avatar
Re: dana 60
I still have yet to call them and see, I got reluctant because of the price, but now I think I need a new front (Im pretty sure mine is seized Im just about to check on that)and I dont really want to rebuild this one and def dont want to buy another d44 unless it was a smoking deal. So I guess Ill start searching for the best deal, I get my dl back in a week so then I can drive to further locations
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 01-09-2010, 10:18 PM   #32
Wildstreak
Wildstreak's Avatar
Re: dana 60
they made a military blazer that had the d 60 in front right? I swore I had seen one and know its been awhile since Ive seen one. I might get one in the next couple months if they came with the d 60, otherwise Ill just get the k30. I got my drivers back this week and need a driver(since my project looks like it wont be done anytime soon) and figure I should just get a blazer or k30.
57 chevy 4x4
68 burb 2wd:
Old 01-10-2010, 01:55 AM   #33
70 beast
Certified Hobbiest
70 beast's Avatar
Re: dana 60
nope. if it does have a d60 it was put in afterwords. blazers only came with 1/2 ton axles.
(d44/12bolt or 10 bolts)
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 01-10-2010, 02:05 AM   #34
Wildstreak
Wildstreak's Avatar
Re: dana 60
damn, I was just hoping they did. Oh well maybe Ill just try and find a 69-72 blazer, I really wanted for quite some time now. or a nice later 80s k5 I miss my old rig.
57 chevy 4x4
68 burb 2wd:
Old 01-25-2010, 12:39 PM   #35
Greenlee
Greenlee's Avatar
Re: dana 60
I agree. Me and my buddy recently bought 2 of them. We paid almost the exact same price you did, however, from what I have seen they usually go for around $1,500 to $2,000 in good condition. If you have the means to go get the trucks and bring the home, this is the way to go. I only bought mine for the axles, but it turned out that both trucks run and drive. We ended up buying another one that doesn't run a few weeks later because I started feeling guilty about parting out a perfectly good truck.
Greenlee is offline   Reply With Quote
Old 01-25-2010, 04:24 PM   #36
Wildstreak
Wildstreak's Avatar
Re: dana 60
wow you guys got great deals, I tried looking at that site but didnt find anything. could be a bad search engine tho. I would prefer to do it like you guys suggest find a good k30 maybe two :P. but I cant find the price you guys do, I just did a search and cheapest I found was for 3500. how do yo know when these auctions are occurring?
57 chevy 4x4
68 burb 2wd:
Old 01-25-2010, 05:28 PM   #37
Greenlee
Greenlee's Avatar
Re: dana 60
I just noticed maybe he bought from a different site. We bought from Government Liquidation. It's an auction site. There are locations all over the country. We usually buy from the one in Lousiana because it's as close to us as the bases in Texas and you don't have to pay sales tax. My friend has probably bought 10 to 12 trucks (2-1/2 tons, 1 tons and Blazers) over the last four or five years. It's too far for us to go look at the trucks before hand. We just bid as if the truck will only be good for parts. Sometimes you get lucky. All I wanted was the axles and ended up with a decent truck that actually runs and drives pretty good. I bought some generators on this site that were complete garbage, so this truck kind of made up for getting ripped off the last time! As long as you can see that the truck still as the axles under it in the pictures, you probably can't go wrong.
Old 01-28-2010, 12:58 AM   #38
mudmizer
mudmizer's Avatar
Re: dana 60
I agree with Greenlee, It is usually the axles wer'e wanting. Just check the site every few days, you can shop by state or type of item.
Old 01-28-2010, 07:20 AM   #39
ghettoluxury
ghettoluxury's Avatar
Re: dana 60
Just picked up another D60 for $500 even got the matching gears for the 14 bolt with it
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 01-28-2010, 09:03 AM   #40
b454rat
Re: dana 60
I picked up a dually 60 at a yard here for $85 total, $20 to torch it out. Traded it for a crossmember and motor mounts to swap in a Cummins in my 89 CCSB.
Old 01-28-2010, 05:30 PM   #41
Dieselwrencher
Re: dana 60
Man that's cheap!
Ryan
Old 01-28-2010, 08:52 PM   #42
b454rat
Re: dana 60
Gotta love u-pull it yards. Get this tho, they wanted MORE for a t-case than the front axle. It was $125 I think for the t-case, and $65 or something like that for the axle.
Old 01-29-2010, 01:30 AM   #43
Dieselwrencher
Re: dana 60
That is crazy!
Ryan
