10-05-2009, 12:46 AM | #27 |
profeshinaly unimployed
Re: brake bleeding
huh
"having mud flaps is like asking for a smaller trophy" |
10-05-2009, 08:39 AM | #28 |
Re: brake bleeding
The star wheel he is referring to is in post #22. It's the adjuster in mid-picture(yellow). If there has been water inside the brake drum it could be rusted together. If so, take it out spray penatrent oil in the adjuster and try to break it loose with two pairs of vice grips. If you can't loosen it replace it.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
10-05-2009, 02:15 PM | #29 |
Badass
Re: brake bleeding
i had to do this with mine about 2 weeksago.take the star wheel out and put it in a vice. and get players and work its way out then get a wire bursh and clean the threads and put some grease on there and your good to go
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
10-05-2009, 05:32 PM | #30 |
Re: brake bleeding
I think Poke's on the right track adjusting the rears first. If they have a lot of travel, they will spring back when the bleeders are open in back, and suck air. I see no reason one can't use 4 bleeder bottles and hoses and bleed em all at once. I also don't like pumping the brakes rapidly, I think it makes bubbles in the fluid.
If the rotors are removable by removing the lug bolts, I agree with putting a few lug nuts back on to center the rotors. Sometimes you have to invert the nuts, sometimes you have to put a larger nut or washers under them to take up the space if the threads aren't long enough. Some of our trucks have a lot of loops in the lines after the master cylinder that tend to trap air. Stopping the 'ol truck lessens the time you spend in traffic court. |
10-06-2009, 08:56 AM | #31 | |
Re: brake bleeding
10-07-2009, 02:05 PM | #32 |
Re: brake bleeding
ok i adjusted both the back brakes and it made a good difrence but its still a little spongy
