#26 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: firewall hei dizzy recess
Sorry for the blurry pics.
It's in but tight. ![]() ![]() ![]()
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#27 | |
![]() . Right now I'm just trying to get back up and running. Maybe this summer, when I plan on lifting the cab off to do some underside work, maybe then I'll modify the bellhousing support and clutch linkage so as to move my perches forward to the other two holes: . ![]() . Thank you everyone for the help. ![]()
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 12-03-2010 at 09:28 PM. |
#28 | |
#29 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
One problem with moving the bellhousing crossmember forward, is that it will raise the crossmember as it comes forward. This is due to the upward angle of the frame in that area. This will change the angle of the engine, which in turn changes the angle of the trans output. This can cause driveshaft vibrations unless the pinion angle is adjusted accordingly.
Also I don't recall there being another set of holes in the frame to mount the bellhousing crossmember farther forward. That may be the case on the '67-'72 frames, but not on the '63-'66 frames.
#30 |
I would just use a small cap style HEI like the MSD Pro Billet. These units are pricey, but so is moving the engine and transmission forward. Take a look:
http://www.summitracing.com/parts/MSD-8360/ Another easy option is to just buy a MSD Ignition Box and install it with your original points distributor. These boxes turn your points into a low voltage switch for the box and allow for a strong series of sparks. I am using a 1969 points distributor with a MSD 6AL box in my truck and I have not touched the points since 1990 when I assembled the current engine. As you can tell, I am a big fan of MSD products. Here's an example of the 6A ignition box also: http://www.summitracing.com/parts/MSD-6200/ Good luck with your truck. Sincerely, Rick
RED RUMBLE 1963 C10 Chevy Truck Owned since 1984 ![]() |
#31 |
Redneck Hillbilly
Great info in here as always, bookmarking for reference later. Thanks fellas.
#32 |
Hey BugeyeV8 - what's this small HEI you mentioned? Never heard of a stock one. Still coil-in-cap? What's it come in?
Ralph |
#33 |
![]() Join Date: Aug 2009
#34 |
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#35 | |
#36 |
Or dare to be differant convert an old chevy stock dizzy, just have the old lobes milled down. and place the module underneath the dizzy...
http://mysite.ncnetwork.net/wgmumaw/...Conversion.htm
#37 | |
60-66 Nut
That's interesting.....I didn't know you could run a MSD box with a points distributor.
#38 |
![]() Join Date: Sep 2006
I just set the engine in my truck so I could run wires and such around the engine. I do not have my tranny mount in yet and the dist is about 1/4" from the firewall. I will gain more clearance when I put a mount in and this is with a BBC. I am using the Mallory HEI dist.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
