09-23-2012, 10:16 AM | #26 |
Re: LT1/4L60 SWAP into the 65
I used my stock tank and welded the fuel pump flange from a camaro in there, just so I could get one at a dealer if it failed on the road. I ran 3/8 for both , mainly because it comes in a 25' roll and I didn't want to buy 2 rolls.
09-23-2012, 11:15 AM | #27 |
I had thought of welding in a stock setup. Tank inc uses a Walbro pump that is pretty easy to get but the factory setup sounds better. Can get at any parts store. No fuel starvation problems with stock tank with no baffles? I could always install baffles. Thanks for all the info. How do I put my build thread in my ?
Sold the 63 and have a 68 now. 63 SWB C10 LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
09-23-2012, 08:23 PM | #28 | |
Thanks for the help. Posted via Mobile Device
09-23-2012, 09:13 PM | #29 |
http://www.hotrodlane.cc/flipper/flipcat2013.html#p=72
That is the fuel line kit you need. Then you have AN-6 fittings to adapt to the hard lines. DO not waste your time screwing around with finding a cheaper alternative. I have probably 800.00 in my fuel lines because I tried to do just that. |
09-23-2012, 09:50 PM | #30 | |
