Old 10-08-2009, 11:15 PM   #26
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: how to do a burnout?
On a stock auto, I would not recomend starting out in second... assuming have a trans that would actually start in second... older fords do this, and late model GM 4L60E... but even they will kick to first when you stomp it.
if you have a TH400, you'll want to go into second gear as soon as you can, right after the tires start spinning is best. A good burnout is murder to a tranny, and very easy to over rev causing stress to the engine's lower end.
Driveshafts and U joints are stressed pretty good too.
If you have an open diff, then it's not real good to do. If your speedo says 40, then that one tire is doing 80, and that is not good for the diff at all.
Motor mounts are tested too.
I was always tought a burnout is when you keep the vehicle in place and spin the tires, also called brake torque, brake stand, or power braking. A line lock makes it easy, but is not needed.
Just nailing it and going straight (or not straight) is just spinning the tires.
Doing it in a manual shift is the only one that is slightly hard... Left foot on the clutch to the floor, trans in first, right foot, heel on the brake and toe on the throttle. Rev enough to keep from stalling but don't over rev and blow the clutch or a U joint, in a fairly quick motion let out the clutch without stalling the engine.
if you are real good you can nail it into second without letting the tires stop.
It'll impress your friends.
unless you are at the strip, and on slicks, it's kinda pointless.
but fun.
Old 10-08-2009, 11:26 PM   #27
72lb4x4
"If your speedo says 40, then that one tire is doing 80..."
Huh!? By what logic have you come to this conclusion?
72lb4x4 is offline   Reply With Quote
Old 10-08-2009, 11:35 PM   #28
2tons of fun
by the logic of the open diff.
if you lock one tire down on the open diff the other will spin 2:1 bescause of the spider gears.
skinny down and hang your foot on the brake, dont jam it just keep it from taking off.
2tons of fun is offline   Reply With Quote
Old 10-08-2009, 11:46 PM   #29
Longhorn Man
thats how they work
not a conclusion, just a fact
Old 10-08-2009, 11:46 PM   #30
67ChevyRedneck
67ChevyRedneck's Avatar
Never been able to get my 2.2L/5spd S-10 to do one I kinda did one on wet pavement...
My truck has a "weak" 70's tree-fiddy in it and I can do burnouts easy. Brake stand and straight line just by nailing the gas. There's no weight over the butt.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-09-2009, 12:01 AM   #31
highperf4x4
Originally Posted by AusTx68 View Post
two words...big block
A true rolling burnout doesn't use the brakes at all. But you're going to need more than 290hp to get it done!
highperf4x4 is offline   Reply With Quote
Old 10-09-2009, 12:02 AM   #32
69halfton
69halfton's Avatar
thats funny. I HAVE to use the brakes to get my tires going. even with my stroker motor. if i just punch it off the line on a dry day, she hooks right up and takes off. makes me sad cuzz then it makes me feel like it doesn't have enough power to light em....
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 10-09-2009, 08:08 AM   #33
68Stepbed
68Stepbed's Avatar
69halfton, don't worry about it, cuz if you're spinnin', you ain't winnin'.
As far as burnouts being hard on parts, yes, it's hard on all drivetrain parts. If everything is all stock, something will eventually break. If you have built stuff, it will also eventually break. it will just take them longer. Amdy covered most of this pretty well. Brake stands aren't as hard on engines(unless over revving), but they will hash a tranny though. The tranny builds too much heat and fries the bands and clutches. It's hard on the u-joints. It just puts more pressure on them, especially just before the tires break loose. It's hard on the entire rearend assembly. It puts forces and strain against all the bearings, the gears, seals, clutches and plates(if applicable), and even the axles.
I don't recommend doing alot of just brake stands. I would say the tranny would be the first to go if it's not built with high friction stuff. Honestly though, dont worry about doing a few every now and then. These trucks are built pretty tough, the rearends will take alot of abuse, and the u-joints are actually kinda beefy. I've not broken any yet.
Your 290 hp engine will turn em over pretty easy, and it won't make enough torque to really murder any parts any time soon.
Go here to see a few videos. My black 68 stepper was doing that long on legger with the 260 hp crate engine. It's basically the same as yours, but with a smaller cam. Actually, the cam even had a wiped lobe when I did that.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 10-09-2009, 10:47 AM   #34
tim21391
tim21391's Avatar
at the drag races we did for a car show.. i just rolled up in drive.. hit the brakes and then hit the gas.. then when i took off the line i just punched gas and it spun the wheels that way... so doing one is very simple...
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 10-09-2009, 12:01 PM   #35
Jim_PA
Extended burnouts with a non-posi can be deadly to the differential.
Jim_PA is offline   Reply With Quote
Old 10-09-2009, 12:23 PM   #36
UltraBlue71
UltraBlue71's Avatar
Pull into the front yard of someone you really do not care for after a rain or the grass is damp. Then just floor it, even tired old worn out trucks can spin em on wet grass! And you cut really cool ruts for your viewing pleasure!
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 10-09-2009, 01:04 PM   #37
texanidiot25
Eat My Rust
texanidiot25's Avatar
This thread needs more burnouts.
texanidiot25 is offline   Reply With Quote
Old 10-09-2009, 03:40 PM   #38
americanmusc1e
americanmusc1e's Avatar
Originally Posted by UltraBlue71 View Post
Mine aways wants to hop, weird how some trucks really hook and some want to bounce, mines a manual tho, pozi too, maybe shes just a pooch....
I'm guessing you have a leaf-spring rear end???
'cause the trailing arms on a coil-spring truck don't usually hop, leaves will almost always hop.
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 10-09-2009, 03:41 PM   #39
americanmusc1e
when I fix this dang vibration in my truck, I'll give you 100' of a one-wheeled burnout with no holding the brake.
-- Josh
Old 10-09-2009, 03:47 PM   #40
texanidiot25
Eat My Rust
2nd gear posi burnouts across parking lots can attest to this!
Old 10-09-2009, 04:46 PM   #41
84_4x4
84_4x4's Avatar
i dont see why your having a problem i have a fairly stock 350 and can spin 2nd from a roll is your clutch any good
1971 c10 350ci long bed fleet side
84_4x4 is offline   Reply With Quote
Old 10-09-2009, 09:06 PM   #42
mikey531
mikey531's Avatar
My answer.. 4.10 - 4.56 rear end gear
mikey531 is offline   Reply With Quote
Old 10-09-2009, 10:46 PM   #43
Camper Power
Camper Power's Avatar
its wierd that my truck wont do any burnout on dry pavement, the only way it does is if the tires are wet or doing a donut. its leave sprung and does have somewhat tall tires but i've gotten other trucks with weaker engines to do burnouts with tires pretty close to the same size, its kinda embarrasing actually.
eh
1970 Chevy C20 daily driver
1975 GMC Jimmy 4x4 project
1966 GMC C10 Dad's project
Camper Power is offline   Reply With Quote
Old 10-09-2009, 11:26 PM   #44
69 longhorn
Just blip the throttle, & pop the clutch.....or let the clutch up easy.....then blip the throttle real hot rods DO have a clutch(old school, but hang on to your azz when you are pullin 6 gears in an old truck) crazy AL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 10-10-2009, 01:16 AM   #45
Beelzeburb
Devil's in the Details
Beelzeburb's Avatar
That may sound like a good idea, but just wait until you get stuck on someone's wet front lawn. I've seen it happen.
Try explaining your way out of that one.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread
Datsun 240Z, 510 2 door and an old Honda motorcycle
Beelzeburb is offline   Reply With Quote
Old 10-10-2009, 01:37 AM   #46
kgt
rollin 40 mph burnouts are the best...bbc's all the way...!!
kgt is offline   Reply With Quote
Old 10-10-2009, 02:23 AM   #47
texanidiot25
Eat My Rust
Your sig says intake and cam. What combo are you running? A single plane manifold and radical cam can make it a bit weak on the low end to brake them loose.
Old 10-10-2009, 09:18 AM   #48
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Put it in neutral, floor it, then slam it into drive...
You'll do a burnout, but if you keep doing that, you'll break an axle, or destroy your transmission.
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 10-10-2009, 10:12 AM   #49
prairewolf
... if you see flames in the rear wheelwells you are probably going to win the contest.
eat,work,spend,sleep,repeat.
prairewolf is offline   Reply With Quote
Old 10-10-2009, 10:39 AM   #50
ripdog28
ripdog28's Avatar
NAC593, IM me and ill drive to you(seeing how your just a short drive away) and ill be more then happy to show you how good your truck can do a burn out. Mine is not rnning yet, but i am hoping it can do it brake tqing.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
