#26 |
"THE GREEN GOBLIN"
Re: Big Block Headers
I am useing FlowTech Full-Length Headers with my 454BB and as you can see from the picture they do sit low just for now I have a set of summit Turbo mufflers so it can be driven, I will later be changing the Exhaust Systems.Heres a picture so you can see for yourself its not a good one but you can tell.. My drop is 2.5inch Spindles with 2inch Springs up front and 4inch drop Springs out back.... and forgot to mention I had no clearence problems with the frame rail, transmission crossmember or anything...
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 10-21-2009 at 05:59 AM. |
#27 |
Here is some images of the Hooker 2455 headers on my big block
#28 |
Are the 2455s round or square exhaust port, my heads have the round port?Would they still work with a sq port and sq gasket? Thanks Brian
#29 |
The tubes are round but the flange is a bit squared. not to much, it still has some roundness.
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() |
#30 |
![]() Join Date: Nov 2007
Thanks for posting the pics Ripdog. Since I'll be running these on my 4x4 with a lift, the drop below isn't a huge issue provided they clear my front driveshaft. The passenger side on the Hedman's I was running before hung waaaayyyy low. Looks like it's time to order a set of 2455's.
EDIT: I musta been really tired when I posted this...it was 1bagged67 that posted the pics. Thanks man. Last edited by AJs72K5; 10-24-2009 at 09:22 AM. |
#31 |
My 67 Stepside is running a Gen VI tall deck big block with a 4 in drop in front and 6 in in the rear. Sanderson BB2 headers ($325.00 if you don't have them ceramic coated) fit just fine. They do not interfere with the starter or the frame on either side but , as you can see from the photo, they did make me relocate the oil filter.
#32 |
I ordered hooker super comps, coated for my 68 c10 w/ a 454. when i get them in i will update, they have 2 inch tubes and 3.5 collectors...hopefully they fit nice,,,,
#33 | |
"THE GREEN GOBLIN"
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
