Old 01-17-2010, 04:13 PM   #26
munger
munger's Avatar
Re: 1973 Chevy 3/4 454 - 496 build + more
what was your gas mileage stock
munger is offline   Reply With Quote
Old 01-17-2010, 05:07 PM   #27
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Cool Re: 1973 Chevy 3/4 454 - 496 build + more
I'd guess at anywheres between 8-12 MPG ; depending on how hard my driving was.
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 02-06-2010, 12:20 PM   #28
RPOZ11
RPOZ11's Avatar
Originally Posted by RPOZ11 View Post
Here are 3 simple shots of the Thorley Tri-Y's being increased to 3" collectors.
I am going to have these "Jet Hot" type coated to look new again.
Looking at a 3" or a 2-1/2" pipe system with either an H or an X system incorporated into it.
Small steps.
Here is a quick pic of these being done.
Will post more pics later...
HO72 build :
2017 SS
Old 02-27-2010, 05:42 PM   #29
RPOZ11
RPOZ11's Avatar
2-27-2010 Update :
Got a problem with the headers.
Took a really close look at the finished results last week and found that the "collector rings" WARPED from the heating processes when these were replated as seen above.
Not sure why this happened but we had to take them back after fixing them back to straight.
Very Odd circumstance!
So, as I am awaiting the return of these, I took the 73 in to install the 3:21 ring and pinion gears and install the Eaton Limited Slip Posi unit that I bought.
Using new carrier bearings etc on the install.
The axle bearings turned out to be OK after inspection.
We get the truck back next weekend.
3-6-2010 update:
Supplier sent the wrong POSI UNIT!
1 more week until I get her back to do the exhaust!
( Why is my luck based upon delays??? )
HO72 build :
2017 SS
Old 03-21-2010, 01:07 PM   #30
RPOZ11
RPOZ11's Avatar
Angry Re: 1973 Chevy 3/4 454 - 496 build + more
Got my truck back last night.
Everything seemed OK, until........
I noticed this :
UUghhhhh
HO72 build :
2017 SS
Old 03-21-2010, 01:18 PM   #31
89muscletruck
89muscletruck's Avatar
ouch!
89muscletruck is offline   Reply With Quote
Old 03-27-2010, 12:54 AM   #32
RPOZ11
RPOZ11's Avatar
496 is Finally completed ; minus distributor, carb and new small parts.
The push rods arrived in the wrong length so we went bought another set.
Going to rebuild a later model Quadrajet and include an electric choke in the vacuum pod's place.
Probably bush the throttle shafts, tweak it up to handle the larger cubic inches, recolor it and adjust it after breakin.
Small list of stuff to target now:
Radiator
New motor mounts
Belts
Aluminum water pump
Hoses
Starter
Temp Gauges
Misc other things
Hope we start the R & R in 3 weeks.
HO72 build :
2017 SS
Old 04-04-2010, 02:40 PM   #33
RPOZ11
RPOZ11's Avatar
Picked up my motor yesterday.
(valve covers are on backwards only for the purpose of sealing it up and for transport-FYI)
Man, this is getting expensive!
Dropped it off over at my friend's shop, where we will be doing the swap at.
Next door they have a DYNO.
It was optioned to me to break this thing in on the DYNO and tweak it for power.
Gotta think about this.
The camshaft was off on the dial in. We ended up advancing it 3*. The duration was bumped up a little on this cam to adjust for the extra cubic inches.
Took a core QuadraJet with the electronic choke in for rebuild. Do it up all new, bush the shafts, etc etc.
Also took in a DAVIS "DUI" HEI I had that was used on a prior 454 I had and will reset the advance to match up with this 496. I think that one was originally set up a 22* @ 3400 RPM's.
So, next I have to steal some pulley's, A/C brackets, and more form a core 73 454 I have lying over here, and start assembling the front of the motor.
Im just fortunate to have a spare motor and parts truck to take from while I still drive the truck before we start the swap.
Gonna purchase some Urethane motor/trans mounts.
Slow movin' but progress is being made.
HO72 build :
2017 SS
Old 04-04-2010, 02:47 PM   #34
RPOZ11
RPOZ11's Avatar
Originally Posted by 77BBGMC View Post
I'm going to be building a stroked BBC as well. I have the block and a good set of 781 heads, now I'm in the process of saving some $$ for the build. Out of curiosity what cam are you going with?
Camshaft #'s request.
I need to get the cam card for this as we had this camshaft made specifically for this application.
I dont think it is too much different than the available cams out but they did add more duration on the intake side to support the larger displacement.
I have to get that card as we need it to dial in the QuadraJet & HEI unit I have.
Ill get back to you on this!
HO72 build :
2017 SS
Old 04-05-2010, 01:17 PM   #35
BillyBlaze
schweet!
BillyBlaze is offline   Reply With Quote
Old 04-05-2010, 01:20 PM   #36
West Texas Z
El Mero Mero Frijolero!!
West Texas Z's Avatar
looking good!
West Texas Z is offline   Reply With Quote
Old 04-10-2010, 09:28 PM   #37
RPOZ11
RPOZ11's Avatar
Took off some small parts for assembly onto the new 496.
Everything will be bead blasted and repainted then reinstalled.
A/C Unit + Bracketry:
HO72 build :
2017 SS
Old 04-10-2010, 09:29 PM   #38
RPOZ11
RPOZ11's Avatar
Alternator Assembly :
HO72 build :
2017 SS
Old 04-10-2010, 09:29 PM   #39
RPOZ11
RPOZ11's Avatar
Power Steering Unit assembly :
HO72 build :
2017 SS
Old 04-10-2010, 09:30 PM   #40
RPOZ11
RPOZ11's Avatar
Fan & Clutch assembly :
( Going to look for a replacement clutch for this )
HO72 build :
2017 SS
Old 04-10-2010, 09:32 PM   #41
RPOZ11
RPOZ11's Avatar
Carb, Trans Dipstick tube & housing, Vacuum Modulator line & fitting, carb to brake booster vacuum line and fittings, & misc...
NOTE : This carb I had from this 73 GMC 454 motor, the carb was a 7043207; and I was told a 7043507 was correct for a smog setup in Calif.
HO72 build :
2017 SS
Old 04-10-2010, 09:34 PM   #42
RPOZ11
RPOZ11's Avatar
Thermostadt Housing (cast iron) & Engine Lift Brackets...
The one small port water hose fitting: should I drill it out for more flow???
HO72 build :
2017 SS
Old 04-10-2010, 09:35 PM   #43
RPOZ11
RPOZ11's Avatar
Battery Cable hold down bracket...
HO72 build :
2017 SS
Old 04-10-2010, 09:36 PM   #44
RPOZ11
RPOZ11's Avatar
What is this bracket used for???
I cant remember???
Alternator wiring harness to alternator?
HO72 build :
2017 SS
Old 04-11-2010, 01:35 AM   #45
RPOZ11
RPOZ11's Avatar
Also, I posted a wanted ad but havent gotten any results so I am going to add it to my build thread here in hopes someone might have what I need here:
http://67-72chevytrucks.com/vboard/c...ct=3767&cat=19
I need the Bracket and a correct GM used working EGR unit for my 73 Chevy truck.
looks like the one in this picture below:
OR, If you have the very same intake with the EGR that I need as shown, PM me as I might take it.
TTT
Anyone got one of these setups???
I am still looking for this EGR and bracket + bolt factorty setup.
HELP....
HO72 build :
2017 SS
Old 04-11-2010, 08:45 AM   #46
Desert1957
Desert1957's Avatar
FYI -Just thought I would mention , while looking at your carburetor picture I noticed the base gaskets is severly burned up. On some of these early Big Block motors there is a separate steel shim that goes between the intake and the gasket to prevent this burning. Any good parts place should have a listing. If you can't find a part number I might have a listing.
Desert
Desert1957 is offline   Reply With Quote
Old 04-11-2010, 01:32 PM   #47
RPOZ11
RPOZ11's Avatar
Ah yes, I do recall using those shims before.
I tore these parts from the 73 GMC parts truck/motor I have.
To make things a bit easier on the reinstall, I am swapping from this GMC 454 motor the necessary parts to install onto the new 496.
Aiming for a more trouble free install.
This particular original carb I will not be using.
We are going with a later 70's to 81 style where the vacuum choke piece is and install an electric choke. Sooo much easier in the morning and for cold starts.
At that pointe, that is when we will select the proper gaskets for this.
We did install an Edelbrock 2.0 Performer intake, with the EGR provision, with oval intake ports to match the 781 heads.
HO72 build :
2017 SS
Old 01-23-2014, 07:43 PM   #48
TheBlueBomber
TheBlueBomber's Avatar
Any updates since 2010?
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
