#26 |
Under Construction
Re: Some Assembly Required / build #2
good progress bro!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#28 |
mini truck racer
I have been doing a little work on the truck , but my maiin goal this week was to finish my disc brake conversion/fornt end rebuild on the Camaro . This had my lawn mower trapped in and i just don't like the car not being moveable as i have very limited space to work in . It came out good , but there are buckets in the subframe that the front springs have to set in . What a pain .
I did get the final coats of paint on the chassis and i am happy with it . I also painted the motor stands and trans crossmember and replaced the shocks . I am currently finishing up the brake lines and Emergency brake cables . I'll post a picture later . Had a guy come over yesterday to look at the Blue truck . Told him id give him the frame for $450 . He is right down the street from me and is converting a LWB to SWB . He wants to pick it up Mon. or Tues. Im trying to coordinate that with the purchase of my newest donor . Thinking more and more about buying repop short fleet sides and making a short fleet bed .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 11-19-2009 at 10:54 AM. |
#29 |
I need to just come get that 68 camaro out of your way so you can get some work done on the truck!
#30 |
Under Construction
I was thinking the same thing....
#31 | |
Under Construction
Newest donor...? did you get the stepper from Matt/ Lee ?
#32 | ||
mini truck racer
I haven't got with them about that truck yet . If this one works out ill take it due to location and options . Now if it were the Z id be all over it .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
#33 | |
Texas Big Wig
![]() Keep dreaming on my Z... Last edited by Spray-Bomb; 11-20-2009 at 01:40 AM. |
#34 |
LOL! Sounds like I need to come to Baytown and speak to the Mrs before you get home. She may just let me clean up!!!!
#35 | |
Under Construction
sounds like a nice score!
#36 |
mini truck racer
Well guys wanted to bump this . Been workin 72 hr weeks now for almost a month . Haven't had any time to work on it at all . I will be going on nights starting tommorow so i'll get something done if it stops raining . Haven't had time to get the chassis to the new owner or pick up the new donor truck . I'll get an update soon . I start vacation saterday morning .
#37 |
mini truck racer
Well the weather and work have not been cooperating , but i finally locked this deal down . I bought a 67' CST that is a hard loaded 3/4 ton . Truck was from west Texas and ended up in beamont , Texas in a garage for around 10 years then where you see it for around 5 . The cab is in really good shape minus the outer rockers . Sorry for the crappy picture , more to come .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 12-08-2009 at 09:48 AM. |
#38 |
Tot Roddin'
Subscribed to this build, best of luck with it!
The '67 looks to be pretty nice.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#39 |
Under Construction
nice score Raland...
#40 |
Still Learning
Will be watching it come together. Nice score on the 3/4 ton.
#41 |
![]() Join Date: Jul 2009
good deal im starting to think i should buy a better cab as well before i start workin on the one i have
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
#42 |
mini truck racer
Thanks guys , i still have some work to do on the blue truck to finish parting it out , but im getting close . This truck is complete and almost unmolested . It has the brush gaurd on the front and it is solid , not tubing . Someone welded a peice of plate in the bed over the wood flor that will become a work bench in my garage . The bed should give me everything except the sides to build a short fleet . Best of all Bucket buddies . 327/th400 eaton axle . power assist steering . Got a busy day , ill check back later .
#43 |
mini truck racer
#45 |
mini truck racer
Yea i know , but this truck turned up les than 3 miles from my house and the price was right , just had to close the deal . Anyway here are some better pictures .
![]() ![]() ![]() ![]() ![]() All in all a very clean truck . Needs just outer rocker which i have . Tommorow i paln to put a hot battery in it and fire it off . We'll see how that goes .
#46 |
VA72C10
![]() Join Date: Mar 2008
Just making sure you know that speed warning is worth a pretty penny before you go hacking that off... figure you do but didn't want you to miss out...I've had people tell me they threw out the ratty buckets and look on the spid and they were buddy buckets...
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 12-10-2009 at 08:41 PM. |
#47 |
mini truck racer
Yea i knew about the buckets . One of the reasons it took a little while was we had to get to the buckets they weren't in the truck . He didn't want them to get weathered . The speed warning dash was a extra bonus i hadn't noticed till today . I don't know how it works , but it's cool . I am glad i ended up with this old truck . I almost hate to move it to the half tomn chassis . Im going to do the CLR trick on the rust and assemble it with what i have . The main goal it to drive it . Paint can come later . I figured someone would catch all that , just not the first post .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 12-10-2009 at 09:36 PM. |
#48 |
Under Construction
yep that was a score Raland, Congrats.. buddies, and speed warning woohoo.....
#49 |
mini truck racer
3892657 327 ci 210 hp 4 barrel wcfb . Tried cranking it today . The carb was bad and the spring was broke on the points . Found a new set of points in the bag on the intake . Threw those in and put the 650 Demon off my Camaro on it with a hot battery and a Holley blue pump and regulator pulling from a 2 gallon gas can . It fired right up and doesn't even smoke to bad for sitting 10 years . Prolly gonna do a carb rebuild and fuel pump replacement before dis assembly .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 12-11-2009 at 04:33 PM. |
#50 |
Under Construction
Nice.....
