Old 10-23-2009, 06:17 PM   #26
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Fuel milage
My comments were based on everything being in a truck and about a truck. Why would I care what a firebird with the same engine got? I'd assume that for the sake of common sense we were talking about the fuel mileage of a truck.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-23-2009, 06:18 PM   #27
project 67 sub
project 67 sub's Avatar
Re: Fuel milage
dont understand exactly how but im averaging about 17.5 miles to the gallon on the freeway doing about 65 in my burb, and 6.5 around town driving like an old lady
project 67 sub is offline   Reply With Quote
Old 10-23-2009, 07:26 PM   #28
big mike71
big mike71's Avatar
Re: Fuel milage
I get 8 mpg, If I was worried about fuel mileage I would buy an S10.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 10-23-2009, 08:52 PM   #29
CSGAS
optomistic ah-so
CSGAS's Avatar
Re: Fuel milage
For around town traffic, stop and g stuff the biggest impact on your fuel mileage will be weight, especially rotating weight.
Lighter wheels, or wheel and tire combinations, along with regular lightening tricks will help. If you were doing long freeway runs, with open roads and little to no traffic, you would want nearly the opposite--heavier rotating mass would carry your momentum allowing you to coast more.
The Q-jet, or another spreadbore carb, gets another nod from me. So does the Multi-spark ignition, you can get boxes for as little as $175 new that may not be drag strip heroes but improve cold-starting as well (even with points).
Choosing a trans that matches your torque peak to the speeds you drive most also helps in traffic in particular. Since you already have a 3.08, I'm thinking a 5-speed or at least a 4-speed so you get gears you can use stoplight to stoplight. If you have to have an automatic, the lower rotating mass gives the nod to a TH-350. If you want an overdrive tranny you'll never use the OD unless you change to 4ish gears.
I always found about 62 MPH to be the speed (American) that I could get the best gas mileage. There seems to be a balance there between mechanical resistance and where air resistance takes over.
To improve aerodynamics, make sure the window frames line up with the door jambs tightly (roll down windows while adjusting this), close up body gaps and hood edges. Seal whatever you can. If you can hear a whistling noise, that's air passing through a restrictive opening, fighting your truck and slowing it down.
When you are ready to spend a couple dollars, converting to a truck/RV profile hydraulic roller cam or engine should be less expensive with more satisfying results than TPI.
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 10-23-2009, 09:26 PM   #30
cparman
sharp as a marble
Re: Fuel milage
My circle is very small, but on occasion I will drive to " TOWN" I would rather get 12 MPG, in my 69, than get 17 in a new Chevy Truck. Any of you guys get " the look " when you drive your 2006? Any of US get the look when we drive our 68-72 Damn right! I love my old truck!
cparman is offline   Reply With Quote
