10-29-2009, 05:25 PM | #26 |
Re: Gas Tank Relocation
Thanks Putter. I might have to get those directions again, and thanks for the offer on lifting the cab. I'm gonna hold off on my request for favors as long as I possibly can. I'm sure there'll come a time when I need some and I don't want to use them up too quickly.
Baby John & Tyler Shows My son and I are resto-rodding a '72 GMC Stepside |
02-17-2010, 06:56 PM | #27 | |
Still plays with trucks
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
02-17-2010, 07:14 PM | #28 |
Not the most elegant but with a tonneau cover no one sees it and it's out of the way... just drop the tailgate, don't have to mess with the cover.
02-17-2010, 07:17 PM | #29 |
I dnt mean to Highjack your tread but has anyone used this Fuel Cell from Jegs? 15382 - JEGS Pro-Street Fuel Cells
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
02-17-2010, 07:37 PM | #30 |
Grandpa in the rustmobile...
I'm thinking of grafting a newer model filler door into my bedside. Would it be easier to use the side marker filler (no bodywork)? What type hinge are you guys using for the side marker? What type of vehicle/year was it? Thanks!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
02-17-2010, 07:39 PM | #31 |
95 to 2002 S-10 Blazer filler neck and fuel door.
02-17-2010, 08:56 PM | #32 |
filler neck adapts to 67-72 blazer tank?! Why filler neck? Thanks im trying to learn everything, my tank comes in friday! Im excited!!! Love the big brown truck!
02-17-2010, 11:16 PM | #33 |
No chance for sparks from lights on the side marker and tailight fillers? I would hate to start a fire.
02-18-2010, 12:09 PM | #34 | |
The only good thing is that unless you are filling the tank with your lights on the lamp circuit will not have power when you have the filler cap off. Definitely secure the wires well to the gas door and wrap them with tape and wire loom where they come anywhere near the cut out in the fender just to be safe.
02-18-2010, 04:32 PM | #35 | |
ROTFLMAO! It is a pretty truck, but as your tagline sez...it's a bit like putting lipstick on a pig. Sure, it still looks like a truck but do you actually think that truck will ever see anything on that bed floor???? There is absolutely nothing about that truck that is in any way practical...unless you use it to wake the neighbors....or just show off! |
02-18-2010, 05:08 PM | #36 |
I like the look of the side marker light fill but my hands are too big to reach in and take the cap off.When I was building mine I did alot of measuring and ended up with the S-10 fuel door. I know it's not original and it is in a F#*d location but it's easy to fill and I'm not worried about scratching the paint with the nozzle trying to fill thru that small hole.
02-18-2010, 07:48 PM | #37 |
Nice I likey!
What would a shot charge to weld in the filler door? and do the bodywork lets say for it. have a welder but need gas for it and dunno how to weld guess i should leearn.
08-20-2012, 01:04 PM | #38 |
Want to do with my 72, Can I get some pointers to what all you did to get a great look.
08-20-2012, 01:32 PM | #39 |
Baby John,
I recently installed a new rear mounted fuel tank on my 72 C10. I used the fuel tank out of a 69 Camaro. I did the drop down license plate and it works great. I used the filler tube and grommet from the original tank to finish it out. I have included a link to a recently post - along the same lines, we took the original fuel tank (behind the seat) and made a speaker box out of it and it bolted up perfectly. Please PM if you have additional questions. http://67-72chevytrucks.com/vboard/s...d.php?t=522264 Good Luck, KellerMac
Texas - Don't Let The Size Scare You! |
01-31-2014, 12:32 AM | #40 |
Any info to share on how to convert your rear taillight to a 1956 Chevy-style tilt-down rear taillight to access the gas tank filler?
01-31-2014, 12:33 AM | #41 |
01-31-2014, 02:26 PM | #42 | |
the boat guy
The only possible advantage of a kit is that the fuel door would be cut already.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
01-31-2014, 05:11 PM | #43 |
kool
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
02-03-2014, 02:04 PM | #44 |
Thats the way I did mine also. I had an exhaust shop bend a piece of pipe for under $20 and welded the vent into. I unsoldered the stock valve piece (under the gas cap) and had the new pipe swedged for it. The tank fills wide open now but does have a tendancy to burp when the pump cuts off. I looked into the marker light setup on the fleet side and figured out there was not enough room without modding the inside of the box. Eventually I will make an enclosure so the filer looks almost factory on the inside. I really like the 31 gallon tank and extra traction.
09-21-2015, 12:55 AM | #45 |
09-21-2015, 07:31 PM | #46 |
09-21-2015, 10:11 PM | #47 |
Classic trucks website has a good article on installing a camaro fuel tank
09-21-2015, 10:53 PM | #48 |
Here is my 02 camaro tank !
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
02-10-2016, 03:21 PM | #49 |
Looking for some help, Have a 1967 Chev C10 LWB fleetside, will be installing an aluminum tank and would like fill behind brake light. Any information/pictures would be greatly appreciated.
02-10-2016, 04:20 PM | #50 |
I'm seeing all of these tank installs and they are all pretty sweet. Has anyone else done the LMC top fill tank? I just did one a few months ago and was pretty happy with it. The only problem I have is the straps that came with the kit seemed to be to short. What are you all running for mounting kits?
