06-07-2010, 12:19 PM | #26 |
Re: Oil Leak on New crate motor
I also have 2 leaks on my 330hp crate motor. One in the front, one in the rear. Why so many crate motors that leak? I need to diag mine still
06-07-2010, 05:04 PM | #27 |
06-07-2010, 07:41 PM | #28 |
Haha true. My 86 305 has less leaks @ 130k miles than my crate motor does at 10k miles.
09-06-2010, 11:42 PM | #29 | |
09-07-2010, 01:29 AM | #30 |
Gone to greener pastures
Well (& I'm not being a smart azz here), if worse comes to worse, install another dipstick tube & dipstick.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
08-12-2013, 08:39 PM | #31 | |
Posted via Mobile Device |
08-12-2013, 08:59 PM | #32 |
08-12-2013, 10:54 PM | #33 |
The Goodwrench engines come with new valve covers & new oil pan. The plug for the extra dipstick hole is provided with the engine.
I have put hundreds of these engines in & any oil leaks have been installer faults. |
10-18-2013, 07:08 PM | #34 |
Yep. Even though I had never done it before, I installed my crate 350 without much problem. Fortunately, I looked at the passenger side dip stick hole and realized something was missing. I looked in the bag that the warranty was in, and there was the plug I needed. Tapped it in and haven't had any problem there. Of course, I have other leaks, which is why I'm reading this thread.
10-19-2013, 08:12 AM | #35 | |
i had the same problem with a old 2 barrel carb i got from a parts house one time, bolted it on and the gaskets where dried out from sitting on the shelf for so long that the thing leaked like a sieve when i fired it up, had to take it apart and replace the gaskets
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
05-01-2017, 10:14 PM | #36 |
Not sure how old this thread is, but still giving solid advice.
I too have a new 350 crate motor that has that same mysterious oil leak around the starter, and after checking everything I could think of, I finally noticed a tiny bit of oil on the recently washed off area, and lo and behold...there is that hole in the block for (I assume) a right or left hand dipstick, and as mentioned before, it just splashes enough to keep everything lubricated well...NOW HOW DO I GET TO THAT SPOT AND WHAT WILL FIT IN THAT HOLE? |
05-02-2017, 01:58 AM | #37 | |
05-02-2017, 08:58 AM | #38 |
I am actually thinking of just getting another dipstick, that hole is deep behind headers, starter and not easily accessible, I just do not see to reach it without removing the starter
I feel bad, been chasing this leak for about the 600 mile life of this engine and just now discovering this |
