Old 11-15-2009, 06:44 PM   #26
Scootin 81 C20
3/4 Ton Rodder
Scootin 81 C20's Avatar
Re: Ole Rusty-86 3/4 4WD
Nice work. I wish I was lucky enough to have a 4x4.
He doesn't make us look bad, he just makes us look slower than he is. LOL.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD
1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy.
Scootin 81 C20 is offline   Reply With Quote
Old 11-15-2009, 11:12 PM   #27
GMC91
Always trouble
GMC91's Avatar
LOL thanks for the comments, how many 16-17 year olds are on this site?
91 Silverado Regular cab, 2wd, swb-project truck
97 Silverado Extended cab, 2wd, swb-driver
GMC91 is offline   Reply With Quote
Old 11-15-2009, 11:45 PM   #28
Scootin 81 C20
3/4 Ton Rodder
Well, we are three. I am until next month, then I'm 18.
Old 11-16-2009, 09:53 PM   #29
GMC91
Always trouble
GMC91's Avatar
I got 2 questions here.
The first: Is this bar suppose to be bent like it is or do I need a new one?
The second:How do I get the hub or what ever its called off?
Old 11-17-2009, 08:44 PM   #30
GMC91
Always trouble
GMC91's Avatar
Ok since that didnt get any replies, what all can I take off the front axle that wont cost me hundreds of dollars to put back on. Im trying to make a sorta show truck outta this thing so I dont want any rust on it. And I know next to nothing about axles and what not. I bought me some chassis saver and what not, trying to clean this front end up for paint.
Edit:Everthing that has a rubber seal, like the tierods and what not, can I jsut buy new boots or do I have to replace that whole thing?
Old 11-17-2009, 08:59 PM   #31
68Timber
I know the pieces fit
68Timber's Avatar
I don't know much of anything about front steering gear, but that is the front tie rod and it needs to be replaced. Bent = trash pile. As far as removing it, I think the tool is called a pickle-fork, but you're really into territory where you need a very good shop manual. Not that you won't get help here, but a good shop manual is a must.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 11-17-2009, 09:04 PM   #32
GMC91
Always trouble
GMC91's Avatar
Where can I find one and how much will it cost?
Old 11-17-2009, 09:10 PM   #33
68Timber
68Timber's Avatar
Originally Posted by GMC91 View Post
Is this normal? I took the front axle out and on the brackets that are welded to the axle that bolt it to the leaf springs one hole is bigger than the other. Here is a pic if the bracket next to the pumpkin
Here is the other one on the drivers side
Is this normal?
I meant to reply to this earlier. It's not normal. At least not that I've ever heard of, but Chevy has done stranger things. They appear to be mismatched spring perches. Which would make me wonder why it was done, but unless you know the previous owner you'll never know the rest of the story - Paul Harvey is dead. But as long as it was done well, don't worry. Check the welds. If they look good, don't sweat it.
John
74 Honda Z50 build
Old 11-17-2009, 09:11 PM   #34
68Timber
68Timber's Avatar
Try the dealership first. Last time I bought one new it was under $100 for a 3/4 ton tie rod.
John
74 Honda Z50 build
Old 11-17-2009, 09:17 PM   #35
bitchin85
bitchin85's Avatar
im 16
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 11-17-2009, 09:29 PM   #36
64swb
64swb's Avatar
that is what the spring perches are supposed to look like, the driver's side mount has a larger/slightly irregular shaped hole.
1978 Chevy C10, 1986 Chevy K20 'Burb, 1970 Chevelle, 1996 K2500 'Burb, 1977 Chevy K10, 1970 Ford F-250, 72 Ford F100 4x4, 1979 Chevy C30, 1982 Chevy C30, 1996 Chevy Dually 4x4 SAS, 1997 Chevy Tahoe, 1991 Ford F-350 cclb dually 4x4
64swb is offline   Reply With Quote
Old 11-17-2009, 09:39 PM   #37
GMC91
Always trouble
GMC91's Avatar
I looked up the diagram for the front end, the bar thats bent is just the adjustment sleeve, its under $50 outta autozone. So now Im trying to take my tie rods out of it. Wat a PITA. New tie-rods are like $20 a peice. The internet does wanders. Thanks for all the replies.
Old 11-17-2009, 10:07 PM   #38
GMC91
Always trouble
GMC91's Avatar
Everytime I look the part up and I find it, I can only find one for a 4:10 gear ratio. Is that going to matter? OR am I just screwed till I do go to a dealership?
Old 11-18-2009, 12:24 AM   #39
Greenlee
Greenlee's Avatar
Gearing doesn't have anything to do with the steering parts.
You can rent the pickle fork at Autozone for cheap.
Nice work so far on the truck!
Greenlee is offline   Reply With Quote
Old 11-19-2009, 06:01 PM   #40
GMC91
Always trouble
GMC91's Avatar
Well I hope that the parts house carries the part cause I just got back from the dealership and they no longer carry it.
Old 11-19-2009, 06:26 PM   #41
74 C-30
Dually Pride
74 C-30's Avatar
well i turned 18 today so now you make an 18 year old look bad
as for your hub, dana 44? if so then you need to take off the locking hub (6-8 long skinny screws) then take that mess out inside (internal snap rings and a big goofy retaining nut that you can take off with a screwdriver and hammer if you dont have the special socket...ask me how i know...) then the hub should slide off. at least thats how it was on a TTB Ford dana 44
oh and all the steering parts are available at NAPA, autozone, advance, VIP, hell i bet you could get them through walmart
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 11-19-2009, 10:10 PM   #42
GMC91
Always trouble
GMC91's Avatar
OK well I got the first snap ring off, the little one on the inside of the hub, now what else and in what order to I need to take out?
Old 11-21-2009, 06:52 PM   #43
GMC91
Always trouble
GMC91's Avatar
Well since Im at a stand still, no money to buy parts, I decided it was time for some cleaning. So I moved everything out of my side of the garage and cleaned it, presure washed the concrete, then moved stuff back in. Now I can walk with out stepping on stuff lol.
Well anywho, got bored so I took some pics with my phone. Heres the frame as she sits.
Here she is moved back in,
Here is my Daily Driver, did a complete tune up today on it.
And just for fun, my pyramid.
Old 11-22-2009, 01:56 PM   #44
GMC91
Always trouble
GMC91's Avatar
I pulled the gas tank today, one bracket was so rusted that it snapped, the other came off fine. How do I fix the broken bracket? Here are some pics.
This is the good side
This is the one that broke
Old 11-22-2009, 02:18 PM   #45
Moody Blues
I have an 87 3/4 ton which at some point is going to need what you are doing. Here is some things to consider. Your rear brakes, the cost of a disc brake conversion is not that much more than rebuilding the rear brakes if you intend to get new backing plates and drums. Also you have a daily driver so I am assuming the is no real rush to get this done. While you have the body off it might be a good time to box the frame even though you want it as a "show truck" it will give you piece of mind if you ever want to go off roading. I like the pyramid of dip cans when you get older the turn into beer cans/bottles and tend to slow your project down. Good on you for taking time to clean, parts the garage, everything. I believe you said you was going to put the 305 back in. My opinion is if your putting this much work in save your pennies and find a nice, running, 350 to put in. You will thank yourself latter. Good job kid it is looking good. if you need any info,stats,specs shoot me a message.
Moody Blues is offline   Reply With Quote
Old 11-22-2009, 03:42 PM   #46
GMC91
Always trouble
GMC91's Avatar
Actually I looked the numbers up on the engine, it turns out to be an 86-88 350 2 or 4 bolt main. So all the motor will get is new seals and what not.Thanks for comments Moody.
Old 11-22-2009, 04:12 PM   #47
Moody Blues
Good deal I have a copy of the RPO codes if you want to figure out what you got for gearing and what not I can send them to you.
Old 11-22-2009, 04:20 PM   #48
GMC91
Always trouble
GMC91's Avatar
First you would have to explain what a RPO code is and where do I find it, but sure Id be greatful to know what gears I have.
Old 11-22-2009, 05:56 PM   #49
Moody Blues
inside the glove box there should be a bunch of codes there different options. i would cut and paste them on here but there is 104 pages. write down all your codes and send them to me at harborfire_17@yahoo.com and I will send you a list of your options and any info I get off them.
Old 11-22-2009, 06:46 PM   #50
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
would they also work for crew cab
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
