#26 |
its all about the +6 inches
Hop to it before it gets dark and cold. I'm not trying to sound cockey...but your burning day light...esp if we are all right and it is your starter...no $ spent to get it running and top get mom off your back.
#27 |
its in my garage right now and i have shop lights in there.
AIM screen name: Bpd0159 IM me if you want to. Ditch the ***** and lets go mudding!! My lug nuts require more tourqe than your ricer makes ![]() Hobbies: Working on cars and trucks, Mudding, Dirt Biking, drag racing, hunting and fishing.... just anything to be out side |
#28 |
the engine isnt locked up
#29 |
what no one has anymore ideas??
#30 |
Member since 2000
have you taken the starter to get tested?
#31 |
no i havent been able to get it off yet
#32 |
![]() Join Date: Dec 2001
Hasn't it been like this for several weeks already?? If I had a dead truck in my garage, I would be out there every time I got the chance....not to criticize you or anything, just take the damn starter off first, if it's not that, you have one thing to check off the list.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
#33 |
Not the nightly winner
Turn the key in the on position,take a jumper wire from big post to small post of starter if it turns over and starts you prolly got a bad conn.or selinod......try hitin starter with a hammer..not a BFH..just a tap tap....if that don't work drop the starter..also on the s10s if you pull the right moter mount bolt jack that side up you can take starter out from top side much more easy..thats all i got less you have some test equ. of your own ......good luck
72C10SWB BLUE 350/350 86K10LWB BLUE 5.7 700r4 7.5' fisher plow 93S10XCAB4X4 BLUE 4.3 4L60e 69gmc c10 v8 3 on the tree yellow 72k10 swb 350 3 on the tree green 86k15 swb5.0L 4spd brown |
#34 |
huh?
![]() Join Date: May 2000
do you have power to everything else in the cab of the blazer? does everything else work, but the starter just not engage? Have you checked the neutral safety switch (if it's an automatic)? If it's a stick, are you sure the clutch is fully depressed while turning the key? Can you take a screwdriver and get the starter to engage by jumping the battery terminal to the "s" terminal on the solenoid? Just a few ideas, I haven't been following this too closely...
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
#35 |
i have power to everything but my CD player. The lights work fine everything does but the engine!
AIM screen name: Bpd0159 IM me if you want to. Ditch the ***** and lets go mudding!! My lug nuts require more tourqe than your ricer makes ![]() Hobbies: Working on cars and trucks, Mudding, Dirt Biking, drag racing, hunting and fishing.... just anything to be out side Last edited by Chevy87blazer; 01-21-2003 at 03:50 PM. |
#36 |
How do i check to see if it is the switch is bad???
#37 |
Where is your CD player wired to? Is the constant power (not sure if this is the right word) wire spliced into the ignition wire?
#38 |
uhmmm.... i just use a wiring harness that i bought for my year of blazer... so i didnt have to really mess with any wires
#39 |
Have you used a remote starter switch or just the key?
#40 |
just a key
#41 |
One more question (I hope)- do you have power to other things when the key is in the acc or on position, like wipers etc?
#42 |
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
Didnt we go through this 2 weeks ago?
Did you try all the things that was suggested? Have you tested the starter and solenoid? Take off all the connections and make sure there clean and corrosion free. this includes battery, starter and ground connections. |
#43 |
yes everything works that worked when it died...
#44 |
yeah i checked the connections for all the things and they are good. but i didnt take the starter off to get it tested yet. i will try to do that tomorrow b/c my friend needed to use some of my tools for a couple of days
#45 |
alright i put it in neutral and turned the key.. nothing happened at all no click at all!! nothing!! this is really messed up!
#46 |
Workaholic
Not a flame, but you've been given sound advice--TAKE THE STARTER OFF AND HAVE IT TESTED! Until then you are wasting your time and everyone elses.
1979 K-10 Silverado (work in progress) 1991 V1500 Subruban 1999 Suburban LT 4x4 2006 Suburban LTZ (daily driver) |
#47 |
alright
#48 |
... or just let your mom sell it ...
#49 |
I dont want her to sell it right now! Maybe if i get it running then she can... hell i want to get rid of it..... but see she wants to see it for like $750 or some BS like that! and i need to make some money off it... people have told me that if i get it in good running order and get the inside detailed taht i could get almost $3000 out of it... but thats if i'm lucky you know?
#50 |
![]() Join Date: Aug 2001
ARE'T YOU THE SAME KID THAT POSTED THE "I'M BORED" POST?
Bored need some ideas on what to do at home??? i'm sick and i cant do a whole lot... the chicks are at school so yeah nothing to do...... ideas needed! I'LL TELL YOU WHAT..... GO OUT & WAIT BY THE MAILBOX..... & I'LL BE RIGHT OVER TO FIX YOUR TRUCK...... I'LL BE THE ONE WITH GULLABLE F@CK TATTOOED ON MY FOREHEAD. LOL ![]() ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
