Old 11-07-2009, 07:41 AM   #26
donut
donut's Avatar
Re: Quadrajunk
I'd start with the battery connections. Make sure they're all clean and intact. Same with the grounds and starter connections.
Charging system good? (battery and alt)
IMO these things should be checked this time of year anyway.
Timing could also be a major factor. (too much)
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 11-07-2009, 11:16 AM   #27
bitchin85
bitchin85's Avatar
Re: Quadrajunk
i know this is probably a dumb question but turning the distributor counterclockwise advances it right? i had someone help me with the timing and i think its a little too much advanced
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 11-07-2009, 02:22 PM   #28
presleyhome
Re: Quadrajunk
Excellent piece on timing an older engine:
Timing article link
Jim P
presleyhome is offline   Reply With Quote
Old 11-07-2009, 03:27 PM   #29
cLaWz
Re: Quadrajunk
Great how to on timing. Have no info on the motor in my truck as to recommended timing and was kind of lost as to where I needed to set it at.
Thanks!
cLaWz is offline   Reply With Quote
Old 11-07-2009, 05:30 PM   #30
donut
donut's Avatar
Re: Quadrajunk
I believe your right. In your case you'll probably want a little clockwise (retard).
Throw a timing light on it and don't forget to disconnect the vac. advance when setting it.
Thanks!
There "should" be an emissions sticker that has your timing on it. (pop the hood, it should be right there.) Not sure on the late models, but I think 4' BTDC would be about right. (or a good starting point )
FWIW, my truck runs 10-12' BTDC. A quick search should turn up timing tips as far as how much advance you can run.
Old 11-07-2009, 11:27 PM   #31
cLaWz
Re: Quadrajunk
No emissions sticker but if there was it wouldn't matter anyway. Truck had a 454 dropped in it along with a bunch of "questionable" repairs from the previous owner.
Old 11-09-2009, 12:30 PM   #32
68 TT
Still plays with trucks
68 TT's Avatar
Re: Quadrajunk
Six to eight degrees advanced is a pretty safe number to start with. You can play around with it to see what your engine likes the most.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 11-09-2009, 11:36 PM   #33
bitchin85
bitchin85's Avatar
Re: Quadrajunk
another stupid questioin but how do i know how many degrees exactallly i am advanced?
Old 11-10-2009, 11:09 AM   #34
donut
donut's Avatar
Re: Quadrajunk
Timing light, marks on the timing tab, mark on balancer.
Do you have a chilton/haynes manual?
Old 11-10-2009, 06:42 PM   #35
big10ratrod77
big10ratrod77's Avatar
Re: Quadrajunk
Yesterday 10:36 PM
its a good thing to have
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 11-10-2009, 06:46 PM   #36
bitchin85
bitchin85's Avatar
Re: Quadrajunk
nope not yet but i had number one piston at tdc and lined the number one wire up on the cap with the rotor and turned the distributor mabye 3/4 inch advanced. im going to try to run a timing light onit in te next few days
Old 11-10-2009, 06:56 PM   #37
donut
donut's Avatar
Re: Quadrajunk
By chance, while you had it at TDC, did you check the timing marks to verify they lined up?
Old 11-10-2009, 07:02 PM   #38
bitchin85
bitchin85's Avatar
Re: Quadrajunk
i didnt even think to but i put a peice of coat hanger in the spark plug hole and had someone turn the crank by hand till it was right at the top
Old 11-10-2009, 07:16 PM   #39
68 TT
68 TT's Avatar
Re: Quadrajunk
Good thing to verify just to know everything is the way it should be before you go much further trying to tune it.
I have come across more than one 350 with mixed vintage balancer and timing cover. Timing will be way off if the parts used do not match.
I have also seen a balancer with the outer ring that has slipped in relation to the center hub too.
Old 11-10-2009, 09:31 PM   #40
bitchin85
bitchin85's Avatar
Re: Quadrajunk
the motor was rebuilt by a place like jasper(dont remember the name) like 20,000 miles ago.. would they mix match parts? i noticed it had 305 heads on a 350 block...
Old 11-10-2009, 10:11 PM   #41
donut
donut's Avatar
Re: Quadrajunk
A timing light is useless if the marks are wrong. A little time checking and you'll know for sure.
Old 11-10-2009, 10:18 PM   #42
bitchin85
bitchin85's Avatar
Re: Quadrajunk
ok ill check it out tomorow. thanks guys
