#26 | |
Re: The old "best" starter to use topic....
If it looks like this its a 92-96 corvette starter, requires a small flywheel. Very good starter. Last edited by clinebarger; 11-03-2009 at 12:14 AM. |
#27 |
![]() Join Date: Aug 2004
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#28 |
I have the red skip white mini starter and it works great and their customer service is awesome.
#29 |
![]() Join Date: Aug 2007
#30 | |
![]() They are smaller than other mini starters, and sounds like a new truck when you fire it up. |
#31 |
![]() Join Date: Aug 2008
#32 | |
A heat sink (or heatsink) is an environment or object that absorbs and dissipates heat from another object using thermal contact (either direct or radiant). Heat sinks are used in a wide range of applications wherever efficient heat dissipation is required; major examples include refrigeration, heat engines, cooling electronic devices and lasers. (A Heat SINK would actually help in this instance). |
#33 |
Mounting the solenoid usually does fix this. I believe all that s needed is a Ford solenoid
#34 |
red "skip white" starter arrived today, dropped it in and it is awesome so far!!
