Old 11-22-2009, 09:58 PM   #26
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: Underbed gas tanks...yes again
Are you going to do it like they did on Trucks one day, where they used a cleaner, then some kind of black liquid to fill the metal on the inside?
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 11-22-2009, 10:07 PM   #27
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've restored some hopeless antique motorcycle gas tanks and have developed a real good set of techniques for them. I actually started on the tank today.
Step 1 is to clean it thorougly on the outside with a strong mixture of muriatic acid and water and a scotchbrite.
Step 2 is to pour muriatic acid into the tank and slosh it every which way repeatedly to get all of the nooks and crannies clean
Step 3 is flush with running water for a couple of hours to dilute and flush the acid out
Step 4 is cook in the oven for several hours at 300 degrees to get it thoroughly dried out
Step 5 is POR15 tank sealer. This stuff works like no tomorrow. It will even seal small leaks
Step 6 is powdercoat the outside for beauty
Currently, mine is cooking in the oven stage. I have the POR15 ordered and am waiting delivery. After that I will shoot some powdercoat on it and cook it again and reassemble with new sending unit and gaskets. More pictures to come as I get the stuff and get it finished.
Old 11-22-2009, 10:16 PM   #28
Sicboy
Sicboy's Avatar
POR 15 is da bomb! Used it on my vintage motorcycle tank a few years back and it still looks brand new.
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482
Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!”
- Hunter S. Thompson
Sicboy is offline   Reply With Quote
Old 11-22-2009, 10:27 PM   #29
Tx Firefighter
Sicboy, I actually know you from Triumph forum boards. I've got a Bonneville myself.
Old 11-23-2009, 10:12 AM   #30
toms84ss
So what kind of oven does it take to cook one of these?
toms84ss is offline   Reply With Quote
Old 11-23-2009, 10:17 AM   #31
Tx Firefighter
I've got a big powdercoating oven in my shop.
Old 04-22-2010, 04:52 PM   #32
irish1966
irish1966's Avatar
Does anyone have pics of the Summit Fuel Cell installed?? I am at the point where I need to choose and budget is definitely an issue. :-(
Cheers
David
66 LWB Fleet (on hold)
64 LWB Fleet (daily driver)
65 SWB Fleet (almost finished as a driver)
64 SWB Fleet (just started - "Tommys Hot Rods" tribute truck)
Nothing worth doing, is easy.
irish1966 is offline   Reply With Quote
Old 04-22-2010, 04:53 PM   #33
irish1966
irish1966's Avatar
And I mean from the rear of the truck. lol. I'm considering it in my 66 long bed fleetside.
Cheers
David
Old 04-22-2010, 05:14 PM   #34
markeb01
Senior Enthusiast
markeb01's Avatar
Here's an earlier thread where forum member TheDark1 shows his installation of a Summit cell. May or may not be the same model you are considering:
http://67-72chevytrucks.com/vboard/s...ht=summit+tank
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-22-2010, 05:32 PM   #35
irish1966
irish1966's Avatar
Thx Markeb01. It appears to be different. I will keep searching the forums. I don't mind the filling thru the bed so I think I will go with the summit kit. This is my first build so I'm learning as I go.
Cheers
David
Old 04-22-2010, 07:09 PM   #36
astrochimp
Rear tank with a receiver hitch? I know I read "something" about it on here.
I'm (99.9%) buying a trailer this weekend, and will need to ad some type of hitch.
I hope to move my tank, for more legroom in the cab.
astrochimp is offline   Reply With Quote
Old 04-22-2010, 08:21 PM   #37
TR65
TR65's Avatar
Astro,
My underbed tank did not interfere with my receiver hitch but I guess it would depend on the tank. I used on from Rick's Hot Rod Shop.
http://67-72chevytrucks.com/vboard/s...d.php?t=398806
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 04-22-2010, 10:36 PM   #38
SCOTI
SCOTI's Avatar
If the 6x-66's are anything like the 67-72's, removing the tank won't gain you any additional leg room. The top of the seat hits the rear cab wall (under the back window) @ the same time the lower portion of the seat hits the tank. I suppose adjustable (forward tilting) seating would allow the seat to be positioned farther back @ the expense of a more upright seating position.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-23-2010, 10:12 AM   #39
andyh1956
check out these folks- they advertise custom ohm matching & sender rebuilding.
http://tristarrradiator.com/Custom%2...ed%20Page.html
andyh1956 is offline   Reply With Quote
Old 04-23-2010, 10:25 AM   #40
andyh1956
about six months ago i had to replace the gas tank in son n laws 69 mustang. i also had to rebuild the flange area of the trunk, because as most of you know the tank is the trunk floor & the tank sets on the flanges in the tank well. the tank comes with holes for the fasteners already in the flanges. it looks like with trimming the frame rails back then the tank could "slide" into the frame rails & then nut & bolt to rail. that way you wouldn't need the retaining straps. with a little rubber insulation under the flange & a rear filler this looks like the best setup to me. wadda yall think?
andy
Old 04-23-2010, 10:51 AM   #41
Rich 5150 69
Rich 5150 69's Avatar
One other person on here has done that, he also moved the fill to one side..
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-23-2010, 01:38 PM   #42
SIR
SIR
SIR's Avatar
...early fo** falcon ...drops in with very little modifications...
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 04-23-2010, 04:03 PM   #43
astrochimp
I have a '89 seat. My original was replaced with junk buckets, when I got the truck.
Old 04-23-2010, 11:39 PM   #44
Captainfab
60-66 Nut
Forum member Vin63 also builds/rebuilds fuel sending units.
Old 04-24-2010, 12:27 AM   #45
62fresh
been wanting to do this as well what would be the
best kit to get for a 62 longbed?
62fresh is offline   Reply With Quote
Old 04-25-2010, 09:28 AM   #46
bubba327
HOW long until spring??
bubba327's Avatar
this is a RCI 17 gallon tank from Summit ---30"x17"X7"
Size:  37.4 KBI trimmed the frame rails on the bottom --frame is 34" to outside -- tank in 30"--I had the angle side braces welded on locally
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 05-04-2010, 07:07 PM   #47
pctahlequah
pctahlequah's Avatar
Hate to revive an old thread but, Sir, could you elaborate on this install, please? I've seen Falcons in the salvage I go to, but it didn't occur to me to check out the tanks.
'66 C20 converted to C10, 454/TH400
'66 C10 saved from crusher
pctahlequah is offline   Reply With Quote
Old 05-05-2010, 02:09 PM   #48
Dan in Pasadena
Dan in Pasadena's Avatar
Man, you MAY have just saved me a LOT (more) searching with this link.
My truck isn't a 60-66 but the issue I have an issue that maybe applies to some of you guys: My '46 truck came with some kind of F*rd tank between the frame rails and behind the rearend and it fits pretty good. Problem? It has the F*rd ring type sending unit retainer instead of the typical GM/Universal 5 hole type fuel sender mounting.
I had the truck pro rewired when I bought it last summer and I bought TPI-Tech gauges. I because I knew I wanted the original factory cluster restored (in the future) but it was too costly then. So I went with the lower buck TPI gauges. They all work fine - no issues, and they even look pretty good in my opinion, see here: http://www.tpigauges.com/prod03.htm
I just haven't figured out how to make their five hole sending unit mount in my type of tank? I've searched Summit, Jegs, North Hollywood Speedometer, and other places for an adapter or something and no luck. MAYBE this place has or will make something for this application?
Have any of you guys figiured out how to solve this problem on the cheap? I think the gauges are 240/30 ohm. ANY help would be appreciated. - Dan
Dan in Pasadena is offline   Reply With Quote
Old 05-06-2010, 02:57 AM   #49
andyh1956
without having seen your parts i think the answer would be to transfer the 5 hole sender assy over to a lock ring type. go to junk yard & get a sender assy that fits your tank. then remove everything on it except maybe the suction tube if equipped. then transfer the sender from the five hole unit over to the lock ring one. all it is being used for is to hold the sender in place so it should just be simple mechanics. be sure to install the lock ring unit in the tank before you transfer the sender so you can see how it fits & index the sender float in the proper position. i spose it should sit sideways to the tank so you dont get "slosh readings". i did this a long time ago on a military jeep that we put a civy fuel tank in. hope this helps!
andy
Old 08-12-2010, 02:31 AM   #50
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Not trying to bring back a dead thread, but there is a ton of info on here I don't want to loose. I'm gonna face this same thing on my truck. Thanks for all the input guys.
fryer1979 is offline   Reply With Quote
