Old 11-12-2009, 08:54 AM   #26
Scot_Douglas
Scot_Douglas's Avatar
Re: Opinions on best sounding exhaust???
Originally Posted by Sicboy View Post
I just put Speedway's Tru-Rams and Brockman (steel packed) Mellowtones on my freshly rebuilt 327. Awesome 60's muscle car sound. I went with 24" 2-1/2" inlet/outlet. They are a little too loud so I'm replacing them with 36" Mellowtones.
It was your "Pabst" post that turned me on to those Tru-Rams.
You guys are giving me plenty of options to research!!!
Thanks so much!
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 11-12-2009, 10:59 AM   #27
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Opinions on best sounding exhaust???
Scot_Douglas,
Since you have a 377 Stroker engine, what are the specs on your engine? Cam lift/duriation,, Heads, Etc.
I know it's a 400 block with a 350 crank. . .destroked.
The exhaust will always sound different acording to how your engine is setup and tuned as well as the headders lenghts, X-Pipe -and/or- H Pipe, size of exhaust tubes, back pressure etc. I am having exhaust cut out put on my truck as well to strike fear in the local rice burners......
The results in HP order:
1.Flowtech Warlock (open) 374.2 hp/ 333.1 tq
2.Bassani Real Street 373.7 hp/ 333.8 tq
3.Hooker Maxflow 373.5 hp/ 333 tq
4.Borla XS 373.3 hp/ 332.6 tq
5.Magnaflow 372.8 / 332.5 tq
6.MAC 372.3 hp / 331.5 tq
7.Flowtech Afterburner 372.3 hp/ 330.1 tq
8.Hooker Aerochamber 372.1 hp/ 330.4 tq
9.Bassani 372 hp/ 333.5 tq
10.Spintech 371.6 hp/ 332.2 tq
11.Edelbrock Performer RPM 370.9 hp / 331.3 tq
12.Borla XR1 370 hp/ 334 tq
13.Flowtech Terminator 369.5 hp / 331.3 tq
14.Dynomax Ultra Flo 369.4 / 333.2 tq
15.Flowmaster 369.4 hp / 331.8 tq
16.Flowtech Warlock 366.3 hp / 325.3 tq
17.No muffs 365.2 hp / 330.1 tq
Sound Off in Quietest to Loudest (Decibels):
1.Borla XS, 80db at idle, 90db at 2,000 rpm, 110db at WOT.
2.Hooker Maxflow, 80db at idle, 90db at 2,000 rpm, 120db at WOT.
3.Magnaflow, 82db at idle, 91 at 2,000 rpm, 114db at WOT.
4.Flowmaster, 82db at idle, 93 at 2,000 rpm, 115db at WOT.
5.Flowtech Warlock, 83db at idle, 92 at 2,000 rpm, 112db at WOT.
6.Dynomax UltraFlo, 83db at idle, 94 at 2,000 rpm, 113db at WOT.
7.Borla XR1, 83db at idle, 96db at 2,000 rpm, 118db at WOT.
8.Bassani Street, 83db at idle, 96db at 2,000 rpm, 120db at WOT.
9.Edelbrock RPM, 84db at idle, 93db at 2,000 rpm, 118db at WOT.
10.Bassani Real Street, 84db at idle, 96db at 2,000 rpm, MAX. (120+db).
11.Flowtech Afterburner, 86db at idle, 94db at 2,000 rpm, 115db at WOT.
12.Flowtech Terminator, 86db at idle, 94db at 2,000 rpm, 119db at WOT.
13.Hooker Aerochamber, 87db at idle, 94db at 2,000 rpm, 114db at WOT.
14.SpinTech, 87db at idle, 97db at 2,000 rpm, 116db at WOT.
15.MAC, 87db at idle, 98db at 2,000 rpm, 119db at WOT.
16.No Muffler, 91db at idle, 103db at 2,000 rpm, MAX. (120+db).
http://ls1tech.com/forums/generation...al-street.html
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 11-12-2009, 11:01 PM   #28
BMSJaX
BMSJaX's Avatar
I just put on a pair of 2.5" Thrush welded mufflers and they sound great! Just like I think a muscle car should sound like. I have the mufflers just behind the cab and they dump out the sides before the rear tires. At first they are very loud and deep but after you run about 100 miles on them they mellow out and give a great sound. And they are only $29.99 each from summit! Beats the price of flowmaster and magnaflow for a sound that I think is much better.
1964 Chevy C10 a.k.a. Julie Ann
H.E.I. cause its better to be pointless
BMSJaX is offline   Reply With Quote
Old 11-14-2009, 10:37 AM   #29
Scot_Douglas
Originally Posted by 1Bad62Pro/Street View Post
Scot_Douglas,
This is all I know about the motor until I tear into it to give it a good once-over:
- 350 block STD bore and a 400 crank machined to fit the 350 journals.
- 5.565" rods and STD 350 pistons
- 4 bolt main block with fresh cylinder hone
- Hydraulic flat tappet cam, 224 Int/ 234 Exh @ 0.050" lift
- All new bearings and gaskets.
- Heads are GM 882 casting with mild port and polish job,76cc. 9.5:1 compression, with 2.02/1.60 valves
- Intake is gasket matched to the heads
1966 C10
Build 'Fread
Old 11-15-2009, 05:49 PM   #30
'72customdeluxe
Please no Flowmasters. Longtubes, 2.5" piping, x-pipe and a straight through muffler. Magnaflow, Dynomax Ultrad Flo, and most Borlas are straight through. This type is quiet when cruising without resonation and really open up with the throttle.
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 11-15-2009, 09:44 PM   #31
LoRollinLS
LoRollinLS's Avatar
u can still get the 40 series, just make sure that you get the delta flow 40 series, they are made specifically to keep down interior resonation...and as long as your gonna have tail pipes behind your muffler there should be even less cab noise/resonation....im surprised no one said this before now
LoRollinLS is offline   Reply With Quote
Old 11-16-2009, 01:49 AM   #32
Captainfab
60-66 Nut
Uummmm they did
Originally Posted by chris6499 View Post
on the flowmasters if you get the delta flows it reduces the resonance in the cab both of my daily drivers have flowmaster 40 series delta flows and they sound good and dont resonate on my 64 i have spin tech and they are loud all the time
Old 11-18-2009, 08:28 PM   #33
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
I'm getting fond of the open headers sound on my burban, when it will run, but thats another thread.....
If the life I live dont kill me, then I guess I'll never die!
New updated stuff at www.kdrodworks.com
My site still needs help, web guys and gals pm me.
the best guys in the whole world:
sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231
kdrodworks316 is offline   Reply With Quote
Old 11-18-2009, 08:50 PM   #34
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
i say go with pypes
either the race pros or the violaters
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 11-19-2009, 11:42 AM   #35
LoRollinLS
LoRollinLS's Avatar
my bad, i misread
Originally Posted by Captainfab View Post
Uummmm they did
Old 11-20-2009, 12:10 AM   #36
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
Hooker Aerochambers have every quality you are looking for!!!! They are awesome.
Imperial Kustom LLC
Meridian Idaho.
I never stopped playing with cars, they just got bigger.
Imperial Kustom is offline   Reply With Quote
Old 11-20-2009, 12:55 AM   #37
19GMC63
19GMC63's Avatar
+1 on the brockman mellotones, if you like the 60's sound. They can build you a pair to order, glass or steel packed, and in various body lengths. Muffler placement is a key with these though. The short body lengths are real popular with the traditional hot rodders who like the off-throttle rap.... I've heard reversing them increases this also. The longer body lengths are nice and mellow with little to no rap... it's a unique sound that doesn't get annoying.
19GMC63 is offline   Reply With Quote
Old 11-21-2009, 05:49 AM   #38
1Bad62Pro/Street
Old 11-21-2009, 07:55 AM   #39
Scot_Douglas
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^6
I think that's the sound!
1966 C10
Build 'Fread
Old 11-21-2009, 08:51 AM   #40
1Bad62Pro/Street
Here you go!!!!!
Patriot Exhaust Patriot Smithy Mufflers
http://http://www.google.com/product...lers&scoring=r
Old 11-21-2009, 06:41 PM   #41
'72customdeluxe
I may be mistaken, but i'm pretty sure those Smitheys have tiny little cores that will choke a 383. Bad. If you want the glasspack sound, look into the "walker/dynomax/thrush" style. They have a straight through perforated core with no louvers and will give you that flappy raspy tone. Here are some, they come in alot of pipe sizes and lengths. Cheap too. http://www.summitracing.com/search/S...rush+glasspack
They have stainless ones aswell on that link
Old 11-21-2009, 11:22 PM   #42
brawley
Easy Does It
brawley's Avatar
Cherry Bombs ??? anybody tried these
brawley is offline   Reply With Quote
Old 11-22-2009, 03:53 PM   #43
1Bad62Pro/Street
Exclamation Re: Opinions on best sounding exhaust???
Cherry Bomb Glasspacks
Old 11-22-2009, 05:20 PM   #44
Hilandr451
Hilandr451's Avatar
Originally Posted by Baby Blue 66 View Post
I just put magnaflows on my 66 with a vortec 350, headers, dual 2.5" with H-pipe, dumped after the rear axle. Very mellow from idle to about 3,000 rpm and then bam! they really snort after that.
Ditto. I have the exact same set-up on my '66 C20. My pipes exit out at 90 deg just past the rear wheels.
Nice mellow sound in the cab, but I have gotten lots of complements from my friends at work on the deep throaty sound. They tell me my truck "sounds fast".
Greg Smith a.k.a. "The Highlander"
1966 C20 Custom Camper, 2017 Chevy Silverado 1500
Highlander's Project Pics
Highlander's web site: www.6066ChevyTrucks.com
Hilandr451 is offline   Reply With Quote
Old 11-22-2009, 06:14 PM   #45
Bazooka
Keepin it old school
Bazooka's Avatar
Everything you need to know right here. 3 pages long... scroll to very bottom to go to next page..
http://www.pontiacstreetperformance....p/exhaust.html
PS Flowmaster sucks
Bazooka is offline   Reply With Quote
