Redefining LowBudget
Re: Hello
kool with any luck I'm going to get my parts truck today now that the rain has stopped...I beleive it a 3 on the tree if you want parts to put it back together let me know...lik I said I'll kknow more later today like you I'm sure...
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
Re: Hello
How did you make out with your parts truck? I took a look at the other one the guy had were I bought mine and it didn't look like anything special. It's a 72 6cyl 3 speed with a clear title. I couldn't get that close to it because of all the other cars he had in the way but it looked like the door bottoms were rotted out from what I could see. He was asking $550 for it but I'm sure you could get it for less. If you're interested I'll give you his number
Re: Hello
I saw it on craigslist...I'll check that parts truck I picked up the inner may be usable I also have the pair I took out of my truck...the parts truck is stripped to the bones not much left after we picked it up off the ground
check your heater controls and inner heater box also I can save the fuel tank if you need it that red truck looks like aparts truck too take another look your in a better postion to get a good deal on it...I would even pick it up for you ![]() Jeff
Re: Hello
Where to start....... I knew that the floor was a little rotted but after pulling out the carpet and weather stripping I found more rot then good metal. It's so bad that I'm going to be hunting around for a cab in better condition. The PO decided to add floor mat after floor mat instead of actually fixing the floor to keep his feet from going down to the road. The front end is actually pretty solid. Looks like the only thing I'm going to have to replace is the passenger side inner fender. The bed is still up in the air. It seems solid for the most part but I haven't taken it apart yet. The only thing I've done so far is take out the seat, tank and carpet along with about 6 sets of floor mats and some astro-turf that the PO put over the gas tank. This morning I started ripping apart the cap so I could start work on the bed to see how bad it really is. Anyway here are a few pictures:
