Old 02-02-2010, 01:39 PM   #26
Fat Mike
Fat Mike's Avatar
Re: '53 gmc new project
Really nice ride. Like the stance and the rims. Show us pictures of your frame.
Fat Mike is offline   Reply With Quote
Old 02-02-2010, 05:29 PM   #27
texas56
texas56's Avatar
Lookin very nice! Wish at times I would have left mine Patina and just did the frame up nice. This body work is tuff! lol Great lookin truck cant wait to see it done!
1955 First Series Thriftmaster
Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s,
texas56 is offline   Reply With Quote
Old 02-02-2010, 06:37 PM   #28
xJoey Dubsx
xJoey Dubsx's Avatar
How did you put the front end of the s10 on it? Could you show pics?
[CENTER][FONT="Arial Black"]-------------------- Joey Dubs --------------------
2000 Dakota - Bagged, Shaved, and more
2003 Ram - Fast, and perdy
1951 GMC Stepside - All apart, like a puzzle.
xJoey Dubsx is offline   Reply With Quote
Old 02-03-2010, 10:41 AM   #29
1950 GMC
1950 GMC's Avatar
Thanks,
Garrett
My 1950 GMC Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=351867
My 1950 GMC Photobucket Account:
http://s565.photobucket.com/albums/ss95/1950GMC/
1950 GMC is offline   Reply With Quote
Old 02-13-2010, 09:13 PM   #30
kdog3121
S10 front clip grafted to original '53 frame. It's 3/16" plate cut to make the transition, inside is reinforced with 1/4" plate plug welded to the inner frame for strength. I'm going to box the entire frame eventually.
Just started working on it again, I'll post some more progress pics as work continues.
kdog3121 is offline   Reply With Quote
Old 02-13-2010, 11:17 PM   #31
Fat Mike
Fat Mike's Avatar
Very clean looking subframe job. I really like your truck. Gives me alot of ideas on my build. Keep us posted and please show some pictures of you link system.
Old 02-21-2010, 08:30 PM   #32
kdog3121
Here's a pic of the rear end / 6 link in progress. Just picked up a 4x4 S10 blazer rear end out of a '98 with discs (59.25") yesterday. Fits better than the ZR2 axle (63.25"), plenty of clearance on the fenders but had to trim the bed slightly with only a 255/35 tire. The rear rails are boxed and notched out of 3/16" stock.
The 6 link is modeled similar to the Thornebecke bros kit. Most of the brackets and links are done now, just need to tack everything in place. The two link brackets where the triangular bars join will be mounted under the crossmember. The bags will ride on the rear link bars. Still need to mount the shock bar, fab axle brackets for the triangular links and complete the bottom rails of the frame where it's notched.
This past weekend I finished the new radiator support, front bumper mounts and steering column base mount. Working on the rear end next weekend, hopefully I'll be fabbing mounts for the motor/trans soon!
Old 02-22-2010, 12:18 AM   #33
GRIMSS
GRIMSS's Avatar
Looking good. I really like the notch, kind of like my panel.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 02-22-2010, 12:59 AM   #34
mobileortho
mobileortho's Avatar
Great looking truck!
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 02-22-2010, 01:28 PM   #35
Fat Mike
Fat Mike's Avatar
Looks really good and clean welds. I like the c-notch. I like the s-10 frame because you can lay frame without having to cut the frame and that would be using 20's or 22's.
Old 02-22-2010, 06:35 PM   #36
BlueJeep
BlueJeep's Avatar
Can you post up pics of how you did your radiator support?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 04-18-2010, 08:43 PM   #37
kdog3121
[IMG]http://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs035.snc3/12296_536976587886_43500166_31645778_1991081_n.jpg
[/IMG]
Some progress, 350 sbc & 700r4 are tacked in, radiator tacked, bed half way fabbed etc alot of stuff needs to be finished, exhaust, brakes, welding the whole chassis, brackets & links etc.
Old 04-19-2010, 08:04 PM   #38
Ben IV
Lookin good, what else is that in the shop? I see there is an ls transplant in the works.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 04-19-2010, 08:45 PM   #39
kdog3121
'55 chevy had it about 4 years now so far: it has an ls1/t56, notcched, bagged w/ shockwaves up front, 4 link, 9 inch posi, 4 wheel discs, C4 front suspension, new floors, full quarters, firewall, trunk, tailpan, tubs, inner outer rockers, braces, thru frame exhaust, flowmasters, 18/20 rim combo, etc etc.... this ones going to be flat black!!! Built the chassis from an original frame.
Old 11-21-2010, 05:53 PM   #40
kdog3121
Rear end is almost done... moving up to the front end and cab over the winter. Hope it's ready for the spring!
Old 11-21-2010, 07:55 PM   #41
Fat Mike
Fat Mike's Avatar
Man that is a heck of a setup! Nice work and keep posting pictures of your progress.
Old 11-22-2010, 01:53 AM   #42
Laid_Out_50
Laid_Out_50's Avatar
Just wondering how much if any the rear wheels stick into the bed?
Laid_Out_50 is offline   Reply With Quote
Old 04-18-2011, 07:41 PM   #43
kdog3121
an LS1 and 6 speed should be pretty sick... need to finish motor mounts but transmission mount is done.
Looking at the exhaust, I may have to build headers for it.. it's really tight in the S10 clip.
Old 04-18-2011, 08:28 PM   #44
99 to Life
99 to Life's Avatar
looks sick man,
I haven't seen backs that far back in the rear. I have you done it like that
before? I have heard over the axle is a bit rough and I have seen alot just
right in front of the axle.
I really like the patina and overall truck.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 04-18-2011, 09:02 PM   #45
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Awesome project!!!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-22-2011, 12:47 PM   #46
kdog3121
thanks for the compliments!
thorbecke brothers sells a 6 link kit for S10's - one of my friend bought it and installed it on his truck. Rides great.
The setup on my truck is setup very similar but it's not the Thorbecke kit. I used 1.5" bars and 5" bags out back. It should ride pretty good - i don't care for the bag over axle design at all.
Old 08-28-2011, 09:09 PM   #47
kdog3121
1 3/4" headers w/ 5/16" flanges custom built from scratch to fit the LS1 in a Z'd S10 front clip. Not much room especially on the driver side due to the steering shaft. Going to TIG butt weld the joints and have them sent out for jet coat.
Finally got some tubular control arms, put the rest of the brakes together and cut out for the RE7 7" bags up front. Making some progress, but still a ways to go.
Need to build a new mount for the p/s pump and a support for the electric fan. Haven't figured on how to do the intake yet - I only have about 4 1/2" from the intake nose to the radiator support.
Cajundragger (dustin) has a square air filter from S&P? which would probably work, but I need the dimensions.
Old 08-28-2011, 11:40 PM   #48
Fat Mike
Fat Mike's Avatar
Man you have an awesome build!! Can you take a few pictures of the crossmember for the radiator and front grille mounts?
Old 02-26-2012, 07:42 PM   #49
kdog3121
3/8" smc valves for FBSS plumbed and wired up. I used parker fittings with air brake line - great quality stuff but not cheap. 1/4" to gauges and 1/2" line to bags.
Installed a 20 gal fuel cell plumbed with fuel pump and corvette regulator.
Next project is to get a set of hanging pedals from a square body s10 for the clutch, build a power steering pump mount (going with wrangler 4cyl remote pump), pull the motor and weld up the front end, motor mounts and transmission mount.
Old 02-26-2012, 07:50 PM   #50
kdog3121
I changed the front radiator support and built one from scratch. Thats a champion radiator for a 64-65 mustang with an electric fan. New fuel rails and 7" brake booster. 28" steering column with jeep cherokee lower steering shaft & u joint.
I bought a cheap shorty air filter but I don't like it, thinking of going into the inner fender if I have room.
