#26 | |
No Nonsense
![]() Join Date: Sep 2009
Re: Bummed Out!
Ok here are some more pics. I took the valve covers off and they had water in their but nothing seems to be damaged in their that I can see (although I have minimal knowledge on motors) and one of the valve cover gaskets were torn.
Bi-Centennial Blazer ![]() ![]() |
#27 |
No Nonsense
Re: Bummed Out!
Took off the intake manifold and everything looks clean, again some water:
#28 |
No Nonsense
Re: Bummed Out!
Can anyone tell me what type of intake this is?? Is it stock oem? Does it look in decent shape? I'm thinking of getting an edlebrock intake to match my 1406 carb.
Bi-Centennial Blazer ![]() ![]() Last edited by Libertad; 11-16-2009 at 05:04 PM. |
#29 |
No Nonsense
Re: Bummed Out!
Ready to take off heads. Any tips on what to do after removing all the head bolts? Do the rods need to come out (never done this before) or do I just use a rubber mallet to break the seal?
#30 |
No Nonsense
Re: Bummed Out!
Here is a pic of spark plugs. Can u tell me anything by looking at them?
My truck bed is now storage:
Bi-Centennial Blazer ![]() ![]() Last edited by Libertad; 11-16-2009 at 05:11 PM. |
#31 | |
Still plays with trucks
Re: Bummed Out!
A Performer would be a nice upgrade though.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#32 |
Re: Bummed Out!
Since you are tearing it apart for curiosity only you can keep the rockers and pushrods in place and just take out all the head bolts. This will use the spring pressure to lift the heads off the block and save you a ton of time backing all the rocker arms off.
#33 | |
No Nonsense
Re: Bummed Out!
![]() By the way where do I look to find out if this is the stock motor or if not what year it came out of? Thanks to all that have given me advice and please keep the comments coming, they really keep me going in the right direction. Much appreciated!
#34 | |
Re: Bummed Out!
Nobody would likely buy it from you for any more than a couple bucks.
#35 | |
No Nonsense
Re: Bummed Out!
I removed all the head bolts and it seems pretty well on there should I tap it with a rubber mallet?
#36 | |
Re: Bummed Out!
The larger set is the assembly plant ID code and application ID code and the smaller set is the partial VIN number from the vehicle it came out of. There is a set of numbers cast into the top of the bell housing flange on the driver side that will tell you what the block is and what year range it was produced. Opposite side of the bell housing flange is the casting date. A single letter and a couple numbers. Month A is January and so on with the double digit day of the month and a single digit year.
#37 |
Re: Bummed Out!
There are a couple shorter bolts on each end under the valve cover area that can be covered with oil and can easily be out of sight.
#38 |
No Nonsense
Re: Bummed Out!
Only saw these on the pad on the front passenger side of block
VO2 19UA Thanks for your time 68TT
Bi-Centennial Blazer ![]() ![]() Last edited by Libertad; 11-18-2009 at 11:11 AM. |
#39 |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Bummed Out!
Libertad you must be a subscribing member to ask a WIW or list a WTB. Please review site rules
#40 |
No Nonsense
Re: Bummed Out!
Sorry old rusty. Just for that I am going to subscribe right now.
#41 | |
Re: Bummed Out!
They can be stuck on there pretty good. I had to use a long pry bar to break mine loose after 30 years on the engine. I was afraid I was going to break the head casting I had to pry so hard. With only two letters at the end of the code shows it is a 1969 & earlier block. 1970 & newer had three letter codes. Make sure there isn't one more letter there. All the UA_ three letter code engines are 1981 vintage 305's that came in half ton trucks. A UA code small block is a 1969 truck 200 hp 2-bolt main 307 cubic inch motor. Put a tape measure on the cylinder bore and let me know what it shows. A 307 has a 3-7/8" bore so it should be obvious that it is not a 4.00" bore like a 350 or 327. A 305 is just under 3-3/4" bore. Either UA code engine is not worth the effort to rebuild it when damaged.
#42 | |
No Nonsense
Re: Bummed Out!
Bi-Centennial Blazer ![]() ![]() Last edited by Libertad; 11-18-2009 at 11:16 AM. |
#43 |
No Nonsense
Re: Bummed Out!
Ok another question I have 882 heads are these heads any good? I may want to put them onto a 350 short block when I find one.
#44 | |
Re: Bummed Out!
Low compression with flat to pistons and they are unleaded compatible unlike the heads that came on that 307.
#45 | |
No Nonsense
Re: Bummed Out!
#46 | |
No Nonsense
Re: Bummed Out!
I may buy one of these 350 blocks
any thoughts?
Bi-Centennial Blazer ![]() ![]() Last edited by Libertad; 11-17-2009 at 12:44 PM. |
#47 |
Re: Bummed Out!
Depends on what you want to do with the truck.
What kind of power are you looking to build?
#48 |
No Nonsense
Re: Bummed Out!
reliable daily driver with mild cam
#49 |
Re: Bummed Out!
You don't need to spend that kind of money on a bare block then. Only somebody pushing the limits of a stock block needs to find the 010 / 020 block.
Go to the local pull-it-yourself wrecking yard and find a 1973 to 1985 vintage 3/4-ton truck. Most had 4-bolt 350's with unleaded compatible heads. Some even came with steel cranks. My local one sells complete engines for $140 plus tax. The core charge for a remanufactured short block is twice that and you will get a whole set of spare accessories too. Look for one that has been hit and you will probably find a decent running engine that may not need much if any machine work to freshen it up. I would pull the oil pan at the yard and make sure there is noting obviously wrong with it and that the engine turns over freely by turning the balancer bolt. If it all looks good I would take it home and tear it down the rest of the way to make sure it doesn't need machine work. If it needs major work take it back and get another one. My yard frowns upon you tearing engines apart in the yard that you are getting as an assembly and wants you to take only what was on that engine but you can mix & match parts if you want. If they say something I tell them I was only going to get the heads but after taking them off I decided to get the whole engine. When you get a block with little to no ridge on the bores and a smooth crank you can just freshen it up with rings, bearings, gaskets, a timing set, oil pump and all steel oil pump drive shaft and a mild cam. Put new valve springs and silicone umbrella style valve stem seals into the heads and you are good to go for a street motor. The Comp Cams 260H cam grind #12-206-2 is what I ran in my 81 K20 truck with a Performer intake and it made great low end power and had great mid range too. Perfect for a daily driver truck.
#50 | |
No Nonsense
Re: Bummed Out!
I guess i fell in love with the pretty block and the fact that it was checked for cracks and all but what your saying makes a lot of sense and very price contious.
