Old 11-25-2009, 02:00 PM   #26
MXmaniac
MXmaniac's Avatar
Re: New '65 Project in Florida
Originally Posted by wlevick View Post
Not bad for $3,000 either.
Nice looking truck!
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline   Reply With Quote
Old 12-02-2009, 09:47 PM   #27
wlevick
Mechanically it is ready to move under it's own power...with the exception of the transmission. It has a 700r4 and when I put it in gear it doesn't do anything. When I first got the engine started (I have ran it for about a total of 15 minutes), something was making a loud sound - kind of like a supercharger sounds. Initially I didn't think to much about it - because it also has a Pete Jackson gear drive - which makes a similar sound. The longer I ran it the louder it got. I checked the dipstick on the tranny and the fluid wasn't even touching it. I added ten quarts and it still made noise and still didn't move. I jacked the truck up, took out the converter bolts and slid the converter back. The noise went away. Good news for the engine...the problem is not there...but I don't know about the tranny. I don't know if the guy I bought this "project" from put fluid in the converter. He says the transmission was newly rebuilt and the converter was new ???? Is there a way to test the converter now to see if it is OK? How about the transmission? If he didn't put any fluid it the converter, will the converter pick up the fluid by me adding it to the transmission? Should I pull the converter, add fluid to it, put it back in and try it again?
wlevick is offline   Reply With Quote
Old 12-02-2009, 10:23 PM   #28
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
I wish I could help you but I have a ? too about this that could help people.
I bought a B&M converter new. It came with some oil in it and didn't say anything about adding. Will the trans fill it.
It's pretty much the same ? as wlevick
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 12-03-2009, 05:46 PM   #29
bigblock96
bigblock96's Avatar
Hate to tell you the pump in the trans is toast! burnt up will need a new pump
bigblock96 is offline   Reply With Quote
Old 12-03-2009, 05:49 PM   #30
bigblock96
bigblock96's Avatar
and as for filling I was always told to add at least 1 quart before installing you need fluid in the converter to prime the pump in the trans ,hope this helps
Old 12-03-2009, 06:34 PM   #31
glendale
glendale's Avatar
i must agree. and if the kickdown not adjusted when you put it in gear. you have a good chance of smoking that trans pretty quick. good luck man that sucks. nice truck btw.
glendale is offline   Reply With Quote
Old 12-03-2009, 08:35 PM   #32
TheDark1
Intentionally Left Blank
TheDark1's Avatar
YUP, I did the same thing a few years ago. Luckily it was my friends car.HAHAHAHA!
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 12-04-2009, 01:41 AM   #33
Captainfab
60-66 Nut
X3
With basically no fluid in the trans, I'd be surprised if there isn't some damage.
Old 12-08-2009, 09:12 AM   #34
wlevick
The front fenders are on and the hood and bed are back from being media blasted.
Old 12-08-2009, 09:35 AM   #35
bigblock96
bigblock96's Avatar
Looking good still,whats up with the trans? any update?
Old 01-04-2010, 10:44 PM   #36
wlevick
Well...the transmission is in the shop and the mechanic said third gear is gone and it has the wrong converter. He said it is a 27 spline transmission and has a 30 spline converter - or vice versa. Nothing that $550 want fix.
