Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 08-08-2010, 12:51 PM   #26
Frizzle Fry
Frizzle Fry's Avatar
Re: Project Family Hauler
Good stuff man. Looks like you might have to go with a bear claw style latch.
Frizzle Fry is offline   Reply With Quote
Old 08-08-2010, 01:02 PM   #27
pickup67man
pickup67man's Avatar
I am thinking about that. Will try the fitment of factory latch first. Want it to look like factory parts to match front. Or I will change fronts so they are all the same.
Travis
2005 K2500 Duramax (hauls the junk home)
1967 Chev C10 (hauls a$$)
1970 Suburban (Yukon XL 4 door)
1968 GMC 3/4 ton (sheetmetal only, chassis gone)
2005 Malibu (wife's car, still a Chevy)
New Home for Chevys (Moved in and working)
pickup67man is offline   Reply With Quote
Old 08-22-2010, 05:09 PM   #28
pickup67man
Got about 4 hours in yesterday. Wife is working this weekend and I am watching our 2 year old. I would have her help work on the suburban but she doesn't like loud noises.
Had to reshape the bottom of the door. The front of the rocker panel is fitted for the front curve of the door, but I used the rear part of a passenger door so the body contour is right but the curve is different on the bottom. So I had to blend the two.
Not only do I have to design the parts, I have to make them and put them together. This is the reason for the slow progress. This is the first time I have done something this custom. I spend a lot of time thinking about how I need to make a part.
Also found the original latch will fit. Tested the door skin and it lines up so the handle will work. Very tight inside. Am going to have handles together like old Lincolns. Using original truck handles.
Travis
Old 08-28-2010, 11:35 PM   #29
pickup67man
Got to work on the suburban today. Fitted the door skin. Found the inside needed to be rearranged a little so everything lined up. This is the new view.
Gray door is the 4th door
Ended up mixing the door skin with the side of the suburban to get the curve right.
Distant view, crazy to look at.
Maybe tomorrow I will start fitting the window frame.
Travis
Old 08-28-2010, 11:41 PM   #30
67chevy1series
67chevy1series's Avatar
wow thats cool
67chevy1series is offline   Reply With Quote
Old 08-29-2010, 09:33 PM   #31
pickup67man
Got the door frame in shape. Had to fit the angles to the suburban. Window rolls up and down. Corner window fits. Got the inside handle installed with linkage. The frame is straight. Just looks curved in picture.
Relocated the inside handle. Everything is connected to release the door.
Close up of window. The skin gets closer at this window.
Rear view of door open
Front view of door open
Still need to fill the gap between the doors. Passenger side is extended from the factory to fill transition.
Also started to finish off the door jamb.
More to come soon.
Travis
Old 08-30-2010, 12:22 AM   #32
67chevy1series
that looks good hope to see the gap closed a little more but i probably couldnt do what you did in such a small amount of time you got seious fab skills
Old 08-30-2010, 12:41 AM   #33
pickup67man
Thanks. I have had this suburban for 5 years and have been working on it for over a year. The first 4 years was just getting the project done in my head. Making a door is the hardest thing I have done. You need to make everything fit from 12 different angles. It wouldn't be as hard if I didn't need to use hinges. Just this weekend I spent 16 hours fitting the door into the opening. It was already started and not even close to being finished. Still have lots of welding and grinding to do. Also need to hammer & dolly the skin. Some of the curve is gone around the weld.
Travis
Old 08-30-2010, 01:05 AM   #34
VA72C10
VA72C10
VA72C10's Avatar
very cool project! Just found it but read the thread and looking forward to following the progress. Great work so far!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 08-30-2010, 03:52 PM   #35
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice work!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 09-06-2010, 09:44 PM   #36
pickup67man
Slight distraction. Our friends were over for dinner and this car came flying down our street in reverse chasing some kids that were on the sidewalk. The driver wasn't looking and hit our friends Jeep Grand Cherokee at about 40 mph. After I chased them for about four blocks (I was on foot) they realized I had their license plate # and came back.[IMG][/IMG]
[IMG][/IMG]
No one was hurt but the kids in the car had to be hurting today.
Travis
Old 09-19-2010, 11:10 PM   #37
pickup67man
It might not look like I did much but it took all day. Finished around the door jamb at the top. Got the pieces from spare cabs so the shape was correct from the door seal to the outside skin. Plug welded the lip for the door seal.
[IMG][/IMG]
[IMG][/IMG]
Front and back door and the B pillar.
[IMG][/IMG]
Back window frame.
[IMG][/IMG]
Close up. Inside corner tough to grind.
[IMG][/IMG]
B pillar with door seal lip.
[IMG][/IMG]
Painted it because the rainy season has started and it is humid. Don't want surface rust to start in bad areas.
Travis
Old 09-19-2010, 11:35 PM   #38
67chevy1series
nice work sorry about those people
Old 09-19-2010, 11:47 PM   #39
VA72C10
VA72C10
VA72C10's Avatar
nice work...really coming together!
Old 09-20-2010, 12:58 AM   #40
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Lookin' good.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
1951 Chevy 2 ton flat bed
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
2008 Chevy Silverado short box 4x4
nickp51chevy is offline   Reply With Quote
Old 09-20-2010, 03:29 AM   #41
swamp rat
swamp rat's Avatar
Hey Travis i gotta hand it to ya, i think what your doing is way over my head and your making some great progress! I see my and your work shop is basicly the same, a 10X20 car cover, pita isn't it!
I need to get some panels replaced in my truck soon but admittedly i little hesitant to start just yet, reading these threads are building my confidance tho...
Welcome from Spanaway! I live close enough to Puyallup S Hill I call that my home. Subscribed!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-20-2010, 06:16 AM   #42
GR8-68
GR8-68's Avatar
very interesting project, but the fab work is looking good
GR8-68 is offline   Reply With Quote
Old 09-20-2010, 05:46 PM   #43
pickup67man
We are neighbors. This is why the suburban is under a car cover. The garage is already occupied. And yes I need new wheels for it, these are very dated. I bought them in 1994 when I was still in high school.
I didn't think I would be able to do it either but I had $100 invested in the suburban so I could afford to mess it up. The car cover cost more.
After 4 years of looking at it I started cutting.
Travis
Old 09-20-2010, 08:44 PM   #44
swamp rat
swamp rat's Avatar
[QUOTE=pickup67man;4200846]This is why the suburban is under a car cover. The garage is already occupied.
Yea mine is occupied too, 3 motorcycles and the 2 small doors arn't big enough to even get my truck inside unless i find smaller tires, but even then if i got it in i'd have to crawl out the window unless i ripped out a work bench and some shelves, that would be a mess. LOL! The good news for me tho is i can cram the bikes to one side and i can utilize a portion of 1 side to do some work if need be.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-20-2010, 11:30 PM   #45
pickup67man
I didn't say my garage was big. The back wall is notched and I back the truck until I hit the carpet that is on the siding. Then I have 1" between the front bumper and the door. I have to crawl out the passenger door to get out of the truck. Watch the video. I tried to link it better but you need to click on the link to see it.
Truck in garage by pickup67man - photobucket
Travis
Old 09-21-2010, 12:05 AM   #46
swamp rat
swamp rat's Avatar
LOL! yea i knew you had a smaller garage from the picks in this thread.. That a clever use of a support beam under that window! tight fit!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-27-2010, 04:22 PM   #47
pickup67man
Worked on it yesterday for about 5 hours and it looks the same. The door wasn't fitting very well. Cut some welds out twisted the door into shape and welded it back together. Did some hammer and dolly work on the skin. The door fits better now. It sits close to the weather strip and the body lines flow well. Also had to rearrange the hinges a little. When I opened the door it looked like it was sagging, but the pivot point was wrong on the upper hinge.
Now before anyone says anything about pics I already said that after all that work it looks the same( at least in pictures)
Travis
Old 09-27-2010, 07:12 PM   #48
swamp rat
swamp rat's Avatar
What no pic's?? LOL!
Heres my latest:
http://67-72chevytrucks.com/vboard/s...=1#post4212828
All that work gave me a craving for a Dons Drive In Double Cheesburger on a french roll (forgot the name) but it was too late and now here i am at work...
Check this link out if ya need parts:
http://67-72chevytrucks.com/vboard/s...2&postcount=72
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-28-2010, 12:20 AM   #49
pickup67man
Those parts would be good but I have the rare 4 door suburban, he is only selling 3 doors.
Travis
Old 09-28-2010, 01:20 AM   #50
swamp rat
swamp rat's Avatar
Ok just found the thread and he's got lots of stuff..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
