#26 |
![]() Join Date: Jan 2002
Re: Source for NOS side trim 1973-1980?????
Ebay- they are deezee- cost $160 delivered brand new in the box!!
2003 2500 HD Crew Cab 1965 GMC K10 1972 Chevrolet k5 blazer |
#27 |
GRAB YOUR CHRISTMAS $$ I got this response from the earlier post!
Upper front fender mouldings, 6260839 and 6260840 $160.00 each Lower front fender mouldings, 6260841, 6260842 $65.00 each Lower door mouldings 475559, 475560 $95.00 each Upper door moulding 475543, 475544 $95.00 each Corner cab mouldings 345124, 345125 $110.00 each upper and lower cab mouldings ( connects door to bed mldgs) 6258145, uses 4 of these $26.50 each lower bed mldg in front of tire for SWB, 475561, 475562 $130.00 each lower bed mldg behind the tire SWB 475581, 475582 $100.00 each upper bed moulding, SWB 475547, 475548 $195.00 each Thanks, Obsolete Chevrolet Parts Co P.O. Box 68 Nashville, GA 31639 www.obschevy.com 1-800-248-8785
#28 |
$1786 plus shipping less cab corner molds LMC looks good to me LOL
#29 | |
Thanks for the warm welcome!
I took one of the NOS pieces that we were able to find with the yellow stripe to my local paint supplier and compared it to the samples in their chip books. I found a color called "Bahama Yellow" in their Dupont fleet color selector that's a very close match. I had some mixed in Nason Ful-Thane 2K urethane and the code # on the can is 7863IB. At least I think the first digit is a 7 ... it got printed partially off the edge of the label. Ray |
#30 |
![]() Join Date: Feb 2009
Thanks Ray!
Any other prep involved after you took off the black? Seems like there wouldn't be enough *tooth* there and/or it would need some sort of self etching base. Airbrushed, or large gun to apply?
-Don- '66 ![]() '77 ![]() '80 ![]() '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf ![]() |
#31 |
Hi Don,
It appears as though the factory paint was applied directly onto the moldings without any primer. However, I too was concerned about the new paint sticking so I did a Google search on "painting anodized aluminum". On one site I found, they claimed the anodized finish is somewhat porous (on a microscopic level) and acts like a primer. But just to be on the safe side, I carefully gave the areas to be painted a light sanding with 400 grit. I did the sanding after masking so I wouldn't accidentally scratch the unpainted areas. The anodized finish is actually quite hard and the sanding didn't dull it down quite as much as I would have expected. So far, it's seemed to work though. It's been a few years since I painted them and it hasn't peeled off yet. I used a regular size spray gun with the fan pattern adjusted about as narrow as it would go. Here's a pic I snapped that shows one of the re-painted pieces (on the bedside) up against one of the NOS yellow pieces (on the tailgate) ![]() I think the Bahama Yellow is a tiny bit lighter/brighter than the original but it was the closest I could find. Ray |
#32 |
Ray- that looks NICE!!!!
#33 |
Ray, just an fyi... your not allowed to post a little teaser pic like that without posting one of the whole truck!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#34 | |
Gettin It One Pice At A Time
RIP ELJAY ![]() ![]() Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
#35 |
anyone every use craigslist for nos chevy stuff??
#36 |
Thanks for the compliment Gary!
LOL Dennis ... I posted a pic of the whole truck in a thread in the Welcome area. But here it is again: ![]() |
#37 |
#38 | |
Conversion Truck Addicted
so ray thats repro trim right?
Thomas Quote:
#39 | |
#40 |
Nope ... its all original GM trim. The majority of it was purchased from the local GM dealer back before it was discontinued (and the prices were still reasonable
![]() Thanks for the compliment Dennis! Longshot379, I wouldn't be surprised if GM used an existing exterior truck color for the stripe on this trim. I didn't bother looking in the older chip books though because my local paint supplier doesn't seem to be very good at crossing some of those old truck code #'s over to modern paint formulas. They couldn't find an equivalent base/clear formula for the #25 "Mariner Blue" on this truck ... just an old acrylic enamel formula. We ended up having them scan the factory paint on the dash and inside of the cab to get a match. |
