Old 12-26-2009, 05:38 PM   #26
Re: LFD's 41 chevy Project "Fill-in"
Another one to watch for sure! Love watching your builds Kevin!
Palf70Step is online now   Reply With Quote
Old 12-26-2009, 05:59 PM   #27
Rokcrln
Rokcrln's Avatar
Originally Posted by 88JRFAN View Post
Thanks Kevin.
The Lincoln Mark VIII is 63 1/2" WMS to WMS. I want to say the T-bird is an inch narrower but I will need to do some work to get that one for sure.
Originally Posted by Puropedo View Post
Thanks, it seems those IRS units will become the next "camaro front clip" additions but for the rear of our projects, and you make them look so good when youre done with them complimenting them a bit further. Great job.
Thanks but wait until you see the one I am going to do for a 34ish Roadster Pick-Up I will be starting in a few months. It will have tubular upper and lower arms and I will be building my own mounting clip that will also be full tubular
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 12-30-2009, 01:24 AM   #28
Puropedo
Kevin
LFD Inc.
Wow!...Sounds superb!...Cant wait to see that one, Ive heard you will be concentrating on hot rods in the future, I just hope you wont forget about us "67-72 truck guys"....
Puropedo is offline   Reply With Quote
Old 12-30-2009, 08:00 PM   #29
70chevytruck
What's your time frame for a build like this? I have been looking for a good truck for so long I may end up just having one built. Oh yeah...what's the goin rate for a restore on a 72 truck back to semi stock?
Great build. Love your work.
70chevytruck
70chevytruck is offline   Reply With Quote
Old 12-31-2009, 01:32 AM   #30
Rokcrln
Rokcrln's Avatar
PM me with more specific details on what you have/want and I can shoot a ball park # from their, but get ready they aren't cheap
Kevin
LFD inc.
Old 01-08-2010, 04:16 PM   #31
kvn1011
Kvn1011
kvn1011's Avatar
I have to be honest, your builds are insightful and your responses and sharing of your knowledge is very much appreciated!!
your builds are better than reading a good book!
Subscribed!
kvn1011 is offline   Reply With Quote
Old 02-03-2010, 10:34 PM   #32
Rokcrln
Rokcrln's Avatar
Been working on the 41 again after waiting for parts.
It is on the ground for the first time tonight and everything looks great. I have 2" of clearance under the chassis when it is aired out and everything turns and rolls great. I have the tanks and both comps plumed and set to turn on at 90psi and shut off at 140psi. The only flex lines in the system are the ones that came pre mounted to the pumps, other than that it is all 3/8" and 1/4" steel bent and flared to fit. So far tonight it has been holding at 138 for the last few hours so we will see how it is in the morning. The rear bags are plumbed and the fronts are still in need of some tube for the bags and brakes and I will work on that Thursday. As soon as the bags and brakes are set I will remove all the wires from the firewall and set the cab back in place for the trans tunnel mock up and steering joints along with the 67-72 tilt column I have for it. Things should be looking good here real soon.
Here are a few pics of it laid out.
Kevin
LFD Inc.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 02-03-2010, 11:04 PM   #33
lolife99
67-72 parts collector,…
lolife99's Avatar
Amazing work!
Old 02-03-2010, 11:18 PM   #34
Number98
Prestige Worldwide
Number98's Avatar
Amazing work!
X2!!
Looking sweet man.... I will have to follow this one as well.
Number98 is offline   Reply With Quote
Old 02-04-2010, 09:29 PM   #35
Rokcrln
Rokcrln's Avatar
Well today I finished up the air system with the front hard lines to the bags and all lines ended at the fire wall and ready for routing into the cab. I also got the adjustable proportioning valve mounted and the rear and drivers front line ran. I will do the pass front line once I pull the motor and then I can drill and tap all the line mounts to the frame at the same time. I am running manual paddle valves in this from AVS and I was really pleased with how fast they inflate for a 1/4" system. I get 8" of overall lift out of the system and I am really looking forward to the first test drives in this truck. I set the cab back on the chassis so I can start the floor board mods to clear the trany hump and smooth off the firewall once I decide were all the wires will hide and A/C will run and what not. Also it will be getting a 1 piece hood that will open in the front so I need to build the hinges and the hood support for everything to mount to. Once the truck is ready to run and drive I will pull it all back apart and send the chassis off to powder coat and paint the misc parts. Then since I will have every system complete and sitting on the shelve it will go back together real easy with minimal work, I hope
Kevin
LFD Inc.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 02-04-2010, 09:52 PM   #36
suville
suville's Avatar
Got room for another observer? Thoroughly enjoy watching craftsmen at work. And I luv the older GM trucks as much or more than the 67-72 but boy they are hard to find now days used to have a 35 and wish I had kept it! I'd probably trade my Harley for a 37!
suville is offline   Reply With Quote
Old 02-05-2010, 05:29 PM   #37
GREASEMONKEY72
GREASEMONKEY72's Avatar
thats one hell of a nice chassis
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 02-05-2010, 07:32 PM   #38
Rokcrln
Rokcrln's Avatar
Few more pics with the body and floor mods. Now it is time to start the 1pc hood.
Kevin
LFD Inc.
Old 02-05-2010, 10:18 PM   #39
70stroker
70stroker's Avatar
stance looks awesome
70stroker is offline   Reply With Quote
Old 02-06-2010, 01:02 AM   #40
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Bad arse....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-06-2010, 10:45 AM   #41
caja_larga
when you use a flex like you did with the exhaust does that allow you to mount the muffle solid or does it serve a different purpose?
caja_larga is offline   Reply With Quote
Old 02-06-2010, 12:25 PM   #42
Rokcrln
Rokcrln's Avatar
Yes for the most part you can mount solid from that point back. On this one I still used a flex type of hanger but several of them pulling in different directions to really hold it in place. They also help keep header flange leaks down to a minimum.
Kevin
LFD Inc.
Old 02-06-2010, 06:28 PM   #43
64shortc10
64shortc10's Avatar
Not as low as your little boys F**D but it still looks pretty SICK! You make it all look so easy! I'm glad I don't live to far I can come check out the progress in person! Keep up the good work Kevin. What a difference between this setup and the death trap subframed stock chassis it came to your house on! Later
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 02-06-2010, 07:40 PM   #44
68jewel
On the path to financial ruin!
68jewel's Avatar
Good, goobidy, goo!! This is some fancy work. LFD is definitely doing it when it comes to quality work. More pics of the Tahoe too, please!!
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS
'68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame
Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280
68jewel is offline   Reply With Quote
Old 02-07-2010, 01:16 AM   #45
Rokcrln
Rokcrln's Avatar
A bit more hood work today. I started by removing the center hinges and then tack welding the hood to the truck to hold its shape and placement. Then the tig welding started all 6+ feet of it. After the welding was done and some of the hammer work roughed in as well I started on the second skin for the new hinge mounts. In the morning I will turn the flat second skin into a structural piece that will allow the hinges to be mounted to it and give the hood some much needed rigidity.
Kevin
LFD Inc.
Old 02-07-2010, 01:29 AM   #46
phipp13
THE DAMN YANKEE
phipp13's Avatar
sweet fab job!!! subscribed
phipp13 is offline   Reply With Quote
Old 02-07-2010, 04:36 AM   #47
38chevyhotrod
38chevyhotrod's Avatar
The hood looks great, did you fill the gap of the hinge with a flat strip?
I also welded my hood(38 pickup) together but that did not came out that well.
After some struggling and patching it with a new piece of flat metal i got it straight now.
Could you make a closeup of the weld?
A have another truck(42 pickup) waiting that i want to do the same thing on.
But I'd rather do it right the first time.
Anybody can restore a classic, takes a man to cut one up.....
http://www.arnoldscustoms.com
38chevyhotrod is offline   Reply With Quote
Old 02-07-2010, 08:17 AM   #48
nuke1
nuke1's Avatar
looks good kevin. I really like your trans cover, mind me asking what you did to make that?
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-07-2010, 01:08 PM   #49
Rokcrln
Rokcrln's Avatar
What I did was rolled the 90* hinge mount back to flat the then over lapped the two sections of the hood back on the truck. I then scribed the line I wanted to cut and just but welded them together. This way I only had 1 weld to do, as were if I added a strip I would have 2 welds the length of the hood. Now this only works if the hood is in great shape. If it has already started to crack along that edge then you are out of luck because it will keep cracking once you are done.
English wheel, shrinker/stretcher and a power bead roller and about 30 min in time.
Kevin
LFD Inc.
Old 02-08-2010, 12:14 AM   #50
Rokcrln
Rokcrln's Avatar
Not finished yet with the hood bracing but it is getting close and this will give you the idea of what I am doing. I made the hinges along with a friend of mine who needs the same set up for his 45. So I designed them and he built the hinges (2 sets) and in return I will make his bracing for his hood. I have already 1 pieced his hood for him.
So I made a mounting brace then the hinges mount to under the dash and a sheet metal brace for the hood. I will make a few more braces for the hood that will run front to back along the sides to take the stress of the gas struts. I used 2 gas struts under the dash out of a 2000 explorer hood hinge. They only have 2 1/4" of movement but are super strong and seem to work real well.
Kevin
LFD Inc.
