12-07-2009, 02:48 AM | #26 |
Gone to greener pastures
Re: Code Blue! She's down! 911!
Quick & Dirty:
Roll the engine until the harmonic balancer/timing mark is at 0 degrees. Pop the distributor cap. If the rotor is not pointing at the #1, or #6, terminal then most likely the timing chained has slipped and your cam (& ignition) timing is out the window. Then you can go from there.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck Last edited by El Jay; 12-07-2009 at 02:49 AM. |
12-07-2009, 11:18 AM | #27 |
Ditto what LJ Said. While you have the cap off use a socket to turn the crank clockwise until the rotor moves. Now turn the crank in the opposite direction and note how many degrees you have to turn it before the rotor moves. This will tell you how much the chain has stretched.
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 12-07-2009 at 11:20 AM. |
12-07-2009, 11:59 AM | #28 | ||
Size Matters
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ...WOOOO HOOOO!!!! |
12-07-2009, 08:48 PM | #29 | |
Use that test as just one part of your troubleshooting. If it only moves a couple of degrees I'd start looking somewhere else for the issue. If it moves several degrees it may be loose enough to jump time.
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 12-07-2009 at 08:49 PM. |
12-07-2009, 09:59 PM | #30 |
Gearhead and audio junkie
Oh boy, this reminds me how my old engine left this world, went for a quick romp around town, idle back in, engine makes bad noises does the whole coasting thing and she was kaput, sad thing was it wasn't going more than 15 mph! I sheared my entire timing gear, piston kissed valves and the highest compression i could coax out of a cylinder was 80 psi, it was a bad day, but hey it was a great excuse for a new engine
12-08-2009, 09:56 AM | #31 | |
Size Matters
08-27-2014, 10:30 PM | #32 |
Size Matters
Soooooo....a mere 4 years and 8+ months later.... It's running again! Now for some tweakin, adjustin and such. Brakes are down (duh), radiator cap was squiting a lil when I was trying to get it running (weird?), STILL needs more tranny juice (6qts so far), needs exhaust, blah, blah, blah. I'm just happy to report that it actually moved under it's own power (into the garage...still gotta get the timing and mixture set). How's that for the slowest fix for a slipped timing chain ever??
08-27-2014, 10:34 PM | #33 |
lmao.
I started reading this and thought...... the date on this...... somebody accidently drug up an old thread....... then .... omg. I understand. well... glad to see you didnt give up all together! |
08-27-2014, 10:42 PM | #34 |
Hey man, its not a race, its a marathon! Right? Youll get it, keep plugging away..
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
08-28-2014, 08:50 AM | #35 |
Size Matters
To be fair, I did fix more than the timing chain. Complete re-build and general clean up of the engine bay. I know, I know...that still doesn't normally take almost 5 years. What can I say, I'm slow. Life got in the way. No time, no money, blah, blah, blah....
08-28-2014, 09:36 AM | #36 |
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
08-28-2014, 09:54 AM | #37 |
Old member
Glad you gotter done man! Hope to hear it in person really soon. Ha!!!!
08-28-2014, 06:48 PM | #38 |
So did you find anything broken in the engine?
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. |
08-28-2014, 09:36 PM | #39 |
I don't believe it.
Congrats on getting it going. |
08-29-2014, 08:44 AM | #40 |
Size Matters
The timing gears were very worn but really nothing was completely broken.
08-29-2014, 08:45 AM | #41 |
Size Matters
I'll get on the pics ASAP.
08-29-2014, 09:43 AM | #42 |
Size Matters
Before shots.
And one of my helper!
08-29-2014, 09:52 AM | #43 |
Size Matters
And now....
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ...WOOOO HOOOO!!!! Last edited by Longhorn321; 08-29-2014 at 10:09 AM. |
08-29-2014, 10:02 AM | #44 |
I'd say the chain slipped. I've only seen one other on a Chevy V8 and it bent the valves. Consider yourself lucky it wasn't worse.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
