#26 |
Re: Normy71
Tony!
I purchased most of my repair sheet metal from Scotts super trucks in Penhold Ab. Not sure what the price was?
Rolled the dice and lost!! ![]() Check Out my 71 build http://67-72chevytrucks.com/vboard/s...d.php?t=375158 |
#27 |
Re: Normy71
I new it!! I'm a 10 minute drive from him; wouldn't deal with anyone else.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
#28 |
Re: Normy71
That's nice and handy for you!
The shipping sucks but the service is great next day to me .
#29 |
Re: Normy71
So are you going with a 5.3L... If so where are you going to get one.\
Trevor
1968 short box stepside. 2007 5.3L 4L60, tuned w/EFI Live 2005 Silverado bucket seats. Dominator 2600's all around. Porterbuilt tubular control arms. Magnaflow 3" dual exhaust. |
#30 |
Re: Normy71
tk
I'm still looking for a 5.3 L33 DBW and 4l60 2 wd trans. There are a lot of 4wd trans around but the 2 wd are harder to find. I'm trying to make a deal on one threw SGI our government wreckers, but they strip them completely down then try to sell them? which is crappy for us custom builders. Any leads on a complete engine/trans?
#31 |
Re: Normy71
I got mine complete with everything with under 50 miles on it from Schram auto. They have an ebay store.. I payed $2200+$800 shipping. I talked to several wreakers around here and the one (Reg's) wanted $4500 for a 6.0L/4L80 set with over 200,000km on it and he wasn't sure if the trans worked..
Trevor
#32 |
Re: Normy71
And that was a 4x4 trans converted to 2wd. too.
#33 |
Re: Normy71
Was that Us$ ?
#34 |
Re: Normy71
tk
Do you have a build started on your 68 ?
#35 |
Re: Normy71
That was US$.. I don't have a build thread on my truck.. I bearly have time to work on it let alone make a build thread... I would love to make one though.. Specially to help others like this forum has helped me..
#36 |
Re: Normy71
Us Canadians gotta stick together!!! We're savagely out-numbered here.
#37 |
Re: Normy71
Found a Engine today a 2007 DBW 5.3 L33 with 55 Km and a trans and hopefully all the goodies I need?
What I did get was the -Alternator power steering pump and bracket -starter and bolts -flywheel -Harness /data port & computer / DBW Pedal I think I got the wrong engine cover? I got some sort of wiring harness? looks like I even got the tail lights! I still need a few bolt and odds and ends. Where to start? Help!!
Rolled the dice and lost!! ![]() Check Out my 71 build http://67-72chevytrucks.com/vboard/s...d.php?t=375158 Last edited by Normy71; 12-18-2009 at 11:15 AM. |
#38 |
Re: Normy71
what I did first was strip the harness. If you are going to do it yourself take all of the pins out of the PCM connectors, label them first C1 or C2 and which terminal. Then you have all of your connectors. Start plugging in the sensor connectors and run the wires the way you want then to go.. Decide where you are going to mount the PCM and cut your wires to length and start putting the terminals back into the PCM connectors..
Have fun.. Trevor
#39 |
Re: Normy71
Some more pictures of the drivers side rocker install.
I still need to flip the cab up and weld from underneath But I will wait until I finish the other side. I'm sure glad I braced up the inside of the cab hold everything in place with all the cutting.
#40 |
Re: Normy71
I also got the frame all welded up. I still need to dress up some of the welds it turned out very nice.
I cheated and had a welder friend come over for a visit and handed him the welder! Thanks Bud!!
#41 |
Re: Normy71
I also picked up some wheels not sure how they are going to look?
My plans are to put 275/60/15 on the rear and 255or235 /60-15 on the front They look good as I have learned from this site. I would like some bigger wheels but see what I can come up with in the future.
#42 |
Re: Normy71
Very good weld penetration; you can be confident there. Lookin good!
#43 |
Still Learning
Re: Normy71
I will be watching this one too. I had the same feeling when I picked up our 4.8engine....where do I start? So, I just haven't started on it yet. I have other fish to fry first.
#44 |
Re: Normy71
Man for somebody thinking that you have been putting something off for a long time, and better start a biuld thread, you sure are going at it hard now. Great progress. Keep it up you'll be crusing this spring in it.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
#45 |
Re: Normy71
Every time I head out to the shop the first thing I see is this long box sitting and waiting to be cut down.
I've got a long way to go!!
#46 |
Re: Normy71
One step at a time and it will get done!
#47 |
Re: Normy71
Got a few things bolted on and still working on the power steering pump pulley!
I had to pull the pulley off to change the install brackets,and my puller installer tool is not metric as required to install this back on, what a pain in the #$$. (I bet the designers are still laughing about that one...) Now I need to find a 10X1.5mm bolt or better yet 10X1.5mm x3/8 in stud so my installer tool will work. That's why it is good to walk away from it for a while..
#48 | |
![]() Join Date: Dec 2009
Re: Normy71
I got everything including all the accessories, computer wire harness, fuse box, starter etc. Let us know what things you are needing to get or modify for your build. Good luck
68 c10 350/th350 winter daily driver 90 Nissan 180sx, sr20det gt2871r turbo, track car,summer daily driver "Just so we are reminded of those who are held back, Up front there ought to be a Man in Black". Johnny Cash. |
#49 |
Re: Normy71
6D8
That's a big list. The next thing on my to order list is engine mounts. I will prob make my own trans mount. I have to clean up my frame and put the front end back together. Touch up the frame paint/ pull the C notch off and paint it. I'm just taking it slow
#50 |
Re: Normy71
do you know the lokar part number for the shifter cable for our trucks and a 4L60 trans..
Trevor
