Old 02-21-2010, 01:50 PM   #26
msgross
msgross's Avatar
Re: I think my truck is trying to tell me something
you have a 69 K-10 with a 454, 1 ton axles, huge off road tires and you are worried about OVERKILL???
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-21-2010, 05:19 PM   #27
Yukon Jack
Post Whore
Yukon Jack's Avatar
Oh man you having me laughing!!!!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-21-2010, 05:41 PM   #28
msgross
msgross's Avatar
wait it's a k-20, that makes it average! lol
The Garage:
Old 02-22-2010, 01:24 AM   #29
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
I'm using the ORD high cross over steer kit and love it..quality is very good. I got a great deal on mine but otherwise yes there are kinda pricey! I have ran 60s in about 5 different trucks now and always replace the springs and poly king pin bushings..never had the death wobble yet..and I dont even run a steering stabilizer in my extended cab K-30 after doing the crossover..and you can run down the road at 75 mph with one finger on the wheel!
I hadn't heard of Ballitic till you mentioned it..just checked out there website and looks like some awesome stuff to me..and yes it would be hard to beat those prices. I do believe you would be ahead with your heavy tire wheel combo to go with the springless kit...either way I believe you will love the outcome after going crossover..with the amount of lift you have I would consider it a necessity not overkill.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 07-07-2010, 10:02 AM   #30
Luba
Luba's Avatar
Yukon- I got a question. so do you have to use stock Dana 60 front spring plates to mount this? I thought you had bought some superlift ones? I have a chevy 60 that I will be putting in the front of my 72 k5 blazer and need some plates. Just want the right ones.
Luba is offline   Reply With Quote
Old 07-07-2010, 10:06 AM   #31
Yukon Jack
Post Whore
Yukon Jack's Avatar
Use the Dana 60's spring plates. I bought a bolt kit from Superlift - ended up that the supplied studs were too long so I used bolts.
Old 07-07-2010, 10:52 AM   #32
Luba
Luba's Avatar
Thanks Yukon looks like I need spring plates then.
Old 07-12-2010, 12:10 PM   #33
Yukon Jack
Post Whore
Yukon Jack's Avatar
A number of websites sell custom Dana 60 spring plates if you have trouble finding a pair of factory plates.
Old 08-23-2010, 08:45 AM   #34
67chevy2wd
67chevy2wd's Avatar
What steering combo did you end up going with? I am looking at upgrading the steering on my 71 GMC. The factory steering setup isn't working and I plan on installing a 8" lift yet.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 08-23-2010, 08:50 AM   #35
67chevy2wd
67chevy2wd's Avatar
Also on ORD I see it said you needed a 2wd steering box. Did you have to use one?
'71 GMC 3/4 ton 4x4
Old 08-23-2010, 09:13 AM   #36
Yukon Jack
Post Whore
Yukon Jack's Avatar
Regardless of the manufacturer of crossover kits, they all require a 2wd steering box. I haven't had time to do crossover yet but at this point I'm leaning heavily towards Ballistic Fabrications setup. Probably do this in the fall.
