#26 |
Re: 5.3 Guys need some help on engine /trans mounts
I am using transdapt LSx plates with stock poly mounts with stock perches stock trans Xmember. F-body rad and fans.
Brother is using POL mounts and Xmember. made his own adaptor plates and using stock rad with stock fan and shroud. I am using the Abbot Cable X box to run my stock speedo, can ship them for $300. I do my own tuning and offer mail order tuning. Using DT swap headers, currently about 2 wks out before DT has them out ready to ship. I am using a Lokar shifter "rod" and brother is using the other Lokar cable style shifter linkage. both work. I am not able to go past 3rd due to angles of the way it is mounted. the cable style will allow you to reach 1st and 2nd but most of the time one does not need to actually get to those gears but some might want to.... Let me know if you have any more questions and I will do my best to help.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap Last edited by Shon; 12-21-2009 at 10:39 AM. |
#27 |
![]() Join Date: Dec 2009
I got a question if you don't mind me stealing your thread.
I got a 5.3L from a 99 silverado. With the mounts that you guys are talking about, does it put the engine in the "stock" location? I see where you talk about the mounts allowing you to set it forward or back. The reason I ask, if I kept stock trans (th350) or went with a non-electric overdrive, will it match up to it, or will I have to move the trans forward or backwards? Thanks
68 c10 350/th350 winter daily driver 90 Nissan 180sx, sr20det gt2871r turbo, track car,summer daily driver "Just so we are reminded of those who are held back, Up front there ought to be a Man in Black". Johnny Cash. |
#28 |
The adpt plates let you use the stock mounting location
but the engine has a different foot print. The th 350 should match up but not sure what you need to do to make it work? I have read about doing that on this site some place. You should be able to use the stock trans mount with out a problem, as long as your engine mount angle works out.
Rolled the dice and lost!! ![]() Check Out my 71 build http://67-72chevytrucks.com/vboard/s...d.php?t=375158 |
#29 |
Back to the 5.3 Mounting question.
Anyone else use the 5.3 stock mounts to adpt to the frame of a 71 GMC? Thanks
#30 | |
#31 |
LS1nova71
I like how you did your TAC module!
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
#32 |
I never thought to get the frame stands off the 2007 truck!
#33 | |
Always wrenching!!
![]() The fans are stock LS1 camaro/firebird/corvette 98-up. i trimmed the lower part of the fan to fit into the stock 71 fan shroud mounts then made plates that screwed into the upper fan shroud mount. ![]() The steam line, my 71 radiator had an extra nipple in it so i ran the steam line to it..... pic below ![]()
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
