Old 12-12-2009, 12:11 AM   #26
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: Speedwarning Complete.... with Video
anytime Trev! you name it.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 12-12-2009, 10:42 PM   #27
into69z
"brand new second-hand"
into69z's Avatar
Doug:I took the speedminder out tonight and tested the continuity as you described(i think!) anyways, I hook a lead to the white wire that comes off the speed face(back side) and grounded the other lead to the speedo base(the metal housing that holds the odometer) and nothing!. Then I touched the needle nib that is fixed to the s.w. white arrow and I had continuity without moving the speedo (red)needle. I was still hooked to the white lead-grounded the other lead to the odometer housing and moved the orange needle and nothing-no continuity. I then tried for continuity with the spring under the orange needle-nothing. Is there anything else to check? I may have to take you up on your offer and have you check it out but if I can fix it myself, I will maybe learn more...by the way you did a great job on your dash set!.....thanks Steve
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 12-13-2009, 12:08 AM   #28
pmpski_1
pmpski_1's Avatar
Cool. Great job!
pmpski_1 is offline   Reply With Quote
Old 12-13-2009, 12:39 AM   #29
tcb-1
tcb-1's Avatar
Steve, you just pay shipping and I would be happy to look at it for free. It's got to be something small.
'bout time for me to head to bed, but I'll think more about your problem and post tomorrow.
before I go, can you remove the speedo from the tins so you'll have it in your hand tomorrow?
Doug
Old 12-13-2009, 09:23 AM   #30
into69z
into69z's Avatar
Doug-done......hopefully you have an idea....steve
Steve
67 Camaro
96 Impala ss-sold
b69:
Old 12-14-2009, 10:09 PM   #31
into69z
into69z's Avatar
Doug-I got it working thanks to your post......I forgot to ground the speedo base-once that happened the buzzer worked fine. The next question is: I have a tach dash and a speed warning dash and I want to combine them. Should I use the speed minder dash and cut it for the tach or should I drill the tach dash for the speedminder? How do you get the stud off the speedminder dash? Anything else I should think about? thanks again..Steve
Steve
67 Camaro
96 Impala ss-sold
b69:
Old 12-14-2009, 11:10 PM   #32
tcb-1
tcb-1's Avatar
Steve,
I guess it would depend on how original you would want it to look/appear.
With that being said, the speedwarning tin is only original once...... and it's rare in it's own right. A tach tin isn't as rare, so I'd be more inclined to modify a tach tin to include some type of grounding post. Remember, the post has to be completely isolated from the tin. You could simply drill a hole through the tin, place a rubber grommet in the hole, and make your connections that way. That would also mean a bit of modification on the harness ends, but that is a way to do it.
If your going for a factory correct resto, you may take the s.w. tin to a few electronic supply houses and see if they can locate a grounding post?
Good luck and keep in touch!! I want pics when you start your resto!!
Doug
Old 12-14-2009, 11:29 PM   #33
DREW67
DREW67's Avatar
Great Job Doug
DREW67
DREW67 is offline   Reply With Quote
Old 12-16-2009, 03:22 PM   #34
msgross
msgross's Avatar
ttt
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-20-2009, 09:48 PM   #35
Conroe trucker
SWBs: 67 2x4, 67 4x4, 70 4x4
Excellent piece. Gotta have one now.
FINISHED Project thread: 67 SWB 4x4
FINISHED Project thread: 67 SWB 6 cyl cruiser
Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT
01 C5 convertable
08 Z06
Conroe trucker is offline   Reply With Quote
