#26 |
Re: Old gas disposal
Buy a bunch of cat litter, pour it into a bucket then pour the gas into it. Keep doing the process untill all the old gas is gone, The you can take the litter to the dump.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
#27 |
Man, that is news to me, didn't know you could do that with out a big explosion
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#28 |
we use to mix it with diesel and burn poop... yes I said poop.. just another reason to "JOIN THE AIRFORCE!"
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#29 |
its all about the +6 inches
you can pour gas on the ground and light it... it won't explode.
Without compression, you only get a fireball... not an explosion. I frequently burn off what ever I spill (example like a carb swap) in the yard in a hubcap or something. Been doing it for 20 years, never an explosion. ever. Last edited by Longhorn Man; 12-11-2009 at 11:03 PM. |
#30 |
Put it in a bag and huff it.
I'm not as good as I once was, But I'm as good once as I ever was. |
#31 |
Active Member
I just went thru this - I called my local recycling center - they pointed me to a company about 20 miles away that takes it for free.
The recycle oil and fuel at this company- just show up and dump it into a big pit - in and out in under 5 minutes
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
#32 | |
#33 |
Moderator
![]() Join Date: May 2007
![]() ![]() ![]() Pour it on some concrete. It will evaporate.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 12-12-2009 at 12:42 AM. |
#34 |
actually not a bad idea. I have an old sheet of scrap plywood that I pour old paint that I want to get rid of on and let it dry. Just put what ever you pour it on way away from the house and garage. Pour it a little at a time so that it has time to soak in and or dry.
from past experience it will mess up a set of valves in an engine real quick. |
#35 | ||||
mini truck racer
Again the smell. Quote:
![]() I have bought an old truck that has been sitting for 11 years and i intend to remove the fuel tank before bringing it home as the fuel is horrible . I'll probable at this point pull the tank and drain to a gas can marked old gas . Add some diesel to the tank and wash it around to try and get as much as posssible , then dispose of the tank through the metal recyclers and dispose of the old gas after contact with the city . Great ideas and some really sound advice .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 12-12-2009 at 11:38 AM. |
#36 |
I been dumping a gallon in the car, then fill the tank, it mixes well like 15 gallons of mid grade and one gallon of old. also add a bit of outboard motor oil for lubricity
#37 |
Throw it up in the air as far as you can and run away really fast.
#38 |
