01-31-2010, 10:56 PM | #26 |
Re: 1949 3600 build
I plan on a MII manual rack. Been sick and busy with work most of January. Hope Feb will be better for work. I have found that I am going to notch the bottom of the frame to raise the unit (lower the truck).
Some parts came from my brother, the cab, frame & box are old ND farm truck from a friend near Canada. Last edited by T Hilde; 01-31-2010 at 10:58 PM. |
05-16-2010, 09:24 PM | #27 |
Re: 1949 3600 build
Wow, been real lazy about updating this. Crossmember is welded in and motor mounts have been made.
I even modified the 292 valve cover to a Cadillac motor. |
07-15-2010, 04:13 PM | #28 |
Re: 1949 3600 build
Any updates on this? I've got an email in to Scott Danforth for some info and pricing. This looks like a good fit for my project.
07-15-2010, 06:32 PM | #29 |
Re: 1949 3600 build
Not yet, I have a friend interested in the chassis. There is some head scratching going on with it yet.
07-15-2010, 10:37 PM | #30 |
Re: 1949 3600 build
What kind of 5 speed is that? At first I was thinking NV3500, but yours looks different somehow. Also, how did you handle the clutch linkage, which I assume needs to be hydraulic?
Ray |
07-16-2010, 02:05 AM | #31 |
Re: 1949 3600 build
The generation before the NV3500, from a full size Chevy. It is a hydraulic clutch but haven't worked on that part yet.
07-16-2010, 05:32 AM | #32 |
Re: 1949 3600 build
Thank you for explaining about the tranny. Btw, your valve cover is a real eyeball grabber.
Ray |
11-14-2010, 03:11 AM | #33 |
Re: 1949 3600 build
You have a friend interested in the chassis? Are you selling it? Head scrathing? Is the the ride higth not low enough when using this cross member? I am considering this front end but I will be using air ride and want to be able to drop the air out and put the running boards almost on the ground. I wonder if the wheel stance or width is wider then using a MII. Thanks!
12-19-2011, 06:25 PM | #34 |
Re: 1949 3600 build
Any updates on your truck, is it on the road yet?
Is Scott Danforth in full production yet, as I have some questions on his front end
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
12-19-2011, 07:47 PM | #35 |
Re: 1949 3600 build
I bailed on this chassis. It irritated me. I swapped it on to a dakota chassis. I have a lot of questions on it too. You have to notch the frame for the upper control arm, if you don't want a huge notch you need tubular A arms and still notch it. The steering isn't sorted out on it yet. The one I know of that hit the road has a turning circle like a large truck. Bottom line, I wished I never bought it.
