Old 01-06-2010, 08:08 PM   #26
Critter
Future TOTM Winner
Critter's Avatar
Re: Looking For Blazer Frame Dimesions
Right click...SAVE IMAGE!
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 01-06-2010, 10:52 PM   #27
Wasted Income
Boosted Member
Wasted Income's Avatar
Originally Posted by vtblazer View Post
very cool, thanks.
Anything like this available in the 4x4 version?
What are the differences between 2wd and 4wd frames?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-07-2010, 12:54 AM   #28
Rod
But we can't do this all day as the pitchman say. Here you go: 1971 4x4 Blazer frame dimensions. Rod
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 01-07-2010, 07:14 AM   #29
vtblazer
vtblazer's Avatar
Great, thanks again.
vtblazer is offline   Reply With Quote
Old 01-07-2010, 01:29 PM   #30
Wildstreak
"something witty here"
Wildstreak's Avatar
definitely
Do they have these for shortbox 4x4, I think my frame is bent or twisted and need to find original measurements.
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 02-22-2010, 11:18 PM   #31
notsolo
notsolo's Avatar
Thanks Rod for posting both frame dimensions, this helped me get proper trailing arm placement on a 4x4 blazer frame, I have looked thru many posts and not found these critical measurements...Thanks again....Ed
notsolo is offline   Reply With Quote
Old 02-23-2010, 01:28 AM   #32
addicted2dunes
Insane In The Membrane
addicted2dunes's Avatar
This is what I've found for 4x4
addicted2dunes is offline   Reply With Quote
Old 02-23-2010, 01:29 AM   #33
addicted2dunes
Oops, already been posted.... helps if I look at the second page huh.......
Old 03-01-2010, 03:59 PM   #34
Rod
That's Good that it helped you out notsolo. Glad to see it made it a useful thread for yah.
Old 07-15-2013, 03:32 PM   #35
RideSF
Anybody know the weight of a 2wd blazer frame?
RideSF is offline   Reply With Quote
Old 07-15-2013, 03:34 PM   #36
RideSF
Without front x member.
Old 07-24-2013, 04:34 PM   #37
ckato4477
has anyone ever found the 4x4 shortbed dimensions? I'm trying to figure out how different the rear mounts are from a k5 frame
ckato4477 is offline   Reply With Quote
Old 07-25-2013, 04:53 AM   #38
taotaoali
You clearly know what you are doing, you’ve covered so many bases.Thanks!
taotaoali is offline   Reply With Quote
Old 03-09-2014, 02:52 PM   #39
smbrouss70
smbrouss70's Avatar
I know this is an old thread, but I have to ask...
Rod do you remember where you found these images? I'm wanting to see the measurements that were cut off on the top, like what I attached which is for a 2wd short wheelbase frame.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 03-09-2014, 03:33 PM   #40
Rod
Factory Assembly manual.
Check your pm.
Old 03-10-2014, 09:32 PM   #41
smbrouss70
smbrouss70's Avatar
Thanks!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 02-14-2016, 09:48 AM   #42
Bob Sacamano
Bob Sacamano's Avatar
Here is a 2wd spec sheet for frame dimensions for a 1971 2wd Blazer.
FYI 4x4 frame specifications has some dimension differences.
Hello there!
Any chance you'd have one of these for a '36 Chevy? I've been looking for a while, and haven't had much luck so far.
Thanks.
Bob Sacamano is offline   Reply With Quote
