#26 |
![]() Join Date: Mar 2008
Re: Air Ride Install - '69 Chevrolet SWB Stepside
Looking good Doug. I need to come and check it out sometime.
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
#27 |
Between Trucks...
Lookin good Doug. Subscribed.
Beat it to fit, Paint it to match... ![]() |
#28 |
Nothing to see here.....
![]() Join Date: Jun 2007
was visited tonight by a box full of SMC valves from suicidedoors. first off, let me say that ***************** is a great place to do business with. I ordered these valves Monday, and here today and packaged well...... and I stole them @ $22 a piece. brand new, still in the factory bubble wrap. so now I have......
![]() I removed the front springs tonight. here's a tip. if PB Blaster doesn't work to get the taper fit free, try a propane torch. only heat the spindle body, not the ball joint studs. the heat will expand the female taper fit. works like a charm eerytime I remove ball joints. Chris, I plan on checking the front cups (drop ins) for fit and finish. I am also completely cleaning the front suspension as well as I can until I can put it on a rack. (hint hint scottrod?!) got to thinking tonight about a "backup" in case the compressor failed. I may put a tee on at each bag and run a Schrader. bad luck tends to follow me, so anything to increase my odds in the other direction, I should explore.
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 12-23-2009 at 10:41 PM. |
#29 |
Mean Buzzin' Half Dozen
Looking great, I can't wait to see how this progresses.
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale) 1967 C10 SWB Dylan |
#30 |
Nate,
I used Rustoleum Industrial OIL based enamel in flat black in a can. it goes on smooth, self levels, and after dry, is fairly tough, especially when brushed on. I was going to use POR15, but that stuff does NOT come off..... and eventually, I want the frame completely blasted and powdercoated. but for now, this is a viable choice that will come off under normal media blasting. I highly recommend the Rustoleum for normal underbody protection!!
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
#31 |
Sounds like the balljoint delema is solved, another way to do it is loosen the castle nut half of the way on the balljoint and while the joint is under spring load take two 3 lb hammers, one is held tight against one side of the spindle at the joint mounting and then the other hammer stikes the opposite side of the spindle temporarily oblonging the hole and releasing the two, make sure from here the spring is unloaded again before the nut is removed, usually works first or second hammer blow.
Like the project, subscribing.
........................ ..........._____|__\___ ..........|_(O)_____(O)] |
#32 |
got to hook on
bogey5 |
#33 |
the rear install is pretty much bolt on. The front depending on how you do it is a little more demanding. Good Luck and you will want to go lower it will be just a matter of time. As far as a back up to the compressor put the schrader valve on the tank.
I sent you a pm also
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black ![]() Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride Last edited by firedog; 12-24-2009 at 11:05 PM. |
#34 |
Tot Roddin'
Okay Doug... what pieces did you unwrap this morning?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#35 |
how did you guess, Nato??!
got rear shock relocators (ECE) and front bag bracket/cups.
#36 |
Tot Roddin'
Awesome!
#37 |
Texas Big Wig
Gonna be sweet man
I have some dodge 17" wheels like yours, but never wanted to re-drill my axles & stuff for them to fit As for the bags, I would buy the Slams... I have both & the Slams look much better made As for the back up, I put a schrader on my tank as well |
#38 |
spray bomber,
if you have a 67-70 truck you want to go 17" steelies on, these will work straight outta the box. they are Toyota FJ Cruiser rims, 17" x 7.5" wide on a 6 x 5.5" bc. I'm running a .75 spacer on them now, but once the truck is lower, I may remove them to tuck in better. I've always liked your builds! thanks for coming by my build. my truck will still look like a 4x4 compared to some of your rigs!!! ![]()
#39 |
Official Site Guitar Shredder
Doug awesome dude...You know you have my favorite truck of all time...Now you are going to make me get a 2nd job and put sweet pea on air huh? awesome dude.......Cannot not wait to see it.........
#40 |
![]() Join Date: May 2009
Doug looking gooood
#41 |
dazed and confused
looking good! subscribed!
members met: redbaron69, billsbowtie,nc67 |
#42 |
starting on the bolt on upper bag plates tonight. made my own drill bit to get to one of the holes.... call me McGyver!
took my suicidedoors drop in bag cups in this afternoon to get a shave. I estimated 5/8" off the total height would be good. I'll get pics soon of my progress. and.... thanks guys for the kind words. I hope I won't disappoint!
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 12-28-2009 at 11:44 PM. |
#43 |
Under Construction
looking good Doug!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#44 |
got a little done over the past couple of nights. I also ordered my bags. with a lot of thought and with suicidedoors recommendations, I went with Airlift Dominator D2600's. can't wait 'til they show up on the doorstep! thanks again suicidedoors!
first, I took my drop in lower bag cups to my fabricator and had him cut them down approximately 5/8". they seem to sit perfect now. 5/8" doesn't sound like a lot, but it actually is when your trying to get as close to the floor as you can. here's the look of the cup in the pocket: ![]() you know, specialized tools are expensive, but my God, they are so worth it. I even cut down a drill bit, and made my own short length bit. when you have to get something done, nothing should stand in the way...... ![]() nothing's more beautiful than a cab full of new parts..... ![]() and for the grand unveiling..... in this pic, I raised the entire assembly up to when my tire was touching the inner fender. I measured and I still have about a inch to play with if I decide to ditch the inner fenders. but for now, this is where I'll dial the front end to..... ![]() and lastly, this is where I would be without inner fenders.. and without a tire: ![]() the first place I head to after we get back on the road is my muffler shop!! may have to modify the crossmember, buy a CPP unit, or drop out right under the cab. oh well, that decision for another day. and before I wrap up this installment, I want to thank LOLIFE99 for giving me the kick in the pants to go on air. Keith is a great guy and knows his stuff. I owe you....... hope everyone has a safe and an enjoyable New Year!!!
#45 |
![]() Join Date: Jul 2006
Looking good! Are you talking about the trailing arm or transmission crossmember?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#46 |
Leevon, should have clarified... the trailing arm cross member.
#47 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Great Progress Doug! (Thanks for the kind words also)
If you decide to get a trailing arm crossmember,... DEFINITELY get the Porterbuilt unit. http://porterbuiltstreetrods.com/site/?p=178 These are by far, the nicest ones out there. (I just happen to own one now) Plus, they have the multiple mounting point to help dial in the pinion angle. And,... you might as well get a set of Nate's new tubular trailing arms,... and,... Keep up the good work! |
#48 |
Tot Roddin'
Nice work Doug!
I was in your hometown for a little while yesterday. Needless to say they didn't receive any snow... ![]()
#49 |
Looks like you're making some good progress.
I gotta ask, is your truck always that clean?
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
#50 | |
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 01-01-2010 at 12:00 AM. |
