Old 01-04-2010, 11:03 PM   #26
71swb4x4
71swb4x4's Avatar
Re: Died at an intersection, DOH!
After today don't waste another dime on the coil/points system. An HEI is so cheap compared to the improved starting and running that you will obtain. I did it on my 67 with the 292 and it was crazy how much better it ran, and how much easier it starts.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-05-2010, 12:14 AM   #27
po_bird
po_bird's Avatar
you might want to install a new point set anyways. its pretty simple. they make them with the condensor already attached.
72 SIERRA LB
74 C10 SB
85 C10 SB
75 EL CAMINO SS
po_bird is offline   Reply With Quote
Old 01-05-2010, 01:22 AM   #28
dccarpenter
I'll definitely change the points soon if I don't manage to find an HEI somewhere for the gmc v6 305(google didn't find anything so far...).
I'm really hedging on keeping this engine as I like taking road trips and all and the lack of parts availability has me worried it's going to strand me somewhere.
dccarpenter is offline   Reply With Quote
Old 01-05-2010, 03:41 AM   #29
wwotr
wwotr's Avatar
Originally Posted by dccarpenter View Post
Replaced the ignition coil today(it was at least the 3rd one in the truck as their was a Delco reman'd one in there currently), it fired right up afterwards. Looks like the choke linkage has worked loose and that will be the next project. Thanks for everyones help and suggestions.
AHHhhhh.............
Now I can have a Ciggarette!
Roger
"RATIKLE"
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline   Reply With Quote
Old 01-05-2010, 10:43 AM   #30
adpostel
New Member
Glad you got it going bro!
1968 C10 LWB Project 454/400
http://www.cardomain.com/ride/2417713
adpostel is offline   Reply With Quote
Old 01-05-2010, 11:16 AM   #31
faribran
is there a HEI that will work in the GMC 305 V6?
faribran is offline   Reply With Quote
Old 01-05-2010, 12:46 PM   #32
monte0185
monte0185's Avatar
Not postive on this but look at the 229 v-6 in the 81-82 monte carlo. Its the same as a v-8 but made for a v-6. ITs actually a 305 with 2 cylinders chopped off. 4.3 may work as well just not sure you could find one thats not computer controlled.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 01-05-2010, 02:30 PM   #33
Sinister
Between Trucks...
Sinister's Avatar
Did a little research, apparently there isn't an HEI for the 305 V6, but a Pertronix kit will probably work.
edit: Pertronix part# 1164
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 01-05-2010, 03:05 PM   #34
69GMCLonghorn
69GMCLonghorn's Avatar
Originally Posted by Sinister View Post
X2. Points should go the way of dinosaurs. A remote starter switch is very helpful for finding TDC when you install your new HEI.
69GMCLonghorn is offline   Reply With Quote
Old 01-05-2010, 03:10 PM   #35
po_bird
po_bird's Avatar
Have you ever thought about adding an ign control box like a msd. I put one on my 72 and 85.
I haven't had any problems yet. They have been on there for 3yrs now.
72 SIERRA LB
74 C10 SB
85 C10 SB
75 EL CAMINO SS
Old 01-05-2010, 08:27 PM   #36
dccarpenter
I'll check out the MSD box, there is now a nice made in America HEI distributor on ebay for the 305 v6...only problem is it is over $200.00..wow, that's a big chunk of change for me(especially with the motor having a slight knock I'm still trying to chase down).
I changed the points today, and the oil and filter, truck is starting up right away with the new coil..running much better than before, absent the slight knock and I'd be doing cartwheels. Going to try and pull the pan and check the screen (and hammer out the big dents I put in the pan). Started putting in new window felt too.
Old 01-05-2010, 08:34 PM   #37
po_bird
po_bird's Avatar
You could buy a new msd dist or about any other brand of dist for or that price
72 SIERRA LB
74 C10 SB
85 C10 SB
75 EL CAMINO SS
