#26 |
![]() Join Date: Sep 2009
Re: Changing an Ignition Lock Cylinder
If Leon "lockdoc" says a rooster can pull a freight train then you better go find a chain.
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually Last edited by Duncan and son; 05-28-2010 at 03:41 PM. |
#27 |
Grandpa in the rustmobile...
theres ahole in the tubler straighten out the paperclip and push it in the hole and turn key to the far left, ACC position
it should pop out it takes some foolin' with though
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#28 |
Okay, I think I've got the cylinder fixed--good ol WD-40. I'm wanting to tighten the bezel before i put the dash back in.
Oldblue, are you saying to tighten the bezel by tapping it clockwise? Thanks for the help, Joe |
#29 |
s/b small hole in cylinder on the left side.
#30 |
#31 |
turn it to accesory position, put paperclip into hole and push spring while turning farther to the left (counter clockwise) and pull with key.
you can tighten or loosen bezel with screwdirver or you buy a special tool pretty cheap.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
#32 |
I'm stuck on supid today and this thing is kicking my butt! Is it the little pin hole that is right next to the key hole or is it the hole that is on the side of the cylinder thats inside the dash?
#33 |
It is the little pin hole that is right next to the key hole
#34 |
It's not going--how/where can I drill it out?
#35 |
I should also mention that I can spin the whole unit 360 degrees. Help get me unstuck from stupid
#36 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Ttt
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#37 |
The Older Generation
Read post #4... LockDoc
#38 |
![]() Join Date: Aug 2012
An old thread but very helpful. If any of you are still on this forum, thanks. This was not necessarily easy but a whole lot easier thanks to your advice.
#39 | |
Some of us are still around. Glad the thread helped. LockDoc
#40 |
![]() Join Date: Mar 2012
Cool! I just bought a new lock set today and was going to search to see how to do this! Im going to try doing the doors first. My ignition is fine, but just my doors that are almost impossible to lock and unlock. Hopefully there is a thread of swapping out door locks somewhere..
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
#41 | |
Check this thread out also... http://67-72chevytrucks.com/vboard/s...d.php?t=425488 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 08-09-2018 at 09:07 AM. |
#42 |
![]() Join Date: Apr 2012
Great thread!
Posted via Mobile Device |
#43 |
Wow thanks LockDoc! Thats exactly what I needed! I see how it works now. Easy.
#44 |
Will this same method work for a 1961 Chevy C10? There is no accessory position.
Thank you |
#45 | |
If I remember correctly the '61 has a separate start button does it not. If so, you would turn the key to the right to the "on" position then insert the straightened wire or paper clip to depress the retaining pin. Then turn the key farther to the right to remove the cylinder. This is the opposite direction from the '67-'72's. I would unhook the battery before doing this. Any problems let us know. LockDoc
#46 |
Lockdoc, thanks for the reply. There is no separate start button but as soon as my new ignition lock cylinder arrives, I will give your instructions a try.
#47 | |
If there is a start position in the switch then it would remove just like the '67-'72's.... LockDoc
#48 |
OK, thanks. I will let you know how it goes.
#49 |
The lock cylinder went in with very little problem. You stick the paper clip in the hole and turn the cylinder it to the left while pulling on the cylinder. It will eventually work its way out. Place the new cylinder in the same position as the old cylinder came out and turn to the right. Thanks for the help.
#50 | |
No problem on the help. Technically you should turn the cylinder all the way to the left "Before" you insert the paper clip and push the spring loaded pin down, then it should turn to the left a little more and pull out. LockDoc
