Old 01-11-2010, 11:11 PM   #26
Moody Blues
Re: The best crate motor for the job
Thank you guys. I pulled my head out of my rear and realized that diesel is the way to go. Unfortunately my bad knee prevents me from driving stick so I am going to do some research on dodge automatics and also look for some adapter to gm tranny's. I might be better off going with a dodge tranny and transfer case. I have heard on other forums that Painless Wiring makes a custom harness for this swap.
Moody Blues is offline   Reply With Quote
Old 01-11-2010, 11:22 PM   #27
msgross
msgross's Avatar
Originally Posted by Jim85IROC View Post
With the budget you've got, why not build a pulling truck and buy some POS for a daily driver & plow truck? It seems foolish to piss that kind of money into a daily driver that's going to get wasted by all that road salt.
He's asking about crate motors, not how to spend his entire budget or what we think of it... please stay on topic, some might consider your comments to be rude...
ramjet 502's have been used on this board in 4x4's, can't remember who though...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-12-2010, 12:58 PM   #28
68 TT
Still plays with trucks
68 TT's Avatar
I hear you on the bad knees issue. My heavy clutch, the 5.13 gears and the fact that I have to drive 20 miles though town in heavy traffic every day makes it really tough on my worn out knees. The automatic conversion is high on my priorities list.
There is an automatic that came with the dodge diesel. My grandpa had one. Don't know how common it is though.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 01-12-2010, 01:29 PM   #29
Jim85IROC
Jim85IROC's Avatar
Not sure why what I said was rude. Regardless of budget, sometimes it makes sense to take a step back and look at the whole picture in order to decide what will really work best for a particular application. When a person starts talking about a $30k engine budget in a plow truck, you can't help but wonder if there isn't a better over-all solution. At the very least, simply making sure that the person has considered some of these options can help the rest of us offer better suggesions. I'm not sure why you're so bothered by my concern?
1987 GMC Sierra Classic 3500
454
TH400
My Sounddomain Page
Jim85IROC is offline   Reply With Quote
Old 01-12-2010, 02:11 PM   #30
Damien
Damien's Avatar
I think the dodge trans can be built to be pretty stout. I know one gut that put a $7000 trans into a $3500 truck that didn't need it. (Dad pays the CC bill). I know another gut that is planning to rebuild his for about $3000, including the $1200 converter. I don't know if you have driven a newer truck with a hydraulic clutch, but they can be pretty soft. It might not hurt (sorry, no pun intended) to test drive a newer truck to see if your knee can take it.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 01-12-2010, 03:56 PM   #31
flamingbig10
6.0 powered square
flamingbig10's Avatar
a 632
http://www.sonnysracingengines.com/e...ac-1x4-1210-hp
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 01-12-2010, 06:10 PM   #32
Moody Blues
Let me clarify 30,000 dollar budget for the whole project which includes boxing the frame, rear steering, dana 60's, tons of body work, and other little things. That is why I am considering the cummins motor. I figured why blow the budget on just the crate motor. This why I will be able to complete more of the projct maybe even complete it with some more over time, side work, and hopefully some snow storms that require mad plowing. If I don't finish no biggy I have the rest of my life to get it done.
As for the knee/clutch problem. I have 2 ideas in my head for a hand clutch but I don't know if either of them will work. The first one is a clutch lever from a motor cycle mounted on the shift lever I could squeeze while shifting. The second a throttle assembly from a motorcycle mounted horizontally on the shift lever I could twist while shifting. Some of you fabricators and engineers out there tell me what you think or should I just find an automatic.
Old 01-12-2010, 06:35 PM   #33
swb85
On a budget like Fred Sanford
swb85's Avatar
While I'm one of the biggest "3-pedals or walk" advocates out there, you're better off with an automatic with this one.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 01-12-2010, 06:52 PM   #34
msgross
msgross's Avatar
no problem, not bothered at all, It's hard to get the "tone" of typed text and I wanted to make sure we weren't picking him apart for a $30K budget and all.
back to the subject though:
Have you thought about a hydraulic clutch for the knee problem, would that still be to stiff? Or you could move the accelerator to the left side (if your state allows)
The Garage:
Old 01-12-2010, 06:54 PM   #35
SCOTI
SCOTI's Avatar
Reading your 1st reponse sounds harsh compared to your 2nd. Your intent may not have been to be rude or harsh, but intent is hard to establish sometimes when reading text. No harm, no foul. Msgross typed that faster than I could hit submit .
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-12-2010, 10:39 PM   #36
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
My vote for best crate motor: 350 Ram Jet!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-13-2010, 06:07 AM   #37
Moody Blues
It is not so much of the difficulty of pushing the pedal. It is the repeated motion of doing it that causes the problem. I can go up a ladder with nothing on my shoulder or 8 2X6X8's the knee hurts the same.
Old 01-17-2010, 06:32 PM   #38
clinebarger
Whatever transmission you go with, a dodge diesel doner is a good idea.
You need to figure out wich year dodge your going too use because they've been using cummins engines engine for 21years. several changes along the way.
Painless makes a engine harness for common rail engines (HPCR) 03-06. that are electronically controlled. Have a history of injector failures, & dropping valve seats.
I recommend staying with a mechanical engine from a 89-93 with a VE injection pump or 94-98 with a P-7100 injection pump.
clinebarger is offline   Reply With Quote
Old 01-17-2010, 08:47 PM   #39
qu1cks1lver56
qu1cks1lver56's Avatar
you said biggest alternator you can find. check out DC Power
http://www.dcpowerinc.com/
the 270XP is a beast, pumps out 200 amps at idle. and they can set you up with multiple alternator setups, just call and talk to Rob and he'll set you up right. and tell him qu1cks1lver56 from the SMD forums sent you.
qu1cks1lver56 is offline   Reply With Quote
Old 01-17-2010, 09:01 PM   #40
78 Chevyrado
All you need is Chevy's 4.1L 250 Gas Inline Six.
See...
You can't be towing more than that around...
78 Chevyrado is offline   Reply With Quote
Old 01-17-2010, 09:12 PM   #41
truckincurt
if ur lookin for 450 500 horse just go to the machine shop near your house and take a chevy 350 and just tell them you want 500 horse out of it done deal with out all the weight of them big blocks
diy or die
truckincurt is offline   Reply With Quote
Old 01-17-2010, 09:21 PM   #42
munger
munger's Avatar
drive it like a truck only use the clutch to stop and start nothing else
munger is offline   Reply With Quote
Old 01-18-2010, 10:03 PM   #43
Moody Blues
Clinebarger: What do you think of the 94-98? I could go with a banks power pack, and run some propane.
Munger: That technique is a little hard to do while plowing. A lot of forward and reverse action.
Old 01-18-2010, 11:59 PM   #44
munger
munger's Avatar
Oh I didn't see that
Old 01-19-2010, 07:49 PM   #45
Damien
Damien's Avatar
If you are using a hand cluch your hand will hurt more then your knee after about ten minutes plowing. You could make a shift lever type clutch with a hold position so you could push in the clutch with your right hand, shift, then go back to the shifter. Or a trist grip clutch as a shifter knob.
Old 01-19-2010, 09:42 PM   #46
68Timber
I know the pieces fit
68Timber's Avatar
The Cummins and auto tranny sounds like the ticket, but they had some automatics in the past that didn't hold up. I don't know what version or what years, it's just a 'heads up' to you. Find a Dodge diesel forum and you'll find out quick.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-19-2010, 09:46 PM   #47
clinebarger
There some of the best. The boush P-7100 injection pump is hard to beat.
Do a search on the "KDP" killer dowel pin. Its a dowel pin that locates the timing case and can become loose and fall into the timing gears & cause severe damage, kits are out there to correct this they run about 60 bucks.
Banks stuff is nice but not needed. I use TST diesel power kits. heres some Links
http://www.tstproducts.com/dowelpinr...tfor94-98.aspx
http://www.tstproducts.com/94-98dodg...thvideo-1.aspx
You will need EGT & boost gauges. The quickest way to kill a diesel is to run too high of EGTs 1250 degrees at the manifold is max in my opinion. Stock turbos will support 35-40 PSI anything more will overspeed the turbo & cause the turbo to come apart.
Old 01-21-2010, 04:07 PM   #48
hickracetruck
hickracetruck's Avatar
Thumbs up Re: The best crate motor for the job
Originally Posted by clinebarger View Post
There some of the best-the boush P-7100 injection pump is hard to beat.
if you want 700 hp and roughly 1200-1500ft lb trq this is what i would and am going to do:
find a 94-98.5 dodge
fix killer dowel pin
boost and pyro guages are mandatory anything over stock
4-5 inch exhaust
intake
intercooler (optional)
injectors (up to you)
helix 2 cam
60lb exhaust valve springs and keepers (needed at this power)
snow performance water/meth injection kit (optional but good for temps)
larger turbo, or good set of twins (preference really)
a good lift pump (fass or airdog)
good torque convertor or complete auto tranny (suncoast or whoever)
may want to upgrade fuel lines from pump to injectors
ARP 14mm head studs
either o-ring kit or fire rings (needed above 500hp)
that should be around 700hp, and still reliable for what you need.
i probably forgot some other small stuff but this is it, probably 15g for everything including truck depending on condition of truck! GOOD LUCK
hickracetruck is offline   Reply With Quote
Old 01-21-2010, 09:48 PM   #49
Moody Blues
I have been doing some looking around online and been making a few calls. What do you think a rebuilt motor should go for? So far I have been finding them in the $5,000 range. I have a diesel mechanic trying to cut me a deal that if I will have to put his business name on the truck when I pull at truck pulls, he will build me a motor, with parts at cost and %20 off the labor rate. I don't like the idea. I know that the pullers around here kinda frown on that type of operation. I am going to keep poking around to find the best deal. Thanks for all the great input guys I am glad you guys made me see the light as far as going diesel. I scored another axle for dirt cheap. My girlfriends father is already drawing out the rear steering. He is one of those guys that will wake up in the middle of the night with a good idea and go draw it out. I will keep you posted on the build. It will start promptly after the last snow fall.
Old 01-21-2010, 10:35 PM   #50
hickracetruck
if the rebuilt motor has a cam and exh springs thats not a bad deal, but is it a 89-93 ve? or 94-98.5 p-pump? or vp44 or common rail motor? if its a p-pump (bosch p7100) thats not a bad deal as long as you get motor, pump, turbo and everything else ya need. what truck you putting it in? and what you thinkin for a tranny?
