Old 01-14-2010, 10:17 PM   #26
capev86
Re: What rear gear ratio is good for highway???
if you want to use your truck on the highway but still want to be able to accellerate, pull loads, etc, there are two words to consider....OVER & DRIVE
i would not want anything less than a 3.42, even in a 1/2 ton. the 3.08 makes for lousy get up and go. a 3.73 with a .7 overdrive comes out to 2.61.....way better than a straight 3.08 in top gear. 3.73 gear isn't bad when you are towing and staying under 60mph. gas mileage is best if you keep the speed low too, regardless of the gear ratio....trucks displace a lot of air and those forces add up when you get moving at modern highway speeds.
my 72 burb 3/4 ton has the 4.57 geared ho52 and i have a 4.10 3rd member to go in with plans to install the factory OD tail shaft on the original 3 speed saginaw (3OT). that will equate to a 2.89 final drive when overdrive is engaged. right now i figure the 307 turns about 3100rpm at 60mph, so i keep it under 50 for long drives and only go higher for short jaunts.
capev86 is offline   Reply With Quote
Old 01-15-2010, 09:06 AM   #27
Oldesole7472
i hope youre right...
side note...i'm a new owner of mine so this is all fairly new to me...bought it about 5 months ago...have wanted one since this dude had one back in high school (10 years ago) and damn i'm very psyched to finally drive one as my own daily driver...i think it says something about a person who drives a classic car or truck...best way to describe those trucks is simply "American"...plus chicks dig guys in old classic trucks ha ha ok im done...just had to say that
Oldesole7472 is offline   Reply With Quote
Old 01-15-2010, 09:31 AM   #28
Oldesole7472
yeah thats exactly what it needs...it just feels like there should be another gear to go into once i hit 3rd...i just figured replacing the rear would be the easiest. Capev86 did you ever check to see how much that would cost to have done?
Old 01-15-2010, 02:52 PM   #29
Blackbird66
My '72 had the original 307 2bl, three on tree and 3.73 gear when I purchased it. I drove an hour one way to work and ran around 70. The motor sounded like it was really turning at that RPM. Now the stock cam and little carb like low RPM,s ,but the motor will not fly apart or anything like that. You can swap out the rear from a truck with a 308, but you will loose any ability to pull from a stop with your current motor/trans setup. In fact if you have tried to pull/haul any real weight yet you have already found that the stock first gear seems a little high for that 307......
If it where my choice, I would swap the cam for a reproduction 350hp 327 cam, and install a 600 holley and intake. This will give you more power, and allow the motor to "feel" more relaxed @ highway speeds.
Remember that we have driven overdrive cars for so long that we forget what it felt like before them............
Blackbird66 is offline   Reply With Quote
Old 01-15-2010, 02:58 PM   #30
Stocker
20' Daredevil (Ret)
Stocker's Avatar
A fixed-blade fan will pull a lot of air and make it sound like the engine is running faster than it actually is. If you still have one, consider a clutch fan. Not only will it cool better (get a recovery tank and sealed-system cap, also) but you won't have the constant roar at highway speeds. If nothing else, it makes for more relaxed highway driving.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 01-15-2010, 03:09 PM   #31
Oldesole7472
yeah first gear does feel like its a lil high
Old 01-15-2010, 05:04 PM   #32
Blackbird66
I blew up the original 3 speed. ( actually had pieces laying on the ground ) After that I went with a tremec 3550 five speed. That gave me a first gear that I only needed to pull a load with, and a super smooth cruise at high speeds. My gas milage did not improve at all, contrary to popular theory. Though I am very happy with my setup, it is not a low cost fix.
I still think that putting a little more cam in your motor would be the lowest cost solution for both high speed cruising, and still being able to pull a load from a stop.
Old 01-16-2010, 08:29 PM   #33
johndawelder
johndawelder's Avatar
I have a 67 C-10 custom with a 69 vette 427, 400 turbo trans,3:07 gear in a 72 rear end.I run 32 in. tall tires on the rear.I'm running 2300 rpm's at 75 mph.As you know speedo only reads 100 mph, I've broke speedo cable twice already.As for gas milage,I have no idea.
johndawelder is offline   Reply With Quote
Old 01-16-2010, 11:57 PM   #34
'72customdeluxe
My truck did 100+ pretty easily when it actually ran. 3.73 rear and 28" tires. 3.08's are a crap compromise unless you have a torque monster engine that just overpowers the tires anyway. You lose the acceleration and around town mileage of the shorter gears while still getting crap mileage on the open road. I would hold out for overdrive
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 01-17-2010, 01:53 AM   #35
gonzo6869
Cops, ha, catch me if you can!
gonzo6869's Avatar
I can tell you that you have 3.73's. I was in your same situation, I finally got a tach, at 60mph i am at about 2800-2850rpm. I was thinking of changing my rear end as well, but after doing some research and pricing, I felt like my money would be better spent on a new 200R4 Tranny. It will only be a few hundred more, and its pretty much a direct swap unlike a 400 or 700.
gonzo6869 is offline   Reply With Quote
Old 01-17-2010, 02:01 AM   #36
'72customdeluxe
^What he said. Both the 700r4 and 2004r have a deeper first gear ratio than non o/d transmissions, so you get even better performance along with the rpm drop in 4th
Old 01-17-2010, 05:30 AM   #37
wwotr
wwotr's Avatar
Originally Posted by Oldesole7472 View Post
My 72 c10's top speed is about 55...i wanna swap the rear with one with a higher ratio...any suggestions???
I'm running 3:73 and my Tach reads approx 2300 RPM at 55 MPH.
I like the sound of it, but then again I have a Turbo 350 with no O.D., so theres not much of a "kickdown" after 60 MPH, but then again I don't do a lot of Freeway driving.
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline   Reply With Quote
Old 01-17-2010, 04:49 PM   #38
Blackbird66
200r4 is NOT a direct bolt in for any manual transmission truck. You will need an auto column, or aftermarket floor shifter ( witch may not clear your bench seat), and you will need to ditch the rear motor mounts in favor for a cross member and trans mount, as your three speed does not use a trans mount. And you may still need to modify the drive shaft. I'm not sure the trans yoke is the same on three speeds, as that for th350 or 200r4.......
Did I miss anything else? Oh yea, you will need the kickdown/tv cable brackets....
Old 01-17-2010, 05:49 PM   #39
wwotr
wwotr's Avatar
Didn't know if you were directing that at me or not.
Hello members...
RIP...."RATIKLE"
Old 01-18-2010, 12:14 AM   #40
gonzo6869
gonzo6869's Avatar
What I said was that it is almost a direct swap, I believe he has a TH350, as I do too. So for us with auto's the 200R4 is a good choice, it is the same size as the TH 350, but like you said, it is not a direct bolt in, it needs minor adjustments in order for it to work.
Old 01-18-2010, 12:24 AM   #41
wwotr
wwotr's Avatar
For ME, I just found out we have this "Tranny Guru", within 10 miles of me.
You tell him what kind of Engine (HP Rating) and he can recommend a Tranny based on that HP, your Driving habits and what type of performance your looking for. When the time comes I'll let him know what I have, what I want and throw the cash at him and say "Make it happen".
Hello members...
RIP...."RATIKLE"
Old 01-21-2010, 06:44 AM   #42
hippie-46
i agree with longhorn man i think you got other problems . maybe clutch or pressure plate slipping .
hippie-46 is offline   Reply With Quote
Old 01-21-2010, 10:39 AM   #43
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
What I said was that it is almost a direct swap, I believe he has a TH350...
I have 307 CI, 3 on the tree...no OD.
Nope... 3 speed manual.
Old 01-21-2010, 10:56 AM   #44
Oldesole7472
i highly doubt anything is slipping...but it could be...i am going to replace the clutch, throwout bearing, etc.
Old 01-21-2010, 11:00 AM   #45
Oldesole7472
i love the nostalgia of the column shift...im going throw a tach in her, and see what its pullin...and if its high im going to put an OD in the trans...are all of the original 3sp trans Saginaw trans? I heard Saginaws are crap trans...is this true? my gut tells me that they are fine...mines lasted 40 years...thats gotta mean something...right?
Old 01-21-2010, 11:49 AM   #46
gonzo6869
gonzo6869's Avatar
I stand corrected, did not remember seeing that post. Are the gear ratios different for the auto and manual trannys?
72 C-10 Stepper
350/TH350
3.73 in the back
Edelbrock intake and Carb
Hooker Comp Headers
275/60R15 on Rallies
Old 01-21-2010, 12:21 PM   #47
tjsblazer
tjsblazer's Avatar
Don't know if this will help you or not but it is an awesome calculator. check out the link.
http://www.grimmjeeper.com/gears.html
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 01-22-2010, 11:25 AM   #48
Oldesole7472
ok...just got off the phone with the transmission place...apparently they cant put an overdrive in my original 3sp...i have to find one that had one in it from factory...
Old 01-22-2010, 11:43 AM   #49
Oldesole7472
are there any direct swaps for my manual trans that would allow me to keep the shifter on the column???????????????????
Old 01-22-2010, 05:22 PM   #50
Blackbird66
no
your column shift will only work a three speed manual.
the column shift also makes for a more roomy cab.
I still say that, for the money, put in a slightly hotter cam and 4bl carb. This will make your motor "feel" more comfortable at speed, and the added power will help you pull from a stop better as well.
