Old 03-06-2010, 12:15 PM   #26
jgb7038
jgb7038's Avatar
Re: My 48 ford shop truck
The shaft clears,and can easily be removed/installed,can get to the spark plugs and header bolts,so I welded eveything up and dressed the welds.
I drilled a couple of need holes in the frame,one for headlight wiring,and one for the brakeline thru the frame fitting.I mocked up the front lines to make sure there was enough slack in the lines with the wheels turned.
Moved to the passenger side rail,repeated the process,weld,fill,box,plate,grind....
jgb7038 is offline   Reply With Quote
Old 03-06-2010, 12:27 PM   #27
jgb7038
jgb7038's Avatar
One area I have had touble with is the grill insert.I have made 2 attempts at it already.....neither of which I was happy with.So I am making attempt number 3. I used 1/2" flat stock to make the outside ring,welded some bolts to the shell to mount it.
I added a couple of temporay horizontal bars to keep things lined up while building it.The top part of the grill needs to be layed back slightly so the hood will clear when it opens and closes. I used 3/4" flat stock for the vertical bars.i started in the middle and worked out toward the sides.
Its hard to see in the pictures,but the bars follow the hood lines,meaning that theypeak in the center,and move rear ward as they go toward the outside,basically thay are not flat.
Old 03-06-2010, 12:33 PM   #28
jgb7038
jgb7038's Avatar
I switched back to 1/2" flat stock to finish out the bars.It looks pretty flat in the pictures,but again,it is not.I still need to add some rear supports and finish welding it all up.Its not quite how I pictured it,but it will work.I can always change it later if I want to.
Well,thats where it stands right now,so I need to go out and get back to work today.........
Old 03-06-2010, 03:18 PM   #29
kyull67
kyull67's Avatar
I think it turned out pretty good. Are you going to have it chromed?
kyull67 is offline   Reply With Quote
Old 03-06-2010, 08:17 PM   #30
ERASER5
ERASER5's Avatar
Do you fab for living? You have skills man!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-07-2010, 12:39 AM   #31
jgb7038
jgb7038's Avatar
Not planning on chroming it at the moment,probably just shoot some paint on it for now.
Thanks,and no, I dont do fab work for a living,would like to though.
Old 03-07-2010, 12:46 AM   #32
jgb7038
jgb7038's Avatar
Did some more work on the grill.finished welding up the bars,added a single horizontal bar to hold the verticals in place and ground all the welds.
Was 50 degrees and sunny here in NE Indiana,so I rolled her out into the sunshine so I could clean up the shop a bit....took a couple of pics before I rolled her back inside and got back to work.....
Old 03-07-2010, 09:33 AM   #33
nuke1
nuke1's Avatar
This has got to be one of the coolest trucks there is in my opinion. You have done a GREAT job so far. keep it up!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 03-08-2010, 08:24 PM   #34
GREASEMONKEY72
GREASEMONKEY72's Avatar
some really good fab skills, lookin forward to the rest of the build
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 03-08-2010, 11:34 PM   #35
89muscletruck
89muscletruck's Avatar
WOW!
89muscletruck is offline   Reply With Quote
Old 03-09-2010, 11:35 AM   #36
jason65
Registerd User
jason65's Avatar
Awsome truck. It looks tuff.
jason65 is offline   Reply With Quote
Old 03-31-2010, 08:21 PM   #37
jgb7038
jgb7038's Avatar
Took a short break from the '48 build,did a few thing that "needed" to be done. Was in the 70's today so I started cleaning up the shop.Needed to make room to put my '38 back in with my '48.Had to make room in the other garage for the wifes new toy......
As usual,I took some pictures of the two projects while I had them out side....
Old 03-31-2010, 08:24 PM   #38
jgb7038
jgb7038's Avatar
And a few more......
Now that eveythings put away,I can get back to the '48 build......
Old 04-01-2010, 08:21 AM   #39
jason65
Registerd User
jason65's Avatar
Awsome!
Old 04-01-2010, 10:36 PM   #40
big_al_71
big_al_71's Avatar
you have some great skills,,,,awesome..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 05-11-2010, 09:15 PM   #41
jgb7038
jgb7038's Avatar
Got off my lazy butt,and started back on the truck.I'm using reproduction '37 ford tail lights.Needed to make a mount for them.Used flat stock as a base to attach the light.
Old 05-11-2010, 09:19 PM   #42
jgb7038
jgb7038's Avatar
Used some 1/2" square tube,angled and closed off one end.Drilled a hole on the topside for the light wiring to pass through.Welded it to the base mount.
Old 05-11-2010, 09:23 PM   #43
jgb7038
jgb7038's Avatar
This is how the mount looks on the light bucket.
Took some measurements,and welded the new mounts to the truck.
Old 05-11-2010, 09:30 PM   #44
jgb7038
jgb7038's Avatar
The cage nuts for the tailgate hinges wre long gone before I got the bed.
Welded some weld nuts on some steel and made some patches.
Made some room for the new patches.
Welded them in....
Dressed the welds.....
Old 05-11-2010, 09:38 PM   #45
jgb7038
jgb7038's Avatar
Even though the bed is built,it still needs finished inside....
Cleaned up the rest of the welds/rust/paint/scale/etc.Decided to replace the front bed panel,so it did not get cleaned.
Sprayed some rattle can etch on the bare metal.Didn't spray the floor cause I'm still working on it.
Started back on the storage compartment doors.drilled holes ,and made recesses for the lock cylinders.All the doors will have locks.
Old 05-29-2010, 11:09 PM   #46
jgb7038
jgb7038's Avatar
Got a little slow at work,so I took the gauge pods in to work to keep myself entertained.stripped all the old paint of and and cleaned up the speedo.
Using after market gauges in the other 4 pods,so I made some simple backets to bolt them in.
Old 05-29-2010, 11:13 PM   #47
jgb7038
jgb7038's Avatar
Im using a 67-72 blazer tank in the truck,but I needed to move the filler neck.Got a simple replacement and welded it in.
Old 05-29-2010, 11:16 PM   #48
jgb7038
jgb7038's Avatar
Had a few of the guys from work stop over at lunch to help lift the bed off. Stood it up on the front panel(going to replace it later) so I can work on the underside.
Old 05-29-2010, 11:21 PM   #49
jgb7038
jgb7038's Avatar
Needed to clean up the bottom of the bed,trim some excess sheet metal and weld up a few more spots.
Cleaned up the metal and sealed all the pockets and seams.
When the sealer dried,painted the entire underside of the bed.
Old 05-29-2010, 11:25 PM   #50
jgb7038
jgb7038's Avatar
Dropped the tank out while the beds off.Needed to fill the original filler neck and vents that Im not using.
Cut everything flush to the tank,made a cover plate,and sealed everything up.
Added a little paint.....
