01-20-2010, 06:29 PM | #26 | |
Re: my latest youtube upload
if it is open (infinity Ohms) it will read past full, if it is grounded (zero Ohms) it will read empty. I'm guessing you have a pinched or scraped wire allowing it to go straight to ground. Or an issue where the wire goes into the sender.
CHEVY ONLY |
01-20-2010, 06:51 PM | #27 | |
and the 12v to the right hand pin then ground out the lower middle pin i have a brand new gauge in a box i will try it tomorrow if it works the problem is in the custer if it dont its in the wire back to the sender!!!!! rght?
78 C-10 5.3 LSX -4L60E |
01-21-2010, 11:58 AM | #28 |
ok i tested the gauge when i have it all connected it goes to empty if i remove the ground wire it goes to full ??
01-21-2010, 12:22 PM | #29 |
Still plays with trucks
I noticed you connected a ground wire jumper from the tach to the fuel level gauge in one of your earlier pics. I don't remember seeing that on the original posters pics. Try removing that jumper and see if anything changes.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
