02-27-2010, 09:10 PM | #26 |
Re: Project Anna (71 2wd Blazer)
Finally got the truck to my house. The metal is aslo on the way for the new crossmember. I cant wait to get going on this thing again.
03-24-2010, 10:29 AM | #27 |
After mush hassle the metal finally arrived. Some how the steel got shipped to someone 6 states away with the same name. Fortunately for me he was nice enough to ship it to me, so now I have enough steel for 2 crossmembers or extra incase I screw up. Hopefully I will be able to make some progress tomorrow if I can find someone to fill my gas bottle for the welder.
03-24-2010, 11:18 AM | #28 |
VA72C10
glad to hear you're getting back to working on it. DO you have any ARCET dealers near you? Or check craigslist for welding supplys or tanks and you might find a deal on a tank or two...
Looking for a 67-72 swb or blazer project in or around VA. |
03-24-2010, 01:09 PM | #29 |
Blaze-Air
That's odd about the mis shipment. Glad your back on track.
03-25-2010, 08:12 PM | #30 |
So the crossmember is going to take forever. I spent 6 hours and I am still not half done, it took me 2 hours to do the front and back plates. I need to learn to quit being cheap and just buy the stuff instead of make it.
04-01-2010, 10:05 PM | #31 |
Well the lower half is almost done. I have officially decided this is a pain in the a$$. If anyone else is planning on saving a few dollars building there own DON'T!! I am getting close to the same price as a dropmember and I already had all the tools. A few things I have learned. First use 3/16" not 1/4" ( thing weighs a ton), use P&O not cold rolled (much more expensive, use the highest quality tools available they do make a difference. I believe I will be buying the rest of my parts.
04-02-2010, 12:14 AM | #32 | |
Blaze-Air
04-02-2010, 07:59 AM | #33 |
I realize that now, I wont be doing another one.
04-15-2010, 04:02 PM | #34 |
Im quickly losing interest in this project. 2wd's just dont seem to be my thing. I have the lower half of the crossmember done except for the lca mounts and I have one of the uppers done. Everything seems to be fine and it has 0 camber through most of the suspension travel. Now I need to do the other side and finish welding it, if I continue this project.
04-17-2010, 06:52 PM | #35 |
Well im back to throwing money at it (thanks to the new home owners tax credit ) I have ordered the front bag mounts, rear step notch, ball joints, some exhaust stuff, and shift linkage. Hopefully Ill have some progress pics this week.
04-17-2010, 11:25 PM | #36 |
VA72C10
cool!
05-04-2010, 08:10 PM | #37 |
I have another 10 hrs in the crossmember and I am finally getting close. All I have left is the lower control arm mounts are in the way of the rack so I need to redo them and I have to make the mounts for the rack and engine. The rear notch should be here tomorrow and the new cam (comp big mutha thumpr) and valve springs (ls6) are on the way.
05-04-2010, 09:42 PM | #38 |
On the path to financial ruin!
Hey.......how's about some pics, huh??
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 |
05-05-2010, 05:21 AM | #39 |
Yeah I need to try to get some this week
09-08-2010, 06:15 PM | #40 |
After a little time away from this project, I am back working on her. I have the 4l80e in, all of the brake system arrived today, and the new crossmember is ordered from cpp. I gave up on my front crossmember for now, I just ant to get her driveable as I have owned her for over 5 years and have never once driven her.
09-08-2010, 08:42 PM | #41 |
Grandpa in the rustmobile...
hang in there bud, havent driven my DD in over 2 months!!!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-13-2010, 06:38 AM | #42 |
It's alsways something.....
subbin in here
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
10-15-2010, 09:04 AM | #43 |
Another change of plans. I ordered the T-70 today. Hopefully the 5.3 will hold 10psi and around 600 hp.
10-15-2010, 10:08 AM | #44 |
i have a 4 runner like thta and a 72 blazer was 4x4 now 2wd. what all is done to the 4 runner?
mine has 1 tons, 3.0 ltr auto with the inch worm adapter to change to gear driven case, double transfer cases with a 4.7 kit in the rear case sitting on 42s |
11-05-2010, 06:24 PM | #45 |
4runner has a 5.3/th400/np208 with a dana 44 front lockers front and rear.
11-05-2010, 06:28 PM | #46 |
Got one side of the turbo done. Im not sure how it is going to look but hopefully it will work.
11-05-2010, 06:38 PM | #47 |
VA72C10
Nice!!!
11-10-2010, 07:56 PM | #48 |
For future reference make sure all accessories are installed on the engine befor building the complete hot side for the turbo...doh turbo or water pump decisions decisions
11-10-2010, 08:11 PM | #49 |
Nice Subscribed
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project) It's your ride build it the way you want !!!!!!!!!! |
11-11-2010, 05:24 PM | #50 |
Well the second try went a little better. I have a water pump and I may even be able to run A/C.
