#26 |
Grandpa in the rustmobile...
Re: Brake fluid not comming back to MC
MAN YOUR GOOD lol how do you tell im going to the garage now to put it back on (how i had it before). thank you!
should the linkage be adj. all the way 1 direction or sorta in the middle? Reason I ask is because my linkage is pretty much touching the firewall with brake off. Is this correct/normal thanks!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#27 | |
Hollister Road Co.
#28 | |
Hollister Road Co.
#29 |
ok that'll give me something to go by..
with no linkage hooked up, the rod that goes into the MC is 1.5" where that rod goes theres a rubber seal torn up good i gotta pic but dont wanna uploading it if i can explain it...yall need a picture? its torn and cut and stuffed into the mc its black rubber. could this be a problem and what could've caused it?
#30 | |
Hollister Road Co.
That could be a major factor in the problem. That is a seal and also helps line up the rod. Looks like your in for a booster. unless you an get just that seal. Is that 1.5" sticking out past the seal or pulled out and its the over all length? Whats the back of the master look like? |
#31 |
the seal (dunno if its attached to booster or MC) is jobed into the MC when I pulled booster mc apart.
The rod from pedel to booster linkage is 7" long not gonna be long enough to have .5" between top of linkage and firewall. EDIT It looked torn, leme double check...
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 Last edited by oldblue1968chevy; 01-19-2010 at 08:30 PM. |
#32 |
Hollister Road Co.
Thats the dust boot for a non power brake master. pull that off it doesn't belong in a power setup. snap a picture of the rear of the master. That rubber should have been removed when it was swapped to power. I think you found your problem. now we need to see the rod and the master recess behind that rubber. put the rod in the booster and snap a picture.
#33 |
Hollister Road Co.
snap a pic of the booster where the rod goes
#34 |
Ok, edit, so what rubber thing do i need lol?
the rubber was jobbed into the MC and the rod made a new hole LOL. that didnt help. so get a pic ok HANG ON lol goin to get pics
#35 |
opps was I supposed to take rubber off and snap pic..can go back outside I reckon
THANKS A BILLION!! When I started today I was agrevated. I cheered up when ya gave me advice. Then thrilled when I found out my rubber had holes in it and was the wrong type. Snapped pics but it wont let me upload pictures I took with digital camera..why? If ya like I can email em to ya for you to look at....
#36 | |
Hollister Road Co.
