#26 | |
I know the pieces fit
Re: Why do I want a higher stall TC?
#27 | |
I'm going with the Comp XE274H and a TCI converter with an advertised stall speed of 2400. |
#28 | |
Still plays with trucks
The 268 cam can be run with a stock converter but will like something around 1800 to 2400 rpm range. I would go with about 2000 rpm to start with. When you put in the external trans cooler run it in series with the stock in-radiator cooler so the fluid goes through the stock in-radiator cooler then into the external cooler and then back to the trans.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#29 |
Why keep it 12" convertor what is the problem with the 11'' and 10'' ones I see for sale.
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
#31 |
you need the whole transmission, not just the converter.
Lots of the mid 80's trucks had the TH350C. I know where there is a good one for sale locally. ![]()
#32 |
Here's my take on that. Many factors play into true stall speed of a torque converter - it is not a promise that it will flash at 2200 if it's advertised at 2200. The engine power, vehicle weight, and size of the converter all play a part of what the true stall speed will be. Smaller ones are generally looser converters. With a Comp 268 in a truck, you can be reasonably certain a 12" converter advertised at 2200 will actually flash at 2200.
#33 |
Bruiser, 68 TT, Chlsnk, 78 Chevyrado,
Thanks again, that clears it up. I'll get a little better 2000-2200 converter and add a cooler in series. Good to know the techs at the speed shop weren't misleading me. They did spec a 2400. Later,
![]() 76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262 http://beerbreadbike.wordpress.com/ |
#34 | |
Is the ECM fuse supposed to be in it for the lockup to work? I took all the electronic carb and whatnot out and idk if it needs any ECM stuff to work. |
#35 | |
I believe it will need the ECM to work automatically but you may be able to wire it up to a switch to lock it manually. I know you can do this with the other lock up trans. I did it with my GN. Wire it into the brake switch so it disengages when you step on the brakes like stock so it doesn't stall the motor when you come to a stop if you forget to unlock it.
#36 | |
#37 |
It shouldn't have anything to do with the ECM unless it was fuel injected. It is a hot wire that goes through an extra set of contacts in the brake switch that will unlock the converter when the brakes are applied, then through a vacuum switch mounted on the firewall that will only let it lock under light throttle, high vacuum.
Look on your firewall above the brake booster and see if you have a vacuum switch with 2 green wires. You can also tell easily if there is a white 4 wire plug on the drivers side of the transmission up above the pan flange and to the rear of the shifter.
![]() ![]() Last edited by joe231; 01-20-2010 at 09:16 PM. |
#38 |
Alright I'll check that out tomorrow. I know there is a connector on the transmission in the place you described but I'm not sure of the color or number of wires. And I'll look on the firewall for that switch. I know it's got all kinds of junk on the firewall that I want to go through and find out what's not needed and get rid of it.
#39 | |
#40 |
It's been so long since we put that motor together I can't remember all of what we pulled out. It had a stock 305 with the electronic carb and all the other electronic junk. And we pulled that off and setup a holley 600 on it. And then built the 350 that's in it now. It's out in the shop right now, water pump went bad, but I'll look it over when I get out there.
#41 |
it all depends on what rpm range your engine is built for, and what rear gears your using.
#42 |
3.42 rear gear. engine is built for low end toque. I'd say 6k is the most it should ever see.
#43 |
then i wouldn't recommend it, if you had a nice street/strip motor where the power band of the internals is like 3000-7500 rpm, then i would recommend it.
you want to match it with your cam and intake rpm range. you'll also have to look into ur rear end ratio. thats not a bad ratio, but if the engine is being used from idle-6000 rpm, you might want to go with a small stall convertor, not like a 3000 or 3500 |
#44 | |
haha, ford guys...
you will need a higher stall if ur upgrading to a large cam (wont idle) another bonus is to get the car in the power range immedently (I have a 2000 stall).... the freeway thing, yes, if u have a 4speed tranny with 4th going 70mph at 1500 rpm and you have a 2000rpm stall, yes, your torque converted will slip, thus causing premature wear, excessive heat and overall bad news. i think what the person i quoted was trying to say is some people buy torque converters with a stall at their power range.... example: car makes 300hp at 3,400rpm and 120 at 2000rpm, its a race car.... when u jump off the line, u wanna be making 300hp immediately, no lagging. keep in mind a torque converter is not like a clutch, it works using hydro pressure, not physical contact of disks. you should look into trans brakes also, some good stuff there. Last edited by spinem; 01-22-2010 at 10:45 PM. |
#45 | |
#46 |
Well I have a vacuum switch above the brake booster, gonna hook it up tomorrow and see if my 70mph rpm's are different.
#47 |
cool
#48 |
inorite?
#49 |
#50 |
inorite/i know right lol
Well I hooked it up today but didn't get out on the interstate and couldn't really tell if there was a difference riding around town. But I did get my serpentine swap done. |
