#26 |
![]() Join Date: Nov 2001
Re: Lifting off my cab...
54blackhornet.... Well your just cheating...
You are using gravity to help you when you turn everything upside down... hahahaha
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
#27 |
I use the two post lift in my shop to lift both the cab off and the bed off the different trucks that come through. I have tried everything throughout the years for backhoes to fork lifts but the two post is by far the easiest way to go. this method I can by my self take on or off a cab or bed, the very first thing I used it for was to change a Suburban body that had been rolled. Jim
#28 |
I gave up trying to flip photos ?
71 C-20 07 Magnum RT AWD |
#29 |
A few more
#30 |
Using a 4x through the windows didn't bend or dimple the doors any? I'm working on a '66 but same principal I think.
#31 |
4 guys can lift gutted cab pretty easy. Myself, 17 year old son and a few of his freind...
easy peasy |
#32 |
![]() Join Date: May 2003
Here's how I do it. Made up this jig to go on an egine hoist.. Easy one man operation.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
#33 |
Here's how I do it. I use a chain attached to the outside seat belt anchor holes and a ratchet strap attached to the lower door hinges. The ratchet strap allows you to adjust it so it is horizontal to the frame. Works great I have had the body off and on my frame many times. When I'm done working on the chassis I put the body back on so the wife can park her car in the garage.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
